V8MUNRO V8MUNRO is offline
Car: F10 M5
Default The best s63tu oil for tuned applications - 02-04-2018, 04:24 AM
Changing my oil next week and i always use bmws oil but i have been unfortunate enough to have lost an s63tu engine due to a spun shell (only had car few weeks and believe previous owner abused) this coupled with the fact the older m engines are prone to excessive crank bearing wear makes me want to use the best oil. I change my oil every 4-5k so i do not need longlife. At the moment i am aining towards motul 300v but unsure of what weight to go for as i do not understand which suits our engines best. Looking for advice from those that do oil samples or have knowledge on the subject. Thanks (btw i am aware theres tons of information on oil out there but little is backed up and tends to be more i use castrol because its good and i was told to)
F10 M5 SAKHIR ORANGE
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 02-04-2018, 08:16 AM
Suggest you go for a slightly thicker oil than what BMW suggests. 5/40 or 10/60.
Depends on bearing clearances etc but BMW generally tends to go tight from the factory so that merits 5/30.... I suppose if you change
frequently enough it should be fine.
Car: F10 M5
Default 02-04-2018, 08:19 AM
Mind if i ask what you was using when was on stock block?
Default 02-04-2018, 08:23 AM
I went with stock weight and changed every 3K. Now I am on 10/60 but that’s intentional given we have accurate measurements on all clearances etc.
Car: F10 M5
Default 02-04-2018, 08:57 AM
Thanks for input ��
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 02-04-2018, 12:22 PM
Valvoline VR1 Racing 10W-60 Semi Synthetic Oil
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
Down4it's Avatar
Down4it Down4it is offline
Default 02-04-2018, 12:27 PM
If you're under warranty stick to OEM and buy direct from BMW. If you're not under warranty, get some warranty and stick to OEM.
steeve13m steeve13m is offline
Car: 13 M5 DCT
Default 02-04-2018, 05:53 PM
Did plenty of oil analysis on different oils and been using Total oils for many years....I use Total 5w40 on the F10 M5
2019 Marina Bay Blue M5 Competition, HRE FF04 21",BMC filters, 5% Window tints,Clear protection film,Escort Passport MAX,zw5,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Car: F10 M5
Default 02-05-2018, 01:17 AM
Thanks guys, i take it 0-30 is just too thin?
Car: 13 M5 DCT
Default 02-05-2018, 06:01 PM
Ya....car calls for 5w30 or 5w40 in warmer climates
Car: 2010 535
Default 02-13-2018, 12:07 AM
why semi synthetic?
M335's Avatar
Car: 2011 E90 335i
Default 02-14-2018, 07:59 AM
Originally Posted by 535_BiTurbo
why semi synthetic?
Because race kar
Car: vw passat
Default oil - 02-16-2018, 04:03 AM
which total? i used to only run the quartz 9000 5/40 for like 4 years straight and my blackstones came out good, switched over to the 0/40 castrol from wally world since it was more accessible and a few bucks cheaper for the 5 gallon jugs.
Car: 13 M5 DCT
Default 02-16-2018, 08:24 AM
Quartz 9000 Energy 5W40 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
My ex Porsche mechanic used to work for a race team....and he tried all oils including Mobil.....then the ELF rep asked him to try their oil and it was the first time after engine teardown that the engine had minimal wear......I started using ELF oil then it was renamed to TOTAL.....oil analysis also showed better results that other brands..
I use this one in the Lambo
Car: vw passat
Default 02-16-2018, 10:21 PM
my mechanic used to race in nasa and put me on to that elf in 2006 and would give it to me for like 22$ and then like you said it was renamed to total and used that exact one for a long time, bitog seemed to think the new castrol titanium was better. i havent used the total for a probably 2 years like you said both give me good oil analysis. i just change every 3k and im good.
