(#51)
OzBMR OzBMR is offline
Car: BMW M140i
Default 11.8@118mph Stage 1 with Hoosier DR2 - 07-10-2019, 06:52 PM
I went to the drag strip last night to test the Hoosier DR2 and modified launch control with xHP Stage 3.
There were over 150 cars and I only managed to get 2 runs over 3 hours The track was also poorly prepped and no sticky surface.
Run 1 Sport+, shifter to the left, small burnout, Hoosiers were at 18 PSI cold, launch control activated at the line and my logs tell me that stationary boost built to 8.7 PSI and on launch 1st gear immediately went to 22 PSI, so there was maybe too much boost and wheel spin for the track, even with the drag radials. The 60 ft time was 1.90 seconds and quarter mile was 11.854@117.62mph
Run 2 I did a bigger burnout after re-adjusting tyre pressure down from 19.5 to 18.0 PSI. As I manually changed into 2nd gear during the burnout to try to get more heat into the tryes the car then shifted into fully manual mode. Launch control flag did not show, boost only built to 3.33 PSI at the line and 1st gear boost only got to 16 PSI. Less wheel spin provided a faster 60ft time of 1.867 seconds, but I lost time as I forgot to shift manually into 2nd and hit the limiter for a little while, so the E.T was 11.89@118.52mph.
With better track prep, 1.7 second 60ft and a clean run I think 11.4@119mph is possible. I have some video of the runs that I may post up soon.
Australian 2016 M140i LCI Mineral Grey ZF8 Auto
11.51@121.94MPH with 1.77 sec 60ft
MHD 95/102 OTS DME Tune with E30 fuel blend
xHP Gearbox Tune
Car: BMW M140i
Default 11.8 quarter runs YouTube Link - 07-11-2019, 05:21 AM
Video of the runs from last night BMW M140i 11.8@118mph July 2019 Stage 1 DME Tune + xHP Stage 3 Gearbox Tune + Hoosier DR2 - YouTube
xHP Gearbox Tune
CntryClub007's Avatar
CntryClub007 CntryClub007 is offline
Car: F30 340i / E70 X5-35i
Default 07-14-2019, 05:31 AM
11.48 @ 119 with a 2000’ DA. Once that DA comes down, think we can muster better!
BMW 340i | B58 | BMS JB4 + AWE Exhaust + Methanol on Vimeo
| 2016 BMW 340i | M-Sport |
| CG Catted + AWE | BMS Intake | FTP Turbo Inlet + CP | JB4 + MHD BEF | XHP Stage 3 | BMS Meth Kit | VP M1
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default Good and Bad news - 07-22-2019, 02:42 AM
First thing, my car is running great at the moment and managed to run a 11.3777 @ 119.8. I went to the BMW show @ Santa Pod UK yesterday and put some good times in, My Quaife and Trans flash make such a difference to the times.
The downside to the day were the organisers disqualified me from the RWYB race as i booked my car in the wrong class, I booked my car in as i always do as a 1 series F21 Chassis 140i. But low and behold they now class all BMW's with an "M" badge as an "M" series Car, so now they see my car as a BMW M1, i so wished my car was an M1.
So guys and girls in the UK if you have a BMW with an "M" badge on the car you now have a "M" series car in the eyes of Sant Pod ?. And all the cars i see in my "A" Series Class have now been disqualified
There were lots of 140i,135i and others with the Jb4 i was surprised at how many had it installed.
Car: BMW M140i
Default 07-22-2019, 02:18 PM
Well done BazBar. Quickest B58 time I've seen so far. I think Peter@Pure's car will be into the 10's with a 60ft time like yours. 1.71 is great, are they Toyo R888 on the rears? Still going 2nd gear at launch, or using 1st now that you have more grip with the Quaiffe and tyres?
xHP Gearbox Tune
BazBar's Avatar
Default 07-23-2019, 08:44 AM
Thanks, yes, New 888r super soft. As you can see from the time slip i ran early in the morning as i wanted to run in the cool, plus they just prepped the track so it was sticky, Pete's car will have his turbo on not a stock Turbo.
Setup: Terry's MHD Meth Race Map + Jb4 Map7 60 add.
Yes, Still 2nd gear launch from 3k RPM, What surprised me, was i changed gear so early from the 2nd to the 3rd gear @ 5.5k RPM this seemed to help the time somehow. It shocked me at how fast the car was going so i thought i'd better change gear....was that the trick to the good time ?.
I normally strip my interior totally out also but i only took the back seats out this time, even had the big heavy front seats in.
The Quaife and the xHD on the race Trans flash with the 888Rs has made such a difference.
A note to all UK BMW show RWYB racers, I have just received a email from the Events Organiser @ Santa Pod raceway UK, regarding classing all M Sport, M Performance, M Power cars. If you have that type of car you will have to enter it into the "M " series class next year, so you guys with the 116 i M Sport will be in the same class as the M2/3/4/5/6 and so on. Good Luck.
Car: BMW M140i
Default 07-24-2019, 05:14 PM
Nice. I thought Pete mentioned at post #44 that they did 126mph with the stock turbo on a E30/meth custom map?
Ridiculous about the classes for the RWYB.
xHP Gearbox Tune
Car: BMW M140i
Default 10-26-2019, 05:40 AM
Good night at the track tonight and first test of the new MHD 95/102 OTS map combined with xHP. Hoosier drag radials on the rear as this is a rear drive only with standard open diff.
It's getting pretty warm here in Brisbane Australia 30 degrees C when the gates opened and DA of 2417ft when I was in the staging lanes for the first run.
I had three runs:
11.689@121.14mph with a 1.873 60ft (second gear launch)
11.701@121.31mph with a 1.920 60 ft (first gear launch, too much wheel spin)
11.519@121.94mph with a 1.773 60ft (second gear launch)
DA had dropped to about 1674ft by the 3rd run.
I used E30 blend fuel, only mechanical mods to the car - delete small front muffler and permanently opened the rear muffler flap and disconnected. Otherwise stock exhaust including ******** with ***. No weight reduction, all seats in the car etc.
Here's a time slip of the best run
xHP Gearbox Tune
Mihail Mihail is offline
Car: Bmw M140i xdrive
Default M140IX - 10-29-2019, 05:15 AM
BMW M140I X-drive 8AT
mhd stage2 98ron , Xhp stage3, JB4 map 3. No met. Stok turbo
best time
0-100 - 3,61c
100-200 - 8,72c
1/4 mile - 11,47c
Temp 19C
ordinary road
Tires stok Pilot Super Sport
I am in Russia, the city of Vladivostok
Car: BMW M140i
Default 11-05-2019, 02:04 AM
Videos of the runs including the 11.5@121MPH
BMW M140i 11.5@121mph Quarter Mile Drag Race vs Mustang and Stage 2 Mk7 Golf R - YouTube
xHP Gearbox Tune
