BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default First logs for my UK 2017 M140i - 04-02-2017, 04:56 AM
Can someone please have a look at the log files. These are the first runs after installing the Jb4 a couple of day ago, whats causing the throttle closure or is this normal, is the timing dropping also. Fuel is Shell V Power.
Spec: Jb4 & Intake only, Down-pipe going on next week
Thanks in advance.
Thisisdudewhoru Thisisdudewhoru is offline
OEM+
Car: '16 340i
Default 04-02-2017, 05:08 PM
Interesting. I've got same mods as you. I suggest you post these in the throttle closure thread as well..
Also first log doesn't look like you went full throttle
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake
Default 04-02-2017, 08:13 PM
These logs are normal. When you install the ** you may start to get aggressive throttle closure.. Note, the throttle blade moving a little is not closure. If it stays at 60% almost the entire run then you have a problem. And to resolve that you just add in the EWG connector and special firmware.
OEM+
Car: '16 340i
Default 04-03-2017, 05:13 AM
So sounds we've got the throttle closure solved now?
I haven't had it yet but I'll have ******** soon
BazBar's Avatar
Default 04-03-2017, 05:27 AM
Thanks for all the replies, I was a little hesitant on all the runs as the car just didn't feel right, cant put my finger on it, maybe because its my new baby & didn't want to hurt her . Terry, I have the EWG on order and will install as soon as I get it, where do I get the special firmware from, will I be able to run the Meth injection with this firmware also. Will I get the slight throttle blip running Map1 & the ********* or only when I run Map2 or Meth Map ?.
Also when you ship out the new Jb4 does it come with the flat OBDII connector cable or the round cable. Being a right-hand drive a longer cable would have helped a lot on the install.
Sorry about all the questions.
BazBar's Avatar
Default Special Firmware - 04-04-2017, 02:51 AM
Where do I get this special Firmware Terry is talking about ?
BazBar's Avatar
Default 04-06-2017, 01:41 AM
I presume from all the reply's to my last post its not worth fitting the down ***** yet until some new firmware is available ?. Last thing i want is a car not as good as it is now .
N54_liam N54_liam is offline
Car: 135i e82 n54
Default 04-06-2017, 08:01 AM
I am also waiting for the firmware to be released and see some results without Throttle closures before getting a ********.
Interested to see how you get on with meth though that is definitely in the plans.
I almost bought your old 135i a few years ago didn't know when I looked at it until after I had bought mine and saw it on youtube as the same as one I test drove.
Current: M140i
Previous: N54 - Forge BOV - Forge Chargepipe - Airtec Intercooler - DCI - VRSF - JB4 - LCA
Default 04-06-2017, 09:11 AM
Once you have the EWG connector just email in as we've not published B58 EWG control firmware yet.
