(#4401)
Seef824 Seef824 is offline
Car: Kia Stinger GT
Default 06-20-2021, 05:07 PM
Originally Posted by Jaybone
What does the code say is the issue? What are your plugs gapped at?
PCM error. The code with JB4 said no information. Google returns a PCM fault that appears to be related to the transmission and requested vs actual torque or MAF issues (which we dont have MAF, so not sure how that relates to throttle).
edit: plugs (denso) are gapped at 0.022.
Chanluder's Avatar
Chanluder Chanluder is offline
Car: Stinger
Default 06-20-2021, 05:25 PM
Something is wrong with the JB4 connection.
Car: Kia Stinger GT
Default 06-20-2021, 05:28 PM
Do you know of anything I can check? When I looked under the hood, everything looked good.
Chanluder's Avatar
Car: Stinger
Default 06-20-2021, 05:39 PM
Check the JB4 pins. If those checked out, reach to Terry. Might be something wrong with JB4 itself.
Car: Kia Stinger GT
Default 06-20-2021, 05:54 PM
I just rechecked all of the wire routing. No wires are pinched or rubbing on anything. I used to manage harness wiring on large equipment, so I took extra time during the install to ensure I routed and retained the JB4 harness and fuel wires away from heat and sharp points as best as possible.
I am not sure what the wiring schematic is for the JB4, but I could check that if it is available.
Is support email the best way to get hold of Terry? or is there another contact method?
rbjohnson78 rbjohnson78 is offline
Car: Kia Stinger 3.3
Default 06-21-2021, 08:51 AM
Yes I would go to map 0 and check those before attempting anything else. Make sure to use the feeler style gap tool so you don't damage the tips.
I pulled the negative for about 15 min or so, and did a run on map 0. Looked a lot better. Did a quick pull on map 1 and I think it still looks ok. I have the csv if you wouldn't mind checking again to see if anything pops out to you. It will be my last pull before checking the plugs. Thanks for all the help!
Jaybone Jaybone is offline
Car: 2020 Kia Stinger GT1 AWD
Default 06-21-2021, 09:03 AM
support@burgertuning.com
Default 06-21-2021, 09:18 AM
Looks good re log in a couple days and if timing is bad again pull plugs and check
JB4 W/FUEL WIRES & EWG WIRES
BMS INTAKES
BMS WMI KIT
BMS OCC
FUEL IT FLEX FUEL KIT
BORLA EXHAUST
STOPTECH FRONT AND REAR PADS
DENSO 5346
SEIBON CARBON FIBER OEM HOOD
NICHE 20" WHEELS MATTE BRONZE
CERAMIC PRO SILVER PACKAGE
DRONE MOBILE REMOTE START
stinger38 stinger38 is offline
Car: Kia Stinger
Default 06-21-2021, 10:01 AM
Would appreciate a log check. Second time owning a JB4 for my car, but this time around it doesn't feel as smooth and feels rough (ever so slightly) at partial throttle. The car feels better with more throttle applied then less.
Log is done on Map1, 91 oct(with a gallon of e85 - was previously testing if the roughness was octane related) vehicle is stock with new Denso 5346 IKH24 plugs.
Default 06-21-2021, 10:50 AM
Thank you for checking! I really appreciate it!
Default map6tuning log - 06-22-2021, 10:57 AM
I sent in my map 2 log and got the message below back. Any concerns with this, or something I should check?
Boost1 and Boost2 To far apart B1: 11.5 B2 3.1 8.4 TS: 2302.75
Default 06-22-2021, 01:07 PM
You have horrible timing. The worst I have ever seen! What are your plugs gapped at?
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Default 06-22-2021, 01:11 PM
Who said that?
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Default 06-22-2021, 02:02 PM
Hey guys, I'm back home (had a fun hospital stay after unexpected internal bleeding during a routine procedure) but have limited energy so won't be doing a ton of forum or email. Will keep up where I can. Steve is manning the forums and you can always email support@burgertuning.com or payam@burgertuning.com if you need a quicker response. I'm able to do around 100 emails a day (1/3 my normal load) so will keep up where I can.
Default 06-22-2021, 02:23 PM
Hey guys, I'm back home (had a fun hospital stay after unexpected internal bleeding during a routine procedure) but have limited energy so won't be doing a ton of forum or email. Will keep up where I can. Steve is manning the forums you can always email support@burgertuning.com or payam@burgertuning.com if you need a quicker response. I'm able to do around 100 emails a day (1/3 my normal load) so will keep up where I can.
Rest up Terry hope you get better soon! We need you healthy to keep making fun goodies for our cars!
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: 2019 STINGER GT2
Default 06-22-2021, 02:37 PM
Get better soon!
Default 06-22-2021, 06:27 PM
Who said that?
The reply you get from the map6bot email.
Default 06-22-2021, 06:51 PM
Sorry not sure what that is. From what I saw your log looked fine to me
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 06-22-2021, 07:04 PM
It was probably right when you lifted. One boost is pre throttle, the other is post throttle, quite normal. Now the only way to tell is to post a log. There's no one on earth that can say if you have a problem from what you posted.
It's like asking a doctor to confirm a broken bone over the phone.
Darrin S.
2019 AWD GT2, JB4, Meth, MBRP, Agency intakes, Agency FMIC, HKS Plugs 11.13 @ 123 mph
Car: Kia Stinger
Default 06-22-2021, 09:31 PM
Gapped down to .022
Default 06-23-2021, 04:55 AM
You are probably right, still learning these logs. I enabled future use A, so I think a couple things may look different, I just heard it was easier to diagnose. Log attached for your leisure.
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 06-23-2021, 05:41 AM
Your log looks normal for map2, no issues. I prefer FUA 0, it's actually easier to see deviations than 5 spaghetti line in different colors spread all over the graph.
Default 06-23-2021, 07:16 AM
Gapped down to .022
I would drop to map 0 and try some different fuel and splash some E85 (3 gallons) to a full tank of fuel and then re log. Map1 is mild and should be fine for 91 octane but that must be some really bad gas.
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Default 06-23-2021, 07:32 AM
Cool! Time to move up to map 3! Running E27 so hopefully all is good! Never ran map 3.
Default 06-23-2021, 07:38 AM
Map 3 is good fun!
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
