lu6i4 lu6i4 is offline
Car: 2007 E90 6spd Rwd
Default Twin Disk Prep - 09-15-2021, 09:03 AM
So I just ordered the Motiv twin disk ST trim clutch kit and currently awaiting its arrival. I was wondering other than the rear main seal, what else should I replace before the installation. I'm looking into the BWS billet clutch valve to get rid of the delay and the ECS Performance clutch fork pivot pin. I'm curious what else I should do.
Snertz's Avatar
Snertz Snertz is offline
H O O N
Car: Ein M
Default 09-16-2021, 02:08 PM
Could replace the pilot bearing but I wouldn't recommend it unless absolutely necessary, it's a pain in the ass to remove from the trans input shaft.
Recommend following the DIY that Tony@VTT posted elsewhere, it's quite good.
H O O N
Default 09-16-2021, 03:07 PM
thanks you for the input
