M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default logs,issue with V2 board/firmware N63TU? - 07-06-2019, 02:53 PM
Hey Terry i got new V2 JB4 and seems like something not right when comparing Map0 and map4, arent they both suppose to be stock flash boost target?
When i did Map6 with target 15psi boost went over 21psi on bank2 while boost bank1 around 16.5psi
Map0
Map4
Map6 target 15psi
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
Default 07-07-2019, 10:55 AM
Just need the CSV files, not photos.
When you switch to a safety map throttle will close so the boost reading will be falsely high. Big issue here is bank2 boost is off the scale. Even your map0 is over boosting a bit. I'd start by disabling WG control all together by setting FF = 0 and logging map1.
M335's Avatar
Car: 2011 E90 335i
Default 07-07-2019, 04:02 PM
Here is Map1 with WG disable and FF = 0
Seems like Boost2 is overboosting over 21.2psi & it kicking into Map4
Default 07-07-2019, 04:36 PM
Do the turbos use factory vacuum wastegates?
Set duty bias all to 0 next and log map1. If it still does it, put BCM connections to stock and log map1.
M335's Avatar
Car: 2011 E90 335i
Default 07-07-2019, 06:58 PM
Yes oem original WG, I did reload firmware and set duty bias to 0 and after few pulls seems like pulling harder and still staying on Map1
Default 07-07-2019, 07:02 PM
Yes this looks OK. It seems any BCM movement is causing the bank variance issue.
It's running WMI? Flash?
M335's Avatar
Car: 2011 E90 335i
Default 07-07-2019, 07:14 PM
Itís on stock oem factory flash with BMS WMI but I believe itís not spraying on Map1
Default 07-07-2019, 07:20 PM
OK let's go back to the WMI map then map8 on say a 40 additive and log that.
M335's Avatar
Car: 2011 E90 335i
Default 07-07-2019, 07:39 PM
Something going on with Boost2, on second log I did from 4th gear and it went in to Map4, look how close boost1 to boost2 after it shifts in to 5th gear(Map4)
File Type: csv 2019-07-07 22_52_02_Map-8 4th gear went on Map4 2.csv (13.6 KB, 81 views)
Default 07-07-2019, 09:29 PM
Set PID gain to 0 also.
M335's Avatar
Car: 2011 E90 335i
Default 07-07-2019, 10:13 PM
Still over the target. My external digital boost gauge showing no more than 12-14psi, could be a Map sensors calibration off on jb4 firmware?
Default 07-08-2019, 08:39 AM
Might be WGs adjusted too tightly on the turbos, to the point that you need to flash the car to manually get WGDC down. The BCM can only add WGDC not subtract it on this platform.
You can go up to a 60 additive next.
On boost JB4 calibration seems correct. Where is the external gauge tapped on the manifold?
M335's Avatar
Car: 2011 E90 335i
Default 07-08-2019, 08:51 AM
ill try to loosing up a little bit the WG rods.
i got Greddy digital boost controller attached to bank2 from compessor cover, the controller is off so im just using as a boost preference.
I did extended one full turn on Boost2 WG, here’s log with additive 60
Default 07-08-2019, 02:50 PM
Get two 3.5bar TMAP sensors on the car also because we're already clipping the factory 2.5bar sensors. And make sure the car is on race gas or E30 while trying to dial it in for a little extra safety.
I still think a modest flash is a good idea to get peak timing down and maybe lean out the AFR a bit.
M335's Avatar
Car: 2011 E90 335i
Default 08-27-2019, 12:33 PM
Can you advise on my latest log
Default 08-27-2019, 08:04 PM
Some bank to bank variance here so not thrilled with the boost control.
