(#301)
Default 04-08-2014, 07:43 AM
Originally Posted by 07tundra
Terry what type of fluid are you going to go with?
I had redline in it before and going to stay with the same brand.
DaleM's Avatar
DaleM DaleM is offline
Band
Default 04-08-2014, 01:59 PM
Our 135i was dropped off at FFTEC this morning for top mount treatment.
Terry,
I am doing the 5862 bottom mount. It has all the hardware at a real good price.
Are all the flash and map files for the 5862 in the OP? I have seen where you were going to add some things but the only link I see is the solenoid hex file.
Vae Victis!
If you are not going Juice Box then you are going slow.
Default 04-08-2014, 02:14 PM
Nice! The single turbo flash files are different. I've added them to the first post.
DaleM's Avatar
Band
Default 04-08-2014, 02:34 PM
As I was reading this. Did you get rid of the 6466? you mentioned it but I did not see if you committed to it or not. email me if you have not and still want too
Vae Victis!
Default 04-08-2014, 05:50 PM
The 6466 kit is installed on our E92 manual trans car. It's been waiting the last few months for FFTEC to build its motor. Hopefully it comes together sooner than later.
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default Flash - 04-09-2014, 06:20 PM
Are theses flashes for a light e85 mixture? Or is it something I should use regaurdless
ak335i ak335i is offline
Default 04-09-2014, 06:22 PM
ill be home this weekend yay..
will post some logs of various fuels for fun
Default 04-09-2014, 08:08 PM
You can use a light E85 mix as long as boost isn't too high. You'll have to monitor your fuel pressure situation and go from there.
Default 04-13-2014, 02:03 PM
We've got the FFTEC 5858 bottom mount kit up and running on Ando's 335. Just did a quick spool test to see where it's at. Looks like it gets close to full target at around 3500rpm. A bit slower than the twin scroll 5862 we're using on the 135i but still much better than the 6466 on our E92!
Should have it on the dyno later this week. Going to tune it for 20psi to keep the automatic trans safe until we know how the level10 build pans out on our 135.
DaleM's Avatar
Band
Default 04-13-2014, 02:11 PM
T,
is that spool difference due to the efficiency of the top mount vs the bottom? Would a top mount 5858 spool faster than a TM5862?
Vae Victis!
Default 04-13-2014, 02:13 PM
The top mount kit on the 135i is a twin scroll setup. So I think the spool difference is a result of that. The 58 bottom mount kit is no slouch and is a little cheaper and easier to install. But for my money the top mount TS kit is probably worth the extra cost.
DaleM's Avatar
Band
Default 04-13-2014, 02:18 PM
Cost of the bottom mount drove my decision. OK, the cost of the rebuild is is driving the whole project right now. The 5862, do you think 26-28 psi is max?
Vae Victis!
Default 04-13-2014, 02:19 PM
The boost is more a function of fueling. Without meth using say race gas only I think 25psi is close to the max. With meth 26-28psi should be doable in a "very aggressive" setup.
IBND335i's Avatar
IBND335i IBND335i is offline
Car: 2007 BMW 335i coupe
Default 04-13-2014, 03:03 PM
how do you think a pte 6262 cea bb turbo would work on your twin scroll top mount setup?
Default 04-13-2014, 03:04 PM
No idea on that. Check with FFTEC on hardware ideas IMHO.
DaleM's Avatar
Band
Default 04-13-2014, 03:26 PM
As Terry says, Anthony at FFtec will work through all your ideas. They have seen lots of what does and does not work.
Vae Victis!
Default 04-14-2014, 01:21 AM
I want you to drive my car around and tell me how you feel with the response and low end torque. The dyno results and logs are showing fantastic response and nice low end torque.
Default 04-14-2014, 08:15 AM
I'll drive it around a bit at shift sector to get a feel for the spool.
Blaizon Blaizon is offline
Car: 2008 E92
Default 04-14-2014, 10:44 AM
I'll let you know shortly. I went with the twinscroll 6266 Gen 2 1.0 a/r...I'm hoping for spool ~3.8k....we'll see though soon enough.
2008 Sparking Graphite 335i 6MT Coupe - JB4/FFTEC
2007 Montego Blue 335i 6AT Sedan
Default 04-14-2014, 12:48 PM
Ill be there Sunday only
Default 04-14-2014, 01:13 PM
Ah, well next time then!
135idct 135idct is offline
Default 04-15-2014, 07:40 AM
can someone tell how to power up the mac boost solenoid where to connect the wire ,there r two wires from the stock solenoid which one should i connect with
Default 04-15-2014, 08:02 AM
Just add some male contacts to it and shove them in where the OEM solenoid connected.
Default 04-15-2014, 08:40 AM
so ill tie the two wires then add the same oem male connector?
Default 04-15-2014, 09:02 AM
connect the orange wires together and the white then connct each one to the black wires of the solenoid??
