Got Boost?'s Avatar
Got Boost? Got Boost? is offline
*Rollin 3rd*
Car: E93 335i
Default JB4 Rev 3 Connect questions - 03-25-2017, 04:47 PM
I have the Jb4 kit and rev 3 bluetooth kit
My first concern is when i tap the boost gauge on my device twice it gives me max boost readings that are pretty high 19-21 psi and are not consistent with my standard line to BOV boost gauge. Boost spike
Second and this one took me forever to notice. Occasionally i would get hazards flashing once not related to my shift light (set to 6k). When I did get a chance to look at my jb4 gauges when it happens i notice my oil temp would spike really high for a fraction of a second. No adverse side effects
Other than that the jb4 together with the connect kit is fantastic
Any help would me most appreciated
Cheers
inevitab1e's Avatar
Car: 2013 N55 135is
Default 03-25-2017, 05:47 PM
Cheers
The hazards could be your engine warming to 160 or going to limp? Those are the only times I've seen it outside shift light.
Post some datalogs of the problem. The oil temp is probably set to boost or something else once you pass 50% throttle.
2013 E82 135is N55 JB4-BEF FBO
Got Boost?'s Avatar
*Rollin 3rd*
Car: E93 335i
Default 03-25-2017, 10:11 PM
First thank you for your reponse
I ruled out warm up as well. Morning routine allows for a good warm up before driving off. The car isn't going into limp mode, no half engine light or SEL. I did however have a code show up among my ** detection codes forgot the number but it was relating to oil condition sensor. I could start there as it isn't that hard or costly of a job...car does have 107k miles and who knows if POs even thought about replacing.
Something worth mentioning also the oil temp gauge spike only shows its self on the app but the oil temp on the dash does not react/spike the same way.
inevitab1e's Avatar
Car: 2013 N55 135is
Default 03-26-2017, 06:35 AM
Maybe the blinkers flash every time a code comes up? The app may just be acting funny. I'd create a datalog so you can see what the oil temp is doing.
Got Boost?'s Avatar
*Rollin 3rd*
Car: E93 335i
Default 03-26-2017, 08:19 AM
That was one of my first thoughts since I get the ********* codes BUT even when I have the codes auto clearing through JB4 I still get the spike along with hazards flash.
Not a bad idea but the log would be pretty big since these spikes don't happen often and I would need to leave the device constantly logging. It wont hurt to try though ill give it a shot
Default 03-27-2017, 05:53 PM
Blinkers flash for 1 of 3 reasons. Up to temp, running lean, shift light. Have you checked to see what menu 3 is set to?
