(#526)
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 11-05-2018, 07:39 AM
Hi Arthur,
Welcome to the forum. Firstly it looks like you may have flashed the b48/b58 firmware as opposed to the mini firmware which ends in hex4. Go to the mini section and the last firmware( though old but reliable) will be under Terry’s post as I have also seen you post under b48/b58 which is the wrong section. Use the settings on that post to ensure you are back up and running and post a log of map 1 in the support section requesting a review by BMS (Terry/ Payam) are very proactive and helpful but are also very busy. Piece of advice as you are new here being patient will get you a lot of support!
Link to where you can find mini section is here and under the post from Terry first post you will find the file ending in 4.hex. I have assumed the engine to be b38/48 and newer mini version.
https://www.n54tech.com/forums/showthread.php?t=33083
ArturCavalcanti ArturCavalcanti is offline
Car: Mini Cooper S F55
Default 11-05-2018, 09:15 AM
Originally Posted by Jay1312
Hi Arthur,
Thanks, just found the correct file!
Car: B46 F56S
Default 11-08-2018, 02:21 AM
If I mix E85. Are flex fuel wires required on MINI Platform?
If so, what settings am I changing when I do the mix?
Default 11-11-2018, 05:13 PM
Log and evaluate it, the fuel pressure wire may be required. Open loop would be set to 60 if equipped.
Car: B46 F56S
Default 11-14-2018, 03:09 AM
Got it. One thing to note, my car is equipped with a BMS Meth kit, Nozzle 7.
What would be a good starter? Map 1, FF Wires, FOL 60, Meth (50/50), 2 Gal E85 with 91?
Or is FF wires and FOL Setting not needed with the presence of meth?
Thanks in advance.
bhw3131@aol.com's Avatar
bhw3131@aol.com bhw3131@aol.com is offline
Car: M3 Competition
Default Same B48 JB4 issues - 11-18-2018, 11:32 AM
I'm having them too:
I've replaced the JB+ with my new JB4 on my 2018 X2 B48. I did the firmware update two days ago and everything seemed fine. So, yesterday morning (I''m running stage 1), after letting the car sit locked overnight, I get this error:
--104302 absolute pressure sensor, intake manifold, plausibility, caster: pressure too low
So, I cleared that code, checked the sensor connections, everything was fine, Drove the car around for the day, and again after sitting locked for a few hours, the error appeared again. I unplugged the JB4, reconnected the OE wiring, and the error didn't appear.
So, I re-installed the firmware, thinking maybe that was the problem. Now, the JB4 is stuck on Stage 4, and won't let me change it. Also, the JB4 is unresponsive using the stick control.
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 11-20-2018, 02:47 PM
Thats because the X2 menu software hasn't been developed yet. Engine will run fine on the B48 perf software but none of the steering wheel controls/ JB menus work.
I'm waiting myself.
minijcw minijcw is offline
Car: MINI F56 JCW
Default 11-29-2018, 07:46 AM
I've got a JB4 (bought earlier this year) that I used to run on my pre LCI F56 JCW. I've recently bought a new LCI JCW with what I think is the B48D engine, there's a few differences looks and layout wise between it and my old one.
Will my current JB4 be ok to plug in to this new engine or are there any issues with that?
Car: B46 F56S
Default 12-04-2018, 02:45 AM
What Boost are you guys seeing? Map 1 I get like 12-14psi on my F56S. It’s also cold as heck but seems a little low to me.
Thoughts?
Car: B46 F56S
Default 12-20-2018, 08:09 AM
What would it take to get meth flow on fuel gauge?
This would give us guys with a boost gauge the ultimate setup. Thanks
Default 12-20-2018, 06:20 PM
More MINI JB4 customers running meth! Get out there and recruit some for us!
Car: MINI F56 JCW
Cool 02-03-2019, 01:32 PM
Any word on if it plays ok with the LCI JCW, seen a post the other day on Facebook about drivetrain errors. Iím just run in so would be looking to fit it soon if all ok.
Makarios Makarios is offline
Car: 2014 Cooper S F56
Default 02-09-2019, 09:43 AM
Hey just picked up and installed the JB4 kit for my
Manual 2014 F56 Cooper S/ I got the app but it's only displaying boost and which map I am on.
Is this a common issue? I can't see any other stats like RPM, Gear, etc.
Followed all the instructions and also downloaded the firmware on the first page.
Any suggestions? I'm just wondering what I may have done wrong.
I'm thinking maybe I didn't pull the coupling for the blue wire and red wire tight enough?
Included some pictures on the JB4 and wireless kit.
EDIT: Photos don't seem to be showing (Maybe because low post count?) Links below.
Photo 1: JB4 unit
Wireless Unit
Wireless Unit 2
Thank you anyone for your help
Marcouuuuu's Avatar
Marcouuuuu Marcouuuuu is offline
Car: MINI COOPER F56 JCW
Default 02-11-2019, 08:27 PM
Where can i find the latest firmware for my jb4 beta? I have a mini f56 jcw 17 prelci. Thank you in advance.
btw, obviously im a newbie, be patient with me. :D
Car: B46 F56S
Default 02-12-2019, 09:48 AM
Photo 1: JB4 unit
Wireless Unit
Wireless Unit 2
Issue related to OBD connection. Check connector and connection to JB4.
Car: B46 F56S
Default 02-12-2019, 09:49 AM
1st page of this thread.
Marcouuuuu's Avatar
Default 02-12-2019, 11:05 AM
Thank you John, needed that confirmation. kind regards.
MINI F56 JCW 2017 - All Black
Mexico City Mexico.
Instagram: @marco_lugo_mx
netnut netnut is offline
Car: 2015 Mini Cooper Base (B38)
Default B38 Map 1 and 2 default values - 02-26-2019, 02:46 PM
Terry,
Would it be possible for you to provide all of the default values for map 1 and 2?
I am looking to use map 6 to fine tune for the pump gas in my area. It would be very helpful to have all of the exact values for each map to use a a starting point for the custom map.
Default 03-04-2019, 03:39 PM
Originally Posted by netnut
Terry,
Sure thing:
Originally Posted by Map2
psi_curve[0] = 30 '1500
psi_curve[1] = 35 '2000
psi_curve[2] = 40 '2500
psi_curve[3] = 45 '3000
psi_curve[4] = 50 '3500
psi_curve[5] = 60 '4000
psi_curve[6] = 60 '4500
psi_curve[7] = 60 '5000
psi_curve[8] = 55 '5500
psi_curve[9] = 50 '6000
psi_curve[10] = 40 '6500
psi_curve[11] = 35 '7000
Originally Posted by Map1
psi_curve[0] = 20 '1500
psi_curve[1] = 20 '2000
psi_curve[2] = 25 '2500
psi_curve[3] = 35 '3000
psi_curve[4] = 40 '3500
psi_curve[5] = 40 '4000
psi_curve[6] = 40 '4500
psi_curve[7] = 40 '5000
psi_curve[8] = 40 '5500
psi_curve[9] = 40 '6000
echacon echacon is offline
Car: Cooper S F56
Default 03-14-2019, 07:00 AM
Sure thing:
Hello Terry, is the BMW B48 the same as MINI? In thread of JB4 B48/B58 for BMW have this:
Map5: Additive map with peak of 6psi over stock added & more aggressive timing profile for higher octane fuel (experimental, 93+ octane, bolt on modifications)
Which are settings that when changed add: more aggressive timing. You can tell me these settings? Would it be possible for you to provide all of the default values? Is it possible to apply this map in the mini F56?
I have a F56 Cooper S + FBO with 104 octane and would like to replicate this setting. Thx!
Car: B46 F56S
Default 03-15-2019, 07:46 PM
Is there an easy way to set minimum RPM for methanol? Or does it stick to the meth algorithm?
chainik chainik is offline
Car: Mini Countryman JCW
Default 04-05-2019, 12:23 AM
Just to be sure - is this one compatible with 2018' Countryman JCW?
Default 04-05-2019, 08:38 AM
Sure thing:
Editing the Map6 with the android bluetooth app, the values are in PSI? is it absolute or additive?
sylv484 sylv484 is offline
Car: Mini Cooper S
Default 04-12-2019, 06:46 PM
Does the map 4 support water methanol kits? I saw under developpement?
About how many hp gains ?
Car: B46 F56S
Default 04-13-2019, 02:55 AM
Yes. Thatís what I currently use.
