(#6301)
2008e90 2008e90 is offline
Car: 08 e90 sedan
Default 03-04-2013, 10:05 AM
Originally Posted by BEAR-AvHistory
Remember 91 already has 10% alcohol in it when figuring the mix.
true that
bmore135 bmore135 is offline
Car: BSM 135i
Default 03-04-2013, 09:05 PM
quick question for Terry, I have a JB3 pin out that i upgraded to the JB4 G4 board. Also currently running FBO WW meth kit... i would like to upgrade to the G5 ISO along with the 2step setting in the next month. My question is if i can still use the pinout version harness i am currently running or will i have to upgrade to the pnp version. i know there are a lot of wire changes from the older versions to the new not only in the BMW harness but also in the JBox harness. just want to figure out whats best to do so i can continue to upgrade in the future. thanks in advance for any help!
Default 03-04-2013, 09:14 PM
You can but you need to be sharp with the directions posted.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 03-04-2013, 09:49 PM
Most 91 fuels do contain 10 ethanol.... but the total octane supplied is still 91.
When they mix in ethanol they can use a lower grade of gas to come back to 91.
Default 03-04-2013, 11:40 PM
I'm running with a pinout configuration, ISO with CPS, SLD, and *** fix...no issues. Just gotta be careful and double/triple check everything! I also heat shrinked every connection...I'm a bit anal that way I guess. But no issues!
Dahwich Dahwich is offline
Car: 2008 BMW 335xi
Default CPS wire install or not - 03-06-2013, 12:28 PM
I'm about to install my G5 ISO. I have all the wires for CPS, SLD & NLS. I am mostly stock with exhaust and intake right now, but I am probably looking at Meth and/or *** soon. My question is there any benefit/drawback to installing the CPS wire. I figured it was better to have everything and install it once in case I needed it in the future.
darkstarr6 darkstarr6 is offline
Default 03-06-2013, 12:31 PM
G5_ISO_17.hex
is this the newest firmware for 2013
Default 03-06-2013, 12:34 PM
Yes, especially if you are using low octane fuel such as 91. You're also going to want to hold off on the using that NLS until you have ***...other wise your likely to ruin your stock ***.
Car: 2008 BMW 335xi
Default 03-06-2013, 12:41 PM
Thanks! I always use 94 octane, but I will hook up the CPS since I'll be in there. As for the NLS I thought it has hard on your cats if you use the 2-Step limiter, not the NLS so much.
Default 03-06-2013, 12:42 PM
or where can I find the newest firmware updates
Default 03-06-2013, 12:44 PM
Under Forced Induction section. End of first post.
grojas grojas is offline
GRZ 21
Car: BMW 335 CI 2010
Send a message via Skype™ to grojas
Default 03-06-2013, 12:53 PM
I need to download the 8/21 firmware for a 1M.
Where can i Found it ?
LuniZ74's Avatar
LuniZ74 LuniZ74 is offline
Car: 335i 2008 AT
Default 03-06-2013, 01:21 PM
Went ISO today and it's Naajs, v. Nice! Smoooth as silk.
GRZ 21
Default 03-06-2013, 01:24 PM
I wull do. tks
Default 03-06-2013, 02:07 PM
What tune are you running?
Your profile says JB3, you're asking for JB4 g4 firmware, and you're in a g5 thread
If you're running g4...you can find the firmware at the end of the first post in this thread
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Default 03-09-2013, 06:09 PM
Hi boys, I'm running G5 ISO with meth (coolingmist system X) on map3. Do I have to set FUB 1, "enable meth pump algorithm on all maps"???
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* ** - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
Default 03-09-2013, 08:13 PM
Nope.
Alex!'s Avatar
Car: 135 I N54
Default 03-09-2013, 08:21 PM
Thanks Terry
cleancutx's Avatar
cleancutx cleancutx is offline
Car: 2007 E92 335i
Send a message via AIM to cleancutx
Default 03-15-2013, 07:32 PM
Just so I could rest easy,
Does it matter if I cut the other side of the diodes instead, unlike the picture?
2002 VW GTI 1.8T (missed)
2008 Mazda MazdaSpeed3 2.3T (missed)
2007 BMW E92 335i 3.0TT (current)
6MT | ACT | VTT | BMS | MMP | MHD | Active Autowerke | VRSF | ETS | TiAL | 'BigTom' | Fuel-It
Car: 2009 335i AT
Cool 03-15-2013, 08:36 PM
You can cut either diode leg.... or both if you want to totally remove the diodes.
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 03-15-2013, 08:58 PM
I think you are better off taking them out so you don't have an accidental contact & short something out
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
FRNTHVY's Avatar
FRNTHVY FRNTHVY is offline
Car: AW135/E30M3 Junglegym
Default 03-16-2013, 05:34 AM
I went to 17 and I notice a big improvement on the part throttle driving. It is much smoother!!
335is 7DCT/JB4
Default 03-16-2013, 09:51 AM
Agree, its the pick of the litter so far.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
Default 03-16-2013, 10:56 AM
Yes I think ISO17 is pretty close to being the first ISO firmware out of BETA. There is just one little bug I've noticed. On rare occasion when the DME wakes up (when you are outside the car) I've heard the wastegates move. And they shouldn't. Has anyone noticed this? If so drop me a note as I have a patch I want you to try.
BMWpurist's Avatar
BMWpurist BMWpurist is offline
E90post reject
Car: Overpriced Econo Box
Default 03-16-2013, 02:18 PM
You must have some super hearing.
My friend died doin what He loved,Heroin.
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
