(#51)
hcorrea hcorrea is offline
Car: Mini Cooper
Default 07-09-2015, 08:59 PM
Originally Posted by Ludrof11
Thanks. I'll wait until I order the FF connector then... Anyone know if they fit b46's? Not sure if it changed.
On the bright side, the update feels way better. Mini doesn't feel so Small anymore with this and the jcw tuning kit installed!
Also hcorrea, you are using dash command right? Do you find it to be pretty accurate? I've been using it and my numbers have been all over... Don't know if that's because of the jcw remap maybe?
explain what would that JWC tuning kit and the JWC remap? your car is a F56 B48?
2015 MCS F56 B48 Down Pipe BMS JB4 FF
Ludrof11 Ludrof11 is offline
Car: F56
Default 07-12-2015, 04:57 PM
What do you want to know? The tuning kit is just the exhaust and remap that puts it to 208. I have a b46
Default 07-12-2015, 08:28 PM
Looking to do some more development on the B46 models, specifically ones that routinely throw a CEL if you leave the brown/MAP connector installed. If so drop me an email and we can test out a few new things.
Car: F56
Default 07-13-2015, 04:02 AM
Terry, so far I only ran into CELs when I first installed it. Since then I haven't had anything show up and I have both connected. Even with that firmware update I haven't had any issues. Knock on wood!
Car: Mini Cooper
Default 07-19-2015, 03:18 AM
Remap what? Only exahaust...
Car: F56
Default 07-19-2015, 12:07 PM
Honestly, I am not to sure. I never asked what it remaps. My opinion would be only exhaust. I used dash command when I got it back from the dealer and all the stats were the same.(boost, a/f ratio, timing was slightly up). I did hear however that with the remap it's the same as the BMS tune; you have to put some miles on it. I however put the BMS back on as soon as I got home haha. I think it's worth the money tho, especially since it's factory.
Could you tell a "huge" difference when you updated the firmware on the BMS? I updated it the day I got back from the dealer for the remap. I'm curious to see if the power gains are from the remap or if it's mainly the BMS. I don't want to switch to map 0 to see and then have to put miles back on map 1 for full effect. Or does that not matter?
Default 07-21-2015, 07:07 PM
Adaption between map 0 and map 1 isn't that big of a deal. A few pulls.
Car: Mini Cooper
Default 08-05-2015, 07:34 PM
updating ..... increased the pressure to +7.5 psi. I did some logs and everything seems normal. the car is getting stronger. I made a suspension alignment to see if the keep walking straight.
fean07 fean07 is offline
Car: Mini f56 JCW
Default 08-10-2015, 03:23 PM
Installed stage 1, originally also with ff cable , but got error drivetrain malfunction straight away.
Unplugged ff and error disappeared . Test drove the car with basic settings and is great already .
I'm waiting for data cable to push a little more and collect some logs
Waiting for some updates from terry regarding ff cable. He told me via mail to leave it unplugged for now
perhaps the setting fuel open loop has to be changed if the ff is connected even though I'm using regular fuel ?
thanks
Car: Mini Cooper
Default 08-10-2015, 09:01 PM
Use open loop 50 with ff plugged. you can go beyond.
Car: Mini Cooper
Default 08-12-2015, 02:14 AM
I returned to the + 7psi. I did not like the lambda values ​​observed in logs and the car became bad to drive. I think I got where I was going.
Car: F56
Default Which map to use - 08-18-2015, 10:15 AM
Hey guys, finally ordered the FF connector. A little confused from all the posts. Do I do adjustments on map 1 or on map 3? What would be safe adjustments to start off of?
Boost safe: 5.0
Waste gate: 2
Open loop: 50
Would that be good to start with?
Default 08-19-2015, 10:16 AM
For the B48 adjustments apply to map 1. Map 3 is for meth use.
With 30-40% E85 mixed in open loop 50 and a boost safety of 5.0 should be OK.
Car: F56
Default 08-19-2015, 02:11 PM
Thank you Terry!
Car: Mini Cooper
Default 08-25-2015, 05:56 AM
Terry
how WMI can improve performance or security in your application. injecting water and methanol (ethanol) decrease the inlet temperature and also the temperature of the explosion chamber. the use of ethanol in gasoline has the same effect. in my Audi S3 I realize that at the time of injection, fueltrim shows a substantial downward correction, preserving the target lambda value. if the injection is excessive errors appear in ECU. what would be the advantage to using meth?
Car: F56
Default 08-29-2015, 03:17 PM
Giving an update for everyone
First off I can't thank Terry enough with dealing with me today haha. I have been exchanging emails with him all day trying to get the FF connector to work and it finally has. For me (B46) I was having terrible issues. When I originally plugged it in and started it up, I immediately got a drivetrain malfunction error. After talking to Terry, I actually had to do the reverse for pinning the connector(male to #20 and female to #21). After that I had a big hesitation when floored; felt like I only had half power because it kept cutting in and out. Terry advised me to put the open loop to 20 instead of 50. Everything is running smooth and pulling hard now!
B46
Boost safety: 5.0
Open loop: 20
Hope this helps anyone with a B46 that may be having the same issue, but I would still talk to Terry beforehand.
Thanks again Terry!
dyong dyong is offline
Car: MCS 2015 Hardtop
Default 09-01-2015, 06:33 PM
New FF connector installed.
Uploaded this firmware (mini_b48_1.hex). Hope this is the correct firmware.
In User Adjustable Settings, there are two waste gate settings
1) Default Wastegate Position or
2) FF / Wastegate Adaptation
Which is the correct one to set?
Many thanks for help.
Car started ok only now have to get some E85 gas.
2015 Mini Cooper S F56-B48 BMS Stage 1 FF
Car: F56
Default 09-03-2015, 01:43 PM
Curious of the same thing. I never changed my wastegate setting because I didn't know which one either?
Hcorrea, which one did you change?
Default 09-04-2015, 10:35 PM
Confirmed with Terry that it's the "Default Wastegate Position".
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 09-10-2015, 08:49 AM
Can I leave USB connected all time and use 3rd party JB4 app to change maps and settings ?!
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE **, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
Car: Bmw 328i F30
Default 09-12-2015, 10:43 AM
Hi does the B38 st. 1 use JB4 Interface, just to know if I can use 3rd party app with it ?!
Car: Mini f56 JCW
Default 09-17-2015, 09:04 PM
Why did you reverse the pin ? Plugged in the wrong position ?
I'm asking because I still get error on my jcw if I plug the ff in
B46
Boost safety: 5.0
Open loop: 20
Thanks again Terry!
Default 09-22-2015, 01:05 PM
Added B48_4 firmware to the first post. For those of you who have had codes/issues with the MAP (brown) patch installed, update the firmware, reconnect it, and evaluate it. I made a change I'm hoping will help with that situation.
mizme mizme is offline
Car: mini cooper f56
Default 09-22-2015, 02:05 PM
thank you terry i uptade firmware
Tobias1980 Tobias1980 is offline
Default 09-23-2015, 06:22 AM
Great Terry!
I have suffered from engine CEL's with error code P12A4 (sometimes) at engine start, this happened until I removed the MAP cable. Is this software applicable to B38? Any adjustments in SW necessary dependent on engine?
BR
/Tobias
