(#4476)
Jaybone Jaybone is offline
Car: 2020 Kia Stinger GT1 AWD
Default 07-12-2021, 11:56 AM
Get those fuel wires connected you get more power up top. And the ewg make the car a monster!
JB4 W/FUEL WIRES & EWG WIRES
BMS INTAKES
BMS WMI KIT
BMS OCC
FUEL IT FLEX FUEL KIT
BORLA EXHAUST
STOPTECH FRONT AND REAR PADS
DENSO 5346
SEIBON CARBON FIBER OEM HOOD
NICHE 20" WHEELS MATTE BRONZE
CERAMIC PRO SILVER PACKAGE
DRONE MOBILE REMOTE START
Boobizzy Boobizzy is offline
Car: Kia Stinger GT2 AWD
Default 07-12-2021, 02:39 PM
Expect over boost codes on the stock tuning with exhaust mods. JB4 will manage it to a degree on its tuned maps but to really fix it in cold weather add in EWG wires. Those let the JB4 lower WGDC and properly control turbine speed.
Sounds like a plan! I have some time before winter hits but it looks like I'll need to get those wires installed. Thanks!
Default 07-12-2021, 02:40 PM
Originally Posted by Chanluder
P0049 Turbocharger/Supercharger Turbine Overspeed
Itís mostly your down plpes. Installing EWG wires might fix it.
I was thinking it was the down *****. Great to know!
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 07-13-2021, 06:54 AM
So I'm going to be getting a carbon fiber steering wheel soon that has the led lights and info screen on the top and i noticed that it needs to plug into the obdii Port to send info to the wheel. The jb4 currently occupies that port.
What would be the best solution to this predicament? I have read that obd splitters don't split the signal and it would just be one getting power while the other gets all the info.
2020 Elantra Sport DCT FBO
JB4 Map 3 w/ E30
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 07-13-2021, 07:12 AM
My experience with splitters has been good. Don't spend the big $ on marketed ones. I bought one off Amazon for about $10 with good reviews. Sometimes it's just a matter of which device you plug in first.
khancerto's Avatar
Default 07-13-2021, 07:15 AM
Sure, do you have any recommendations?
JB4 Map 3 w/ E30
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 07-13-2021, 08:00 AM
This one is a freebie. Go to Amazon, type ODBII splitter and pick one with good reviews
Amazon.com: Right Angle OBD2 Splitter Y Cable Male Splitter to 2 Female Extension Cable 1ft Feet 30cm/12 (1male to 2 Female) 24AWG: GPS Navigation
This is the one I picked and works well
khancerto's Avatar
Default 07-13-2021, 08:10 AM
I get that I can just google OBDII splitter, but there are a lot of options out there and a lot of them mention that only one will get info and power while the other will just get power. So I am asking here if anyone has gotten one that does both info for both so I can run the steering wheel gauge and JB4 simultaneously through the same port. A review on the one you listed said that it doesn't do what I am trying to achieve. What are you runninng with the splitter currently?
JB4 Map 3 w/ E30
ssgm1x ssgm1x is offline
Car: bmw 535i
Default 07-13-2021, 09:11 AM
Originally Posted by Jaybone
Do you have a lot of bolt ons?
Currently stock 3.3T with just a JB4 on Map 2.
Before I start adding Performance mods, I would like to do some baseline Dragy runs.
2021 BMW M340ix w/JB4
2018 BMW M3 w/ECU Flash
10.6sec 1/4mi 6.6sec 60-130mph
Default 07-13-2021, 09:14 AM
Then why not run a map 0 run?
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: bmw 535i
Default 07-13-2021, 02:10 PM
I will be running a Map 0 through Map 2 on a New stock 2022 G70 on stock plugs to compare runs. Then I will be adding bolt ons, intakes, plugs, e30, etcÖand comparing gains and running other maps.
I was just curious what others are running so I know what to expect.
Thx !!!!
kdSpartan kdSpartan is offline
Car: 2018 Kia Stinger GT2 AWD
Default 07-13-2021, 02:15 PM
Thx !!!!
I wouldn't run Map 1 and especially not Map 2 on stock plugs. You can, but seems like an unnecessary risk on a brand new engine for some experiment to see what it gets you.
If you want to install the rest of the mods incrementally and track your progress, go for it. I wouldn't do the JB4 without plugs though
Default 07-13-2021, 02:20 PM
You can do stock plugs with the correct gap. But for the small cost to get some plugs and have piece of mind is worth it!
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: 2019 STINGER GT2
Default 07-13-2021, 03:08 PM
There's no sense in pulling the stock plugs to gap them and put them back in. Pull the stock plugs to put the right ones in, with the proper gap. Either Denso 1(2)-step or HKS.
Chanluder's Avatar
Chanluder Chanluder is offline
Car: Stinger
Default 07-13-2021, 04:13 PM
Yup might as well get some new sets.
cncbilly cncbilly is offline
Car: Stinger
Default 07-13-2021, 05:02 PM
I just updated to 21/22/5 (Kia Stinger) and now my gauges on the app don’t work. Help pls.
Cheers,
Bill
Default 07-13-2021, 05:09 PM
Originally Posted by cncbilly
I just updated to 21/22/5 (Kia Stinger) and now my gauges on the app donít work. Help pls.
Cheers,
Bill
Completely close out of app and restart phone. If it doesnít fix unplug and re plug ob2
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: bmw 535i
Default 07-14-2021, 03:43 AM
Then I guess itís time to install the new spark plugs I got.
I am not looking forward to this install (am not removing intake)
Thx !!!
Default 07-14-2021, 04:42 AM
Thx !!!
The right tools will make the job a breeze. Just takes a little more time and wiggling on the passenger side.
Car: bmw 535i
Default 07-14-2021, 04:52 AM
Thanks for the support !!!
Iíll make sure Iím well prepared with tools. 🤙
Default 07-14-2021, 06:04 AM
6" MAGNETIC SWIVEL SPARK PLUG SOCKET
3/8" drive with extension (3",6") and swivel
1/4" drive with extension and swivel (3/8" adapter)
10mm socket or 10mm offset wrench (I use the socket)
Car: bmw 535i
Default 07-14-2021, 06:41 AM
Luckily I have everything on this list.
Will give it a go
Thanks !!!
Car: Stinger
Default 07-14-2021, 09:25 AM
Do I unplug with Engine off AUX on or all off. Phone reboot was first thing I tried with no success. Will try obd this morning. Thx.
Default 07-14-2021, 10:26 AM
Unplug the jb4 cable that is plugged into the ob2 port. Wait a couple seconds and re launch the app and see if that fixed it
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Default 07-14-2021, 01:57 PM
Cheers,
Bill
May need to lock doors and wait a few min, or maybe you knocked the OBDII loose.
