(#5301)
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 10-18-2012, 05:58 AM
what smoothing does everyone use on VD?
this is from the track the other day, map7 with meth activated but i was having flow issues....
******* **, VSRF Intercooler, DCI, G5 ISO, Backend Flash, and 100% meth flowing 60% .... fuel was e85 blend and ms105 mix
went 11.9@119 but could of went better, first time out though... it has a 11.6-7 in it for sure
e92
Default 10-18-2012, 08:16 AM
You can check the firmware date, or writing on the black box, to see which board you have. Info on the G5 is in the G5 sticky.
jlcolon2001 jlcolon2001 is offline
Car: 335i 2007
Default 10-18-2012, 08:35 AM
How do you activate meth on Map 7? I'm under the impression meth only flows on Map 3
steve.kodra steve.kodra is offline
IXLR8
Default 10-18-2012, 09:12 AM
I am guessing that on the G5 it is the same as the G4. Set FUA=1 and it will spray meth on any map. I haven't tried since I run map3 all the time.
Landman Landman is offline
Car: 07 E92
Default 10-18-2012, 10:08 AM
Has anyone noticed any deforming of the plastic housing? Wondering if I should just remove it from the get go.
RB Turbos//JB4 G5 ISO Flashed//Alpina B3 Flash//AR *********//ER FMIC//ER Chargepipe//AWE Blow Valves//AFE Sealed Intake//BMS X Meth//AST 4100's//Forgestar F14s
tofu tofu is offline
Car: 335i e92
Default 10-18-2012, 10:31 AM
nope no deforming here
i'd leave it on. wrap tape around it if it's coming apart
Car: 07 E92
Default 10-18-2012, 10:33 AM
Thanks! Haven't installed it yet, but noticed the "warning" in the first post.
Default 10-18-2012, 10:36 AM
pics of slip
e92
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 10-18-2012, 10:40 AM
Terry, for the temperature problem, we can always do a DIY ..
With this fan we can extract temperature, making a hole of the same extent in the enclosure of the g5 JB4
just look for 5v to feed.
I think it's easy and profitable
measures 20mm x 20mm x 10mm
Time is the best teacher
Too bad it kills all its pupils ....
Default 10-18-2012, 10:43 AM
The only issue with temperature is that the board is rated for a much higher temperature than the plastic enclosure is. So we probably need to remold the plastic enclosure with a higher temperature rated plastic at some point in the future. We're looking in to that now.
infinity's Avatar
metanol pawa!!
Default 10-18-2012, 10:44 AM
terry, but if we install a fan, we extract the overtemperature
Car: 07 E92
Default 10-18-2012, 11:08 AM
The fan would work for existing G5 owners, but I probably wouldn't worry about it if there haven't been "melt downs" reported. I guess, if it's found to be a problem, Terry would be happy to ship us his higher temp rated case. As a customer, I wouldn't mind paying a fee to cover shipping costs. I think Terry made the note simply because it could maybe possibly happen one day.
Car: 335i 2007
Default 10-18-2012, 02:04 PM
Thanks for the info. I didn't know that. I always run on map 3.
Which map (map 3 vs map 7 w meth activated) have higher boost targets?
IXLR8
Default 10-18-2012, 02:11 PM
Stick with map3
Default 10-18-2012, 03:58 PM
I was having meth flow issues and with race fuel I knew map 7 would be okay even without meth , so i used 7 so boost would target higher than map 3 without enough meth flow. Which was happening earlier and targeting 16 psi (still went 12.0@116.5 :-) )
New map 7 targets 18.5 and with the backend flash with right fuel is pretty darn strong but I wouldn't do it with pump and meth over 3. You're giving up some safety nets.
Map 3 is still best option and can hit higher boost even tho 18.5 is more than enough on stock turbos IMO.
e92
Default 10-18-2012, 04:16 PM
Yes the way these things go is we pay say $15k for molds and then the molds are used to spit enclosures out for $1 each. So once we make a higher temp maybe slightly larger enclosure mold anyone who wants one of those enclosures can have one for free. The downside is it's a long tedious process. But, we've been through it before, and we'll get going on it again.
Car: 335i 2007
Default 10-18-2012, 04:20 PM
Stick with map3
I'll do!
Great info, thanks
rudypoochris rudypoochris is offline
Default 10-18-2012, 08:34 PM
Mine is running pretty nicely now. Good work Terry.
Should we make some preventative perforations in the cover, if so where do you advise?
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
bobhaus bobhaus is offline
Default 10-19-2012, 04:48 AM
ok - so i hooked up my laptop again this morning to see what would happen with the whole g4/g5 firmware thing - trying to pay a bit more attention this time around.
so i opened the jb4 interface and connected - it immediately gave me a warning that the interface setting didn't match the g5 board (was set to n54). ok. checked the firmware version - said 3/xx/12/256 (still) - even though i had uploaded (succesfully it said) the g5 firmware yesterday.
went to update firmware - selected the latest g4 firmware. gave me a warning that the g5 board requires g5 firmware and do i want to override? yes :-)
uploaded firmware succesfully. disconnected and reconnected. no warnings this time around and firmware is 8/21/12//0 like it ought to be.
i'll drive around later today and see what happens...
i'm hoping this is some sort of a bug with the 9/1 interface and not that i mistakenly got some pre-pre-pre-production g5 board.
Default 10-19-2012, 08:44 AM
Yes, really old firmware from March gives a false G5 warning. Just ignore it and when you upload the proper G4 firmware it won't come back.
Pe90x's Avatar
Pe90x Pe90x is offline
Car: '08 Xi
Default 10-19-2012, 12:27 PM
sup fellas anybody ever seen this code? : 2F6C exhaust fumeflap input signal
2008 XI, RB's, ECS 3"chargepipe Synapse BOV, CPE *****-less **'s, Hks SS Exhaust, Dual Cone Intake, G5 Iso, VW Meth kit, H&R sports + Bilstien, 19's!, M3 Rep-front, LED Halos,M6 shiftknob, 500HP bound!!
mzman mzman is offline
Car: 135i, 944T, M3, MRoad, Miata
Default 10-19-2012, 12:34 PM
That code is if you have unplugged the exhaust flapper, or if the exhaust flapper has failed I suppose. Should be a hidden code IIRC.
Current Euros:
'08 135i AW/CR -- FBO, E35, WW Meth 40/60 M/W
'95 M3 Blk/Blk -- Cosmos V2 intake, Borla exhaust, 3.5in MAF, 24# Inj., LTW FW, Turner chip, Euro Brakes, Koni S/A's, H&R Sport springs
'88 944 Turbo S SRose/Tan -- Too many mods - 401rwhp/429ftlb
'99 M Roadster AW/Blk -- Stock
Past Euros:
'87 944S GR/Blk -- Exhaust, Intake, throttle cam, coil-overs
Pe90x's Avatar
Car: '08 Xi
Default 10-19-2012, 01:03 PM
ok thanks, .. and im not able to open the hex files is there a particular way to access these files?
Default 10-19-2012, 01:06 PM
You don't open them, they are loaded as is to the JB4 using the JB4 interface application and USB cord.
Current Euros:
Past Euros:
RBloodscalp's Avatar
RBloodscalp RBloodscalp is offline
Power slide freak
Car: 09 E82 MT6 JB4 ST3
Default 10-19-2012, 01:39 PM
EHHH whats "CAN" active is it the thing at the tip of the oem exhaust pipe.
and what is "WOT" mean
This might be stupid question but i want to make sure what it is really
If you are not going JUICE BOX then you are going SLOW
[N54 with RB`S, E82 MT, DCI aFe,CHARGEPIPE,SINGLE BOV&FMIC ACTIVE AUTOWERKES, NST CRANK PULLEY, 3' BMS **, M PERFORMANCE EXHAUST, BMS MCV, BMS OCC, BMS 2STEP, JB4 G5 ISO board BMS Flash at 20.5psi]
