Default M4 JB4+BEF+E85 Dyno Testing - 01-22-2018, 06:34 PM
Had a chance to spend a little time on the dyno today with our development M4. Driven by Payam@BMS it's a 2015 manual trans with around 80k miles. Bone stock except for a JB4, BMS intake, and our development back end flash map loaded via MHD. JB4 is using latest v1.8.1 firmware with the higher speed data logging.
Testing today was done on straight E85 so we could test the limits of the factory fuel system. Some quick notes:
1) The high pressure pump keeps up with straight E85 relatively well at this power level, but pressure starts to nose off around 6000rpm at max boost.
2) Low pressure held fine even under higher RPM higher fuel demand.
3) The factory turbos still run out of steam at higher RPM. Exhaust modifications might extend the usable range slightly.
4) We ran the tuning with relatively conservative ignition advance peaking around 9 degrees. A couple timing drops here and there but mostly due to the back to back runs and working the turbo beyond its efficiency range at higher rpm. I meant to try running higher advance at higher RPM where the turbos drop off, but didn't have time to test it today. Next time.
5) Just for kicks I did a run on existing additive map1 and map2 for comparison. With the BEF loaded we'll be reprogramming all the JB4 map options so you retain a similarly wide range of power delivery options at your fingertips.
Lots more to come...
Default 01-22-2018, 09:08 PM
This car is such a blast to drive around. Gobs of torque down low, it just gets out super quick. Can't wait to see what it will do once we really turn things up
Peter @ Pure's Avatar
Car: F20 M135i
Default 01-23-2018, 01:10 AM
I still find it sad to see power dip so fast after 5k rpm...
But there are solutions for that.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
luchocamp's Avatar
Default 01-23-2018, 07:46 AM
great guys ... S55 stock uff
A90 Supra Full Weight No Nitrous 10.78@133mph
BMW M4 stay tuned
Drag Track online set up on instagram @luchocampusano YouTube Lucho Campusano
dragy dragy is offline
Car: BMW 320i
Default 01-23-2018, 09:59 AM
Can't wait to see 60-130 and 1/4 times on Dragy.
Car: 335i, 2009
Default 01-23-2018, 12:23 PM
What an awesome torque curve. Totally agree with the Pure guy, even a mild upgrade could help flatten out the end of that power curve. I can just imagine a larger 600+ torque curve. =)
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Default 01-23-2018, 12:39 PM
Yes definitely the turbos holding it back. We can make a ton more torque down low but figured what's the point. As is right now the shift point of around 5500rpm would give the best racing results.
Car: 335i, 2009
Default 01-23-2018, 02:47 PM
Yes, I agree. A big surge of torque is not the best way to get track times, but it sure would be fun to drive, to some extent. It would be pleasantly driveable and trackable if the curve is flattened .. My next platform is likely to be the S55, depending on how long I'll stick out the N54, which has been going amazing over the last several years.
BMS Stage 1
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 01-24-2018, 10:28 AM
Thanks for sharing on this, Terry - please let us know updates. Exclited about the apparent strength of the stock fuel system, esp compared to my N54.
Do you feel this represents maximum peak power on the stock turbos? Or might there be more to gain in mid range to 5500?
Same here ... FBO + Tune M3 that hangs with single turbo N54 #'s? yes please, especially for a DD with all dat torque.
Default 01-24-2018, 08:26 PM
Timing was relatively low so I'm sure we can squeeze another 15whp out of it in a "dyno glory" scenario. But practically speaking I think 550whp is about where you should expect the factory turbos to peak at.
Steve @ PURE's Avatar
Steve @ PURE Steve @ PURE is offline
Car: F80M3
Default 01-25-2018, 01:00 PM
Sweet!!
Z4 GT3 BodyKit | Pure Turbos | Fuel It | LiteSpeed Racing Wheels | GT250 APR Performance Wing | Studio RSR Rollbar | GTHAUS Meisterschaft turbo back | DinMann CF parts | RECARO CS Sportster | JB4 | CSF Cooling System | Full Custom interior | 2M AutoWerks | Viral vinyl werks | Toyo Tires | Ceramic Pro | Oneighty NYC | DOC Race | M3/M4 BBK | SSP Upgraded Clutches | Custom Coilovers with Hydraulift System By Status Gruppe |
MarinoB's Avatar
MarinoB MarinoB is offline
Default 01-26-2018, 08:19 AM
Will there be BEF maps for non E85...for example, exhaust modifications & 93 octane?
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
Default 01-26-2018, 10:00 AM
Yes, we have a back end flash map for pump gas.
24k-m4 24k-m4 is offline
Car: 2016 AY m4
Default 01-29-2018, 07:37 AM
hey terry im really interesting in getting a e85 BEF please need more info ,thanks
Default 01-29-2018, 09:18 AM
Directions here: http://www.n54tech.com/forums/showthread.php?t=51166
DLSJ5 DLSJ5 is offline
Car: E92 M3
Default 01-30-2018, 01:36 PM
Great stuff guys, congrats Payam!
T, do you think there's any chance with Pure Turbos that we can run E85, with 100% Meth on the stock fuel system?
16 F82 M4 ZCP - DCT - JB4 - Meth - 1/2 Mile 161MPH
08 E92 M3 - DCT - Built Motor - ESS VT3-750 SC
710 WHP/495 WTQ STD CF @ 14.4psi
6.1s 60-130MPH (Drag Strip)
174.12 MPH Shift-S3ctor Standing 1/2 Mile - E9X WR
Default 01-30-2018, 02:10 PM
Thanks Drew!!
I think he was testing that on Jasons M3, no idea how far he got though.
