Ma2 Ma2 is offline
Car: Mini JCW F56
Default Mini JCW F56 Logs - 07-16-2019, 10:33 AM
Please find attached the log files. Mods: MST induction kit, middle and final resonator delete, NGK iridium spark plugs, fuel 100 octane, outside temperature 28 degrees celsius/82.4 degrees Fahrenheit.
Map1:
https://www.photobox.co.uk/my/photo/...d=501995226124
Map0:
https://www.photobox.co.uk/my/photo/...d=501995229433
Map2:
https://www.photobox.co.uk/my/photo/...d=501995231773
Default 07-16-2019, 04:44 PM
Change 3rd gear to 0psi, you're limiting it to stock boost here at 0.2psi.
Ma2 Ma2 is offline
Car: Mini JCW F56
Default 07-17-2019, 02:16 AM
Hi Terry,
thank you. 3rd gear settings set to 0. Please check the logs with map1.
Ma2 Ma2 is offline
Car: Mini JCW F56
Default 07-17-2019, 03:54 AM
Map 2
Ma2 Ma2 is offline
Car: Mini JCW F56
Default 07-17-2019, 03:57 AM
Comment: With the previews Firmware 14/1//5 I was driving the Mini 10 months on map 2 with no issues. Now after the update to 48/4//5 I'd lite to "tune" the JB4 module a little bit more. Please comment the Map 2 logs and let me know if I can use it and what to look at in the settings to pull out the maximum from the engine
Really thenk you in advance.
Ma2 Ma2 is offline
Car: Mini JCW F56
Default 07-17-2019, 10:28 AM
Another Map 2 log and graph.
