(#426)
Topher_Allrad Topher_Allrad is offline
Car: 2018 F150 3.5/2019 A4 Allroad 2.0t B9
Default 01-26-2019, 10:29 AM
Terry here is a log I was able to get. 90mph came QUICK
2019 B9 Allroad- Audi Exclusive
2018 F-150 Lariat 502a 3.5/10Speed
2018 Q7 3.0T Prestige
Default 01-26-2019, 02:27 PM
Log looks clean to me here!
Rival23 Rival23 is offline
Car: e90 335
Default Explorer Sport? - 01-28-2019, 06:06 AM
Any update on when this will be available for the Explorer Sport 3.5L EcoBoost?
Default 01-28-2019, 09:40 AM
Any day now on those harnesses!!
craftwerx craftwerx is offline
Car: 2018 Ford Raptor
Default 02-02-2019, 12:13 AM
hi guys, first post here, installing my jb4 on my 2018 raptor tomorrow... Terry can you change maps on the fly? let's say you're driving on map 0 and want to change to map1 using the app?
thanks
-ken
Default 02-02-2019, 10:34 AM
Yes on the fly, no problem!
Default 02-05-2019, 02:34 PM
Just had a set of Pure 575 Hybrid's installed on our 2.7L F150. Early dyno results, still JB4 only for tuning, are exciting. Can you say Raptor killer? Will post more details soon.
Default 02-05-2019, 03:41 PM
Ohhh man, can you share with me at least!?
Am I going to pick her up?
Default 02-06-2019, 11:31 AM
Sent our 2018 F150 2.7L "baby Raptor" down to Pure Turbo a few weeks ago for hybrid turbo R&D. The result is a new set of Pure hybrid turbos called Pure 575s. They take the factory turbos, port them out, install larger upgraded wheels and parts, and the end result is a set of turbos that look factory externally but with dramatically improved performance.
It's still early days on the tuning front but the results are so impressive I wanted to share the results.
Currently tuning via the JB4 only (no JB4 back end flash map yet), Pure 575 turbos, everything else stock including the stock intake, stock exhaust, etc. Under the hood it looks like a factory truck. Fuel is 30% E85 mixed with 91 to give it a little safety margin as we flush out the tuning.
Best run on the stock turbos was 391whp. Best run on the Pure 575s, 477whp! And the best part is while the factory turbos tanked towards redline the Pure's keep going. Up next we'll be working on a free flash map meant to be used in conjunction with the JB4 to see how much further we can push these. Then we'll probably send one of our Raptors down (we have 2) for similar work.
Default 02-06-2019, 11:54 AM
I just want to tow something with this again just for fun! This thing is monster.
Mata Mata is offline
Send a message via MSN to Mata
Default 02-06-2019, 05:31 PM
does the jb4 offer the 'pedal tuner' option?
if not, can the jb4 be run along with the pedal tuner you offer? thanks
Default 02-06-2019, 05:40 PM
The JB4 does not offer the pedal tuner option, but the pedal tuner we offer is 100% compatible with our JB4. We've sold a ton already and users love them together.
yellowssm yellowssm is offline
Car: 16 BMW M4
Default 02-10-2019, 05:44 PM
Got a chance to do a run in map 7 with a E30 blend. Can you tell me how my logs look?
Also how accurate is the jb4ís 0-60 readings cause on this run it said I did a 4.875 seconds!
Default 02-10-2019, 06:06 PM
Some good news our 2011-2014 3.5L harnesses finally came in! We'll have it as a variant on our site shortly. 2015, the harness can change based on build date so if you have a 2015 F150 EcoBoost email in photos of the TMAP and MAP sensor so we can confirm what you need.
This same harness should be compatible with a few of the various other models that have been sidelined so let's get those rolling too.
Ford F150/Raptor JB4 Tuner | Burger Motorsports
Default 02-10-2019, 06:08 PM
Also how accurate is the jb4’s 0-60 readings cause on this run it said I did a 4.875 seconds!
Log looks pretty clean to me.
The 0-60 isn't perfect but it's always in the ball park. Use a dragy to to know for sure.
dragy - GPS Based Performance Meter - Free Shipping in USA
Default 02-23-2019, 10:37 AM
Making good progress on the EcoBoost Raptor/F150 Pure Hybrid turbo tuning. We're using HP Tuners for the back end flash support which I'm very familiar with from our Z06 tuning. We'll be publishing free unlocked HP Tuners maps you can use as references for both the Raptor and the 2.7L Hybrid Turbos.
Did a quick dragy run this morning in our 2018 F150 2.7L EcoBoost. Only mods are Pure Hybrid turbos, JB4, and our new back end flash map. Running a half tank of ~92 octane and ~20spi. Didn't even turn off traction control! Easy 12s in it as is. Hope to get it back on the dyno soon to crack 500whp.
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 02-27-2019, 11:35 AM
Is there going to be a group buy for the PT575, or buying these through you Terry? Would be sweet to get these in for the summer.
Default 02-27-2019, 11:42 AM
No plans for that, I'd just contact PURE directly for them.
But we'll be here to help with the tuning end!
335imofo's Avatar
Car: 335i Coupe
Default 02-27-2019, 12:30 PM
We dont have ethanol in Ontario. Lots of 94 octane though.
What would you recommend if you dont want to mess around with Ethanol?
Would you do a Back end 94 tune only? Would it be worth me adding the PT600?
Default 02-27-2019, 01:40 PM
Stock turbos? Not going to be a log of benefit to adding in the back end flash over a JB4 only but we'll quantify it on the dyno in the coming weeks.
335imofo's Avatar
Car: 335i Coupe
Default 02-27-2019, 01:53 PM
I mean, what if i purchased the PT600 kit and only ran 94 octane.
Default 02-27-2019, 03:32 PM
Ah, yes we can help with that for sure. Too early to know what the power potential will be but it's going to be a lot more than stock!
DB119 DB119 is offline
Car: 2017 Ford Raptor
Default 03-03-2019, 11:25 AM
I don’t have access to e85 within 100 miles. Is there a gas addative that would boost my 93 octane gas enough to run on map 5. (2017 Raptor Stock other than jb4 + pedal Tuner)
Default 03-03-2019, 05:06 PM
Torco or Boostane work wonders! Any MMT based octane booster works though. Lucas is another good option.
Default 03-03-2019, 06:08 PM
Copy that. Thank you Terry
