(#126)
spammer's Avatar
spammer spammer is offline
Car: 435i
Default 03-10-2019, 05:33 AM
Originally Posted by T_H_O_M_A_S
Ive changed the oem N55 hpfp (hdp5) with a B58 model (hdp5evo) , ive used the same map only a different hpfp , check the rail pressure differences , i'm on 93oct pumpgas for now .
for some reason i cant post the datazap links :s
Thanks Thomas! Can't wait to see more info.
Car: M135ix
Default 03-10-2019, 04:08 PM
https://daatazap.me/u/thomas/log-155...og=0&data=4-21
remove 1 letter a
my latest log with map rev 7.1 (some mhd/xhp fix )
M135i PWG , FBO , PS2 , LPFP st2 , HDP6 custom for N55 , wedge MHD mapping , XHP AT8
schmidty335i's Avatar
schmidty335i schmidty335i is offline
Car: 2012 335i 6mt
Default 03-10-2019, 04:37 PM
remove 1 letter a
damn looks good!
2012 335i Msport E92 6mt M3 gauge cluster, FBO, Jb4 G5 iso w/ff, BMS meth kit, Stg2 LPFP, Fuel-it TBI, 3.5bar, Pure turbo w/ inlet pipe and GFB DV
crobond crobond is offline
Car: M235i
Default 03-10-2019, 05:27 PM
The install is easy, you only need to cut the b58 pump, take off the mainfold and change the pumps, and finish it. When ypu know how, you dont need more than a hour. We messure some times but they are slow, because we are to much people and to much stuff in the car.
Next weekend we do some time testings with jb4 and map6.
We do some puls on map6 but i think we can ran more boost in the midrange.
We also do some puls to 270kmh on german Autobahn and we had no problems. Only when we put to much e85.
Its a very nice option this pump and i can only say, buy it, install it and run it, you will love it
Car: M235i
Default 03-10-2019, 05:33 PM
Nice to see some results , i hope to see a map update soon , so i can display
mine too , first 93oct after that e20 to e30 mix .
is it possible to have some pics of your install ? did you do things differently the way i did them ?
I install it like you, cut it same like you, only i dont need the conector, because the m2 conector is the same. E40mix was the maximum with 102 octane pump fuel frome Germany, e50 was to much
Car: F25
Default 03-10-2019, 05:52 PM
remove 1 letter a
With what fuel in that log?
F25 X3 35i M Sport | Pure Stage 2 turbo + inlet | UR de-catted thingy | VRSF Race IC | FTP full thingies | BM3 PTF tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | 50iX brakes
Car: M135ix
Default 03-10-2019, 05:56 PM
93oct
IK6SPEED IK6SPEED is offline
Car: BMW
Default 03-10-2019, 08:44 PM
remove 1 letter a
Still made less bhp than with the N55 stock pump and December log.
You made 1bhp more after the MHD/XHP tune for the B58 pump compared to the original N55 tune running the B58 Pump.
So much for how everything would get better once the car was tuned for the new pump
Congrats, you are only down 13bhp to the N55 Pump now.
Car: M135ix
Default 03-11-2019, 02:07 AM
you have some very clean logs , great work man
Car: M135ix
Default 03-11-2019, 02:24 AM
yeah install itself is pretty easy , just have to be careful when you cut the flange and make the two new holes , so debris doesnt get where it shouldnt
overhere you have to blend your e fuel yourself ,as it isnt available in a gas station , im down to pumpgas for now but later on will try with e20 or e30
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 03-11-2019, 12:29 PM
when going down the e20 route i wonder how far it can be pushed . if i can get 20-21psi on e20 im very happy with the 200usd upgrade
I think you would be octane limited before you reached that much boost. I was running 21 psi on E20 and methanol on my 335i (older HPFP) which I wouldn't have been able to do without methanol or no timing advance.
as far as the connector goes ,it has to do with production dates
If your car was built before March 2014 you may need a new plug.
It was changed around 03/2014
My production month is 3/14 on my E84 so if this pans out maybe I am lucky.
Are you still running the stock intercooler? Intake temps are getting pretty high.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
maxihari maxihari is offline
Car: 2011 335i
Default 03-11-2019, 02:21 PM
http://www.bosch.co.jp/tms2015/en/pr...DP5_EN_low.pdf
N55 vs B58 Specs
2011 N55 MSport 6spd
**, PPK, JB4 w FF, FMIC
Car: 2011 335i
Default 03-12-2019, 08:40 AM
My car's prod date is April 10
Fuel pump p/n 13517616170
I am probably SOL
How do I find out if this fits or not (plunger style vs older)
Car: 2011 e92 335i
Default 03-12-2019, 08:48 AM
I am probably SOL
The change was March of 2012. You have the N54 style HPFP. I was able to run 19 psi on E30 and 23ish psi on E20 and meth with that HPFP.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Car: M135ix
Default 03-12-2019, 08:50 AM
your p/n took me to this picture on google .
so the swap cant be done , but your pump older style hpfp
should flow more than the oem N55 plunger new style hpfp.
N54-SHI N54-SHI is offline
Default 03-12-2019, 11:06 AM
From facebook
after M2 to B58 HPFP
Jozo Crepulja :
Its enought now to max out the m2 turbo, the maximum ethanol mix was e40 on 102 octane pump gas
https://***********/u/crobond/m2-b58...log=0&data=1-4
Originally Posted by N54-SHI
From facebook
Jozo Crepulja :
https://da t a zap.me/u/crobond/m2-b58-map6?log=0&data=1-4
Car: 2011 335i
Default 03-12-2019, 11:36 AM
oh **** then
haha
you guys enjoy!
Car: BMW
Default 03-13-2019, 08:21 PM
So you don’t want to post the logs from the last 2 days proving you’ve fallen flat on your face with this?
Losing about 100bhp on 93 Octane and e20 performing even worse.....
Sad.
Car: 2007 BMW E90 335i
Default 03-13-2019, 10:02 PM
For $1100 you're better off getting port injection which can support a lot more power.
2013 135is DCT Carbon Black
Car: BMW
Default 03-13-2019, 10:26 PM
Yep.....but it would take more than $1100 all told with lines and lpfp.
431bhp on 93 Octane with FBO and Pure S2......down from 523bhp on the N55 stock HPFP is pretty sad.
E20 is even lower.
Actually I cannot fathom how they managed to kill that much power in the latest data files.
PI could take MUCH further (pushing 600) on straight E85 if so desired.
Feel sorry for those who wasted several hundred on this who didn’t read the data as I suggested.
Bee Pee Bee Pee is offline
Car: BMW F20 m135i
Default 03-13-2019, 11:54 PM
I wonder if you could put n55 HPFP5 mounting flange into b58 HPFP5evo so itís an oem PnP upgrade
F20 M135i EB AT with options - what a hoot !
Car: M135ix
Default 03-14-2019, 01:11 AM
dont think you could do that without wrecking something
Jozo Crepulja :
For upgrade turbo and ethanol it is still not enough .you will have to go the xdi route anyway . as can be shown in these logs .
93oct
https://daatazap.me/u/thomas/log-1552302396?log=1
E20
https://daatazap.me/u/thomas/log-1552511070
same engine map different fuel , its a 93oct map used for testing with e20
,if a dedicated ethanol map would make any difference idk , it was first time ive tested with E20
Car: M135ix
Default 03-14-2019, 01:14 AM
i paid only 200 usd for 2nd hand one
KevinC39 KevinC39 is offline
Car: 11 335i 6MT RWD
Default 03-14-2019, 06:42 AM
I've got a question, if you've already got 102 octane available at the pump, isn't that enough? Why bother mixing in the E85 at all or am I missing something?
E90 N55 RWD 6MT MHD Speedtech EFR7670 MFactory LSD
