DaySleeper DaySleeper is offline
Car: 2001 and 2013 BMW M5
Default F10 M5 Methanol Install - 10-11-2018, 10:14 AM
Where are guys routing the red power wire that goes to the fuse panel? The pictures show a fuse box under the hood on a different model car.
Also, I've routed the methanol line inside conduit under the car.
https://flic.kr/s/aHsmp2ia3s
Jon @ BMS's Avatar
Jon @ BMS Jon @ BMS is offline
Administrator
Default 10-11-2018, 12:46 PM
Photo attached. The location is in the passenger side corner compartment under the hood near the windshield. Just remove the cover to access the area. A fuse piggyback is used in the photo shown, but you can just push a wire in next to the fuse as well if needed.
It is the sole responsibility of the purchaser and installer of any BMS part to employ the correct installation techniques required to ensure the proper operation of BMS parts, and BMS disclaims any and all liability for any part failure due to improper installation or use. It is the sole responsibility of the customer to verify that the use of their vehicle and items purchased comply with federal, state and local regulations. BMS claims no legal federal, state or local certification concerning pollution controlled motor vehicles or mandated emissions requirements. BMS products labeled for use only in competition racing vehicles may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event, in accordance with all federal and state laws, and may never be operated on public roads/highways. Please see http://www.burgertuning.com/emissions_info.html for more information on legal requirements related to use of BMS parts.
Default 10-11-2018, 02:22 PM
Default 10-18-2018, 02:59 PM
Is there a screenshot of the settings required for the methanol pages on the jb4 app? I see some things that I don't know how to set up.
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 10-18-2018, 08:58 PM
Your settings depend on your setup. Describe your setup and post a photo of your settings and you can get feedback!
Default 10-19-2018, 06:33 AM
I have a jb4 v1 with the burger inlet and charge *****. No other mods.
Default 10-19-2018, 06:37 AM
BTW here are some pics of the installation!
https://flic.kr/s/aHsmu76u9Q
Default 10-19-2018, 02:12 PM
Well I tried it and the car goes into limp home without even building any boost on map 8. Went back to map 1 and still does it. It was working fine on map 1 with using ethanol kit not selected.
The messages are 140010 misfires, more cylinders
14081 misfires cylinder 8
