(#501)
c0op3r c0op3r is offline
Car: 2017 F57
Default 08-31-2018, 10:58 AM
I got my Package today I decided to install the Bluetooth Module INSIDE the casing. There seems to be plenty of room and it is just safer and better wiring.
I did not use the tap connector (I hate those things) I soldered to the Positive wire on the board and added a connector so the module can be removed with ease.
Default 09-01-2018, 10:41 AM
You know, we've never tried that. Does it work well in car?
Car: 2017 F57
Default 09-01-2018, 11:13 AM
I will let you know in a day or so, the car is at MINI right now getting the JCW brake Kit installed. I am picking it up today, at which time I will install the box, download the app and test it all out and let you know.
Car: 2017 F57
Default 09-01-2018, 06:45 PM
OK So I got the car back with the Brake Kit installed. I installed the JB4 as shown above in the pictures, the box is mounted on the top of the battery and it works perfectly.
So putting the Bt module inside the main box works just fine on the MINI Cooper.
Car: B46 F56S
Default 09-07-2018, 04:56 AM
Is it possible to show meth flow on gas gauge instead of boost? I already have a mechanical boost gauge. Would like to see more meth options on MINI.
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 09-13-2018, 07:30 AM
Any updates for X2 yet?
Still struggling with no dash mode.
Anyone else JB their x2, or am i the only one? lol
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 09-18-2018, 09:20 PM
How much power are the tuned 2.0 putting down?
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Car: B46 F56S
Default 09-26-2018, 03:09 PM
Will EWG connector work if I order it on the MINI B46 Platform?
Default 09-28-2018, 12:56 PM
On the EWG connector for MINI, we've shipped a few but never hear back. Maybe it's too hard to reach?
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 09-29-2018, 05:42 PM
On the Grand tourer it surely is harder to use but EWG does work.
JCarter19 JCarter19 is offline
Car: Mini Cooper F56 1.5
Default 10-03-2018, 12:26 PM
Alright everyone, brand new to the whole tuning thing but I have a JB4 installed on my B38 Mini Cooper and it keeps coming up that it’s going into the safety map. Any ideas as to why? Thanks
Car: B46 F56S
Default 10-03-2018, 05:30 PM
What does the “last safety” say? Need to go on JB4 app or plug into computer.
Default 10-03-2018, 11:07 PM
The saved value for last safety in the user adjustment is 0 if that helps
Car: B46 F56S
Default 10-10-2018, 12:32 PM
If we can get meth on fuel gauge. I’d be so happy.
335imofo's Avatar
Car: 335i Coupe
Default 10-11-2018, 09:30 AM
Need some B48 X2 love.....
Default 10-11-2018, 10:15 AM
Working on a B48 X2 update! Coming up with a way to get you guys back on the BMW firmware so you get all the features. Email me a log and I can help you sort it. Terry@burgertuning.com
Car: B46 F56S
Default 10-12-2018, 08:28 AM
Let me know what you need to attempt to get BMW firmware on MINI. I'll be happy to assist/test things.
Default 10-15-2018, 08:54 AM
The MINI has a different CANbus engine so this change is specifically for the BMW X1/X2 models.
suyitwo suyitwo is offline
Car: F56 JCW
Default Check my jb4 logs please - 10-19-2018, 06:34 PM
Hello.
My car is F56(Mini 3th) JCW and no tune.
I installed Jb4 + bluetooth kit.
And I set up Map 1.
But, after logging I checked high boost. (Max boost is 23psi)
23psi is ok on stock?
And, I set up Map2,
Max boost was 25psi and changed Map4. And boost dropping
Check logs please.
I attached log files.
21_18_57 is Map 1 log file
21_30_07 is Map 2 log file
Default 10-20-2018, 06:06 AM
The JB4 is still cutting to map 4 under acceleration, gauges read 20 psi when engine is switched off also along with other things, any ideas?
Car: B46 F56S
Default 10-23-2018, 01:38 AM
What is the safety value?
Default 10-23-2018, 03:11 AM
Only value I can find for safety is in user adjustments for Map 6 which I haven’t used, it’s set to 0 along with everything else. Should I be using Map 6?
Default 10-23-2018, 05:18 AM
Everytime I change the boost safety from 0.6 up it automatically changes it back after I hit save? Car is constantly in map 4 the JB4 is practically useless
Car: B46 F56S
Default 10-23-2018, 07:56 AM
Do you use laptop or JB4 app? Should show why its bumping you to Map 4. I think its called "last safety" or something. Then will say, Boost over safety, AFR Lean, Fuel Pressure Low, Meth Low, etc...
ArturCavalcanti ArturCavalcanti is offline
Car: Mini Cooper S F55
Default Firmware and CEL. - 11-05-2018, 05:34 AM
I've just installed a JB4 in my Mini Cooper S F55. My car never turned on the CEL Light before. After the JB4, using only MAP1, everytime a have a cold start, it turns on the light, the codes are:
104302 absolute pressure sensor, intake manifold, plausibility, caster: pressure too low
101f02 Throttle Angle - Intake Manifold pressure, correlation: Limit exceeded.
What are these? anyway to solve it? thanx
Because of these errors, i tried to upgrade the firmware to the latest version, but could only find the BMW_B48_B58_OBDII_9_T7.hex in the threads. Flashed it and now the JB4 mobile app can only "see" in the app the boost and map setting, all others remain in zero.
Is there any firmware made for the minis? if so, where i can find the latest version? need to fix this!
thanx and sorry for the english.
The latest question, in Brazil the "non premium" gas, has 27.5% of Alcohol, is that enough for MAP2? need the flex fluel cable? thanx.
