PHAILUR PHAILUR is offline
Car: 335i n54
Default Need to have logs reviewed for jb4 fine tune - 04-28-2017, 10:01 AM
Getting crazy misfire in any map other than 5 when running full e85...
What is needed (gear, WOT...rpm range?) and on what map should I record the log?
rcpro88 rcpro88 is offline
Car: 535i
Default 04-28-2017, 02:18 PM
Gear: 3rd
RPM: 3k - 6.8k
WOT
running full E85 - have BEF?
watch hpfp pressure (want at least 1500 psi)
watch lpfp pressure (don't let drop below 60)
watch AFR (anything above 15 is too high, 11-13 is approx range)
DON'T buy VRSF D.Ps or inlets! I have them and their fitment sucks! Running their FMIC with no issues.
HKS BOV, BMS DCI, BMS Meth Kit
JB4 w/MHD-BMS E85 Backend Flash
Custom Map 6 21.5 psi (E70 mix)
Walbro 450 LPFP - 4 Bar TMAP Sensor - Muff Delete
SAT Transmission Flash/retrofit (Thanks to Wedge!)
AD Engineering Oil thermostat - Rob Beck PCV Valve
Installed all the parts myself.
Car: 335i n54
Default 04-28-2017, 06:09 PM
Sorry, what's BEF?
Car: 335i n54
Default 04-28-2017, 06:11 PM
Also, does it matter what map I'm in when I record the log?
Car: 535i
Default 04-28-2017, 10:10 PM
BEF is a backend flash. It mixes with the JB4 like peanut butter and jelly. AKA really good stuff.
If you are running 100% E85, you need this. Running anything over E30 without a backend flash will have some problems. For high E85, use the E85 map.
You can be in any map you want. Just start the log when pedal > 90%. Refer to rpm range.
If using map 5, make sure to do three 3rd gear pulls from 3k-6.8k, THEN log pulls from there on. Takes 3 pulls for JB4 to auto-learn/optimize in map 5.
Car: 335i n54
Default 04-28-2017, 10:15 PM
Ah got it. My installer did add additional tuning to the car after the instal but I haven't had time to get it dialed in past that night since I only had 91 in the tank we really couldn't do much and it was late. I'm pretty sure there is a BEF in there.
I will go ahead and try and get some pulls in sooner than later so I have an idea why I'm still getting misfire.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 04-28-2017, 10:45 PM
Here's a video that'll help you learn how to properly log.
https://youtu.be/vWJPJk_pSbk
Mods: Stock for now
Car: 335i n54
Default 04-28-2017, 10:46 PM
Thanks Lowon! I'll check it out. This part was stressing me out
'09 e92 jet black 6sMT
VRSF ** • VRSF Charge pipe• VRSF 7.5" intercooler• VRSF2" inlets• VRSF DCI•aFe intake scoops•HKS BOV•RB pcv valve•BMS Jb4 g5 w/ Bluetooth •BMS Oil catch can•BMS Clutch valve•NGK plugs•Bosch coils• 450lph Walbro for e85•Master Clutch lightened flywheel-ACT 6 puck clutch•turbo back straight pipe w/ all deleted
Car: 335i n54
Default 04-28-2017, 10:51 PM
Ok yea I have the Bluetooth so I assume when recording data it will act the same as laptop.
My biggest question is... once I post up the .csv files, there will obviously be changes that need to be made. How can I adjust and create these changes? Can that be done also through the jb4 Bluetooth app?
Lowon's Avatar
Car: Bmw M2
Default 04-28-2017, 11:04 PM
BMS support team will offer you suggestions on what changes that will be required, if any are required at all, and they'll tell you what to do. If changes are required you can do them through the bluetooth app or via a computer and USB cable (I personally prefer this method).
This is a pretty good thread to read and learn about tuning via JB4.
http://www.n54tech.com/forums/showthread.php?t=21269
~Lowon
Mods: Stock for now
