(#9051)
Default 04-10-2015, 10:05 PM
Originally Posted by hendo
Well that's not good. . If anyone has it please pm me for my email addy.
Donnie will post JB4 mobile updates soon. Until then ensure CPS values are set to 0. Those same fields became duty bias.
Bullitt1841's Avatar
Default 04-10-2015, 10:47 PM
Where can I download and earlier version firmware ?
If you don't have a windows laptop and BMS USB cable to modify the settings, you might need an older firmware. Just email Terry to be sure.
FWIW, I never drive my car hard without logging...
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 04-11-2015, 05:24 AM
Others here do that actually ? lol
shoepac11's Avatar
shoepac11 shoepac11 is offline
Car: 2008 335i E90
Default 04-11-2015, 09:46 AM
Can someone please remind me of the default values for "all map afr" and "all map cps" thanks
2008 e90 6mt
FBO/BMS meth
RB turbos
RB inlets
G5 iso
back end flash
fuel-it stg 2
Default 04-11-2015, 09:55 AM
Updated first post with that info.
huberto huberto is offline
Car: 335i e90
Default 04-12-2015, 08:32 AM
hello,
quick question:
is there the possibility to alter the settings for the cold/hot oil protection (for example to raise the hot limit a few degrees) or to disable it?
i know the risks, it is for a special purpose.
edit: oh sorry, i wanted to post this to the general thread, maybe somebody can move it? (http://www.n54tech.com/forums/showthread.php?t=10605)
Default 04-12-2015, 09:30 AM
Read the firmware notes for directions on that.
Car: 335i e90
Default 04-12-2015, 10:19 AM
ok i feared that this question was anwered before and i searched.
The only thing i found was:
FUD 100 - Use water temp in place of oil temp for warm up safety.
Well ok, if this is the only option I have let me understand it better:
does it work like the oil protection? (so ranges from 160 to 280 degrees?)
Default 04-12-2015, 11:17 AM
It goes off water temp instead. Turn on 160 degrees F water temp. Which takes much less time.
Car: 335i e90
Default 04-12-2015, 02:38 PM
ok, i'll try it - thanks so far.
but to be clear: no way in just turning the safety off?
Default 04-12-2015, 02:43 PM
That is the only option. The DME also has a built in safety based on water temps so using that method is about as aggressive as you can get.
cm50k's Avatar
cm50k cm50k is offline
Car: BMW E91 335i
Default 04-13-2015, 01:37 AM
Originally Posted by cm50k
changing values in the interface (e.g. wastegate or other settings) also changes the value in the car?
when updating the firmware some settings are still saved in the car (selected map, can flap, etc.)! so which settings changes in the car or what are the default values for the settings IN THE CAR.
nobody an answer to that?
Default 04-13-2015, 08:02 AM
The wheel control guide in the first post outlines the in dash settings.
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 04-13-2015, 08:19 AM
Terry,
guideline is missing auto-clear settings
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 04-13-2015, 09:07 AM
Originally Posted by Levan-i
Terry,
...yep...
sent you a PM
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Car: 2013 Genesis Coupe
Default 04-13-2015, 09:13 AM
Is it only me or when flashing the car the safety feature of hitting full boost before operating oil temp is disabled? Not that I ever get on it before operating temps but just noticed it in beginning, in which I feathered the throttle until I went to the 4/2 setting.
Grease Monkey's Avatar
Grease Monkey Grease Monkey is offline
Car: 335i xdrive
Default 04-13-2015, 09:35 AM
With a backend flash, you will be able to reach full boost even with cold temperatures. Just make sure to drive carefully until warmed up, since the warm-up safety feature no longer applies. This has to do with permanently altering the tune in the computer, as opposed to just having the JB4 control tuning when oil temps are ready.
'09 335 xdrive: JB4 G5 ISO - BMS Pump Flash - E30 / BMS DCI / VRSF DP / VRSF FMIC / BMS CP / BMS CDV / BMS Clutch Stop / ZHP Shift Knob
'07 Mustang GT/CS vert: Intake / Tune / Straight ***** / Strut Brace
'67 Jacobsen Tractor: Yardwork Toy...
Default 04-13-2015, 09:36 AM
With the new setup the warmup protection is in effect. Sure you are in 4/2 back end flash mode?
Beemin Beemin is offline
Car: 2007 e92 335i
Default 04-13-2015, 09:52 AM
With the pump gas flash and 91 octane I get many consistent timing drops when running anything higher than map 1 before the new firmware (13 psi). Now, in the new 4/2 mode the lowest I can run is map 1 (now 15 psi) and I'm seeing many timing drops.
Is the only way to create a less aggressive map to make a custom map 6 at 13 psi? How much boost are you guys able to run on straight 91 and the pump flash without timing drops? Thanks.
07 E92 335i 6MT- BMS JB4 G5 ISO, BMS Meth Kit with dual CM7's, MMP inlets/outlets, AMS FMIC w/ custom 3" Lower CP, N54 Tuning ***, BMS CP, MHD, PE Mod Exhaust, 4" tips, Vibrant 1792's in place of secondaries, BMS OCC, N20 TMAP, RB PCV, BMS CDV Delete, BMS Clutch Stop, BMS/Shifteck SSK, BavAuto Weighted Knob, 335d intake, 335is Engine Mounts, E46 M3 Tranny Mounts, Redline Mt90 & diff, 1/4 BOV barb, OEM Aero Lip, CSL Trunk Spoiler, Painted Side Markers, Angel Eyes, Enkreuz H10R 19in Wheels, coded.
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 04-13-2015, 10:19 AM
start a thread in the support section and post logs, we can offer specific help there without making their thread any longer
Car: 335i xdrive
Default 04-13-2015, 11:28 AM
That's great! I didn't realize it was back in effect now.
Also getting significant timing drops, more than my last setup on the previous pump flash, ISO 28_5. I need to post up some logs later tonight, even map 5 can't resolve itself.
Car: 2007 e92 335i
Default 04-13-2015, 11:31 AM
+1 Map 5 just keeps upping the boost despite timing drops.
Car: 335i xdrive
Default 04-13-2015, 12:21 PM
I'll post up my map 2 and map 5 logs tonight, curious to know if you're seeing similar problems. My plugs are maybe a couple thousand miles old (I pulled them last week and they looked fine). Injectors are newer, coils haven't been a problem for me yet. My timing drops are all over the place, not isolated to specific cylinders and parameters.
Default 04-13-2015, 01:26 PM
Timing drops alone don't indicate that something is overly aggressive. Map5 uses the average timing value across all cylinders to peek at the DME's timing adaptions.
Default 04-13-2015, 02:49 PM
Yessir I am u have been ever since the firmware change, I have to try it again, I just usually feather the pedal so I haven't really tested it, but I will let you know.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
