Blessking35 Blessking35 is offline
Car: Mk7.5 gti
Default Mk7.5 gti jb4 issue - 02-04-2019, 07:48 PM
Can't download the new firmware update. Having trouble making sure I'm also selecting the right down for my engine.
Default 02-04-2019, 08:55 PM
What are you having trouble with?
Car: Mk7.5 gti
Default 02-05-2019, 04:27 AM
After finally getting the firmware up to make sure my jb4 is working correctly. That didn't help get my gauges functioning correctly. They still don't operate only show my boost or map 2 setting. How do I solve this issue?
Default 02-05-2019, 05:17 AM
Did the gauges work before?
Do you have the OBD connected inside the car. If so check to see if the small molex plug is connected with the correct orientation. You can use the angles below to match male to female.
Car: Mk7.5 gti
Default 02-05-2019, 05:26 AM
The guy I bought my jb4 didn't give me the OBD connector unfortunately so that must be my problem. If I were to ask u for a custom tune will it's still work and data logging?
Default 02-05-2019, 05:43 AM
The OBD wire can be found at this link: http://www.burgertuning.com/JB4_upgrades.html
Its in the drop down menu in the JB4 connectors section. Select the OBDII only LHD for left hand drive.
With the wire the JB4 does not see all the engine data for mapping purposes so you pretty much restricted as it runs a safety map without it. Relative to the firmware version loaded it might not be adding any boost.
Car: Mk7.5 gti
Default 02-25-2019, 08:36 AM
Hey George I have the jb4 fully connected OBD cable is in and all. Check engine light is on but the jb4 code scanner cant read the code. Why is that?
Default 02-25-2019, 01:00 PM
When you reading the fault what does it show?
Car: Mk7.5 gti
Default 02-25-2019, 01:17 PM
3ABA no description found for both
431A
0000 unknown found
Car: Mk7.5 gti
Default 02-25-2019, 01:18 PM
Will a data log help u understand anything?
Default 02-25-2019, 02:26 PM
431A
0000 unknown found
431A is a notification that something is stored on another ECU of the car.
3ABA is fuel rail pressure fault typically caused by the fuel open loop value being to high. What have you got it set at? It can also be triggered from doing a hard pull on low fuel level.
_Dejan_ _Dejan_ is offline
Car: Seat Cupra ST 300 4DRIVE DSG
Default 02-25-2019, 02:35 PM
George how we can decode error codes to standard OBD codes?
Today my car hestitate at full aceleration JB4 go to map 4, CEL/EPC light show on dashboard and by jb4 read codes I get:
P0000 No Description Found
P01100 No Description Found
Car: Mk7.5 gti
Default 02-25-2019, 02:37 PM
Haven't done anything to the ecu other than put the jb4 on? Fuel loop is set to 45 from what u told me to do before. Haven't done a hard pull on low fuel she is running one 93 oct
Car: Mk7.5 gti
Default 02-25-2019, 02:41 PM
I'm only also switching from start up with map 0-1. Start up is slow so I worry that I'm damaging the starter motor car has only 11k miles and from start is always quick. Also from start up she's popping a bit like my intake valves r clogged but I know that way to soon to have right now
Car: Mk7.5 gti
Default 02-26-2019, 09:32 AM
New check engine code 53B1 no description.
I'm running map 2 now with a iE Cold air intake and cattless ******** resonator delete stock everything else
Default 02-27-2019, 03:54 PM
[QUOTE=Blessking35;624762]New check engine code 53B1 no description.
I'm running map 2 now with a iE Cold air intake and cattless ******** resonator delete stock everything else[/QUOTE
Fault is second air injection- insufficient flow. Its the SAI that connects to your air box. Clear and see that if it comes again.
Car: Mk7.5 gti
Default 02-27-2019, 08:19 PM
Still have code 3ABA. Everything else is clear
Car: Mk7.5 gti
Default 03-02-2019, 05:09 AM
Plug C is faulty that's why that code was on. Am I able to buy a new set of cables?
Default 03-02-2019, 05:29 AM
Fastest resolution to issues like you having is to email me at george@burgertuning.com .
Car: Mk7.5 gti
Default 03-02-2019, 02:42 PM
Can I use other maps without plug C in?
Default 03-02-2019, 06:55 PM
It will run more like a conventional piggy back without it. Map 1 is ok to use and with map 2 the ECU will most likely run at full fuel trim.
Car: Mk7.5 gti
Default 03-03-2019, 12:28 AM
Ok so don't run map 2 because we need plug C to run 60 instead of 45 on fuel loop. Got it. Couldn't find a replacement set of cables for my jb4. Where can I buy 1?
Default 03-03-2019, 05:49 AM
Map 1 will be safe. Without the plug fuel open loop does not work as its the plug that affects the rail pressure.
If I am not mistaken I emailed you in regard to the cable already?
Car: Mk7.5 gti
Default 03-03-2019, 05:54 AM
I did not get a email back sorry George. But thanks
Default 03-03-2019, 04:01 PM
Sent again. Check your spam folder maybe.
