mega mega is offline
Default flash + meth map and meth modes - 09-22-2021, 06:28 PM
anyone have a current list of map modes and meth triggers? The stickies appear to be out of date I saw old posts and new edits on 4/4 and I'm not entirely sure if 4/4 retains all safety functions
background, considering custom flash + jb4 with meth. Currently using race bef with jb4/meth.
I believe the safest is 4/3 map 3 +adder with meth trigger 0 I think targets minimum of flash but adds adder on top, retains safeties
does 4/4 map 3 adder also retain safteties? I think the only differnece is flash vs jb4 boost targets?
How does meth trigger 4 play into this? it's not on the stickies but I know it was added at some point. I used 4/2 map 3 and meth trigger 4 last weekend and it worked well.
if I want to spray and log with MHD is that possible without disconnecting the jb4 harness?
Default 09-23-2021, 07:09 AM
If you want to retain the meth safeties, you need to run the meth map. That is the safest option. You can always run a lower additive.
Default 09-23-2021, 07:26 AM
are there any clear docs on what safties each of the 4 modes do, i.e, 4/2 vs 4/3?
meth trigger mode 4 ? not documented at all except for a couple old posts by terry
Default 09-23-2021, 07:27 AM
also I cant find what a stock map sensor adder 75 will translate to with a 3.5bar map sensor, to still target 20psi I think the adder needs to be MUCH lower
