Sandro_335i's Avatar
Sandro_335i Sandro_335i is offline
Car: 2009 BMW 335i xDrive E90
Default Log Review M5 F10 - 05-04-2019, 08:17 AM
Mods are:
JB4 with BCM V2
40/60 mix BMS Meth kit (turbo power windshield washer fluid, the blue stuff)
94 Octane fuel
Stock clutches
After every pull in map 8 the car changes to map 4. Need some help troubleshooting.
Default 05-07-2019, 04:08 PM
Is there a way to target slightly less boost, im thinking like 22psi. Some sort of guidance would be greatly appreciated.
Default 05-15-2019, 03:39 AM
Bump
Default 06-02-2019, 06:31 PM
Here are two more logs I got. I changed the boost additive to 25.
Should I lower the min flow boost (PSI)? Currently it's set to 15psi
