johntotah94 johntotah94 is offline
Car: B46 F56S
Default No meth Map 3. Meth working Map 1?? - 09-16-2018, 12:46 PM
Interesting situation.
Meth stopped flowing on Map 3. Well on some random pulls it would turn on, but most of them no meth.
Map 1 on the other hand flows meth every single time. (Meth Trigger = 1).
Took these logs after lowering Min Flow Boost to 6psi. Still have issues.
Cooper S F56.
JB4. BMS Meth kit. DevilsOwn Size 7 Nozzle.
See attachments for logs.
Thank you in advance
Default 09-17-2018, 03:14 PM
Attach the CSV files to the post directly, not in a zip folder.
Opened one or two, don't see what your issue is. Photo of the WMI user adjustment settings?
Car: B46 F56S
Default 09-18-2018, 06:49 AM
Map 1 and 2 flow meth perfectly fine.
Map 3 (meth map) stopped flowing meth completely for some reason. Or has random spikes of meth flow on occasion.
Out of precaution, I rewired the entire system for more reliable connections. Same issues unfortunately.
Must be something on the software side.
Thoughts?
Logs and settings attached.
Default 09-18-2018, 07:02 PM
What about meth trigger = 0, does map3 meth work consistently then?
Car: B46 F56S
Default 09-19-2018, 08:37 AM
Negative Sir.
Meth Trigger = 0. Still does not flow Map 3.
Meth Trigger = 1. Flows properly on Map 1 and 2. Not 3.
I would suspect some bugs in the MINI software. Also, when I let off throttle, AFR goes to 3.8 all the time. Don't think this is correct either.
Log attached.
Thoughts? Thank you
Default 09-19-2018, 11:11 AM
AFR is correct when letting off gas as fuel is cut off. It's only valid under normal load levels.
Found a bug in the firmware. Try this.
Car: B46 F56S
Default 09-20-2018, 11:46 PM
Seems to be working fine now. Had 1 time where it didn't flow. Changed Min Flow PSI from 7 to 6. So far so good.
Trying to figure out boost. Boost Additive is at 65 and looks like I only get about 12psi. Unless I am reading it wrong.. (Logs attached)
Is it possible to do Map 3 as Map 1 boost levels and Boost Additive value ads on top of that?
With a tune I was running around 22psi (probably not reliable imo). I'd like to be around 16-18psi with JB4 if possible.
Default 09-21-2018, 01:18 PM
The target is around 15psi, but without an EWG connector to drive boost to target it's going to make whatever the factory dutycycle tables allow.
Car: B46 F56S
Default 09-21-2018, 02:14 PM
I know its hard to install. But I can do it.
Can I buy the EWG connector? Or is it not available for MINI?
Default 09-21-2018, 02:32 PM
We have not done much work on that front. A few have bought them, then ever hear back on anything.
Car: B46 F56S
Default 09-21-2018, 02:53 PM
Will the software auto adjust if I connect it? Or do I need new firmware?
Will "JB4 F Series EWG Add On Connector BMW B48/B58" work? I can figure out how to install and report back with logs and such.
Will order today if you confirm it works. Thank you.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 09-23-2018, 03:20 PM
Can we update to this firmware test 1 attached or is it specific to the meth issue. I am in the process of installing meth awaiting charge ***** for the grand tourer. EWG does work on the b38/b48 ; may improve low end torque as in my case.
Default 09-23-2018, 06:05 PM
Yes anyone can load the test firmware if they are having a WMI issue.
Car: B46 F56S
Default 09-24-2018, 01:34 AM
Still a few occasional runs with no flow. Changed min boost to 4psi and seems more reliable for now.
Can I order EWG Connector? Or bad idea?
