Johnorl Johnorl is offline
Car: 340i
Default 340i..... 11.8@117 mph with 1k in mods - 02-14-2017, 04:30 PM
Took the 340i to the track and ran an 11.8 @ 117mph a few weeks ago with only $1,100 worth of upgrades. JB4, ER **, BMS intake and 100 octane. Trap speed was identical with 100 vs 93 octane which was odd. 93 octane ran .2 slower but not sure if the 100 octane made a difference or I just got a better launch.
Default 02-14-2017, 04:50 PM
Solid!
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 02-14-2017, 04:58 PM
Awesome time!! What wheel setup were you running and how did you launch the car?
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 02-14-2017, 05:37 PM
.1 on the 60 is .2 at the end. Looks like car ran the same yoy got better tho
2008 BMW 135i MT: Stock turbo FBO
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default 02-14-2017, 06:48 PM
Was the 12.0 on 93+e85 mix?
Default 02-14-2017, 06:55 PM
His 60' was .5 better which is more like .7-.8 off his 1/4. Im willing to bet the 100 oct gave him more tq than hp. Also his driving could be better this time.
Default 02-14-2017, 07:00 PM
Which map did you run?
Default 02-14-2017, 07:21 PM
That's awesome man! Time to add some Methanol and EWG wires to up the boost.
Default 02-14-2017, 07:25 PM
What?! No ewg wires?! No wonder 100 oct didnt do much
PLF's Avatar
PLF PLF is offline
Auto trans ?
Default 02-14-2017, 08:13 PM
I'm not to sure, I'm just assuming since no methanol.
Car: 340i
Default 02-14-2017, 09:18 PM
Thanks! RWD 245 running 22psi in the back. Michelin PSS. Deactivated the DSC
The 12.0 was 93 only, no E85
60 was only .060 quicker compare to my 12.0 on 93
Also I was running map 2 and Auto
16' 340i RWD
JB4 Map 5, ER **, BMS Intake and E30
Car: 340i
Default 02-14-2017, 09:19 PM
I plan to do meth soon. Not even sure what an EWG is, can you explain?
16' 340i RWD
Default 02-14-2017, 09:49 PM
The drop in 60' basically got you the 11.8. Were you just flooring it out the hole?
Car: 340i
Default 02-14-2017, 09:55 PM
No I feed the throttle but with the 11.8 the dsc was off while the 12.0 I was in sport +. After the track I have been messing around with the settings and turning dsc off feels like it makes a difference.
16' 340i RWD
Default 02-14-2017, 09:56 PM
So you just left it in comfort and turned dsc off?
Car: 340i
Default 02-14-2017, 10:03 PM
I put it in sport + then turn dsc off
16' 340i RWD
jpsimon jpsimon is offline
Car: 335xi coupe
Default 02-15-2017, 07:49 AM
Wow nicely done!
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Car: 340i
Default 02-16-2017, 11:34 AM
Anyone else wants to jump in and explain what the EWG wire is and and where to get it?
16' 340i RWD
Default 02-16-2017, 01:32 PM
It is used by map5, 6 ,& 7 to control the boost. I thought all recent new jb4's came with it.
luchocamp's Avatar
Default 02-17-2017, 08:01 AM
impressive
10.64 @129mph N55 World Record ~ Drag Track online set up on instagram @luchocampusano @speedmotoringsolutions ➡
Thisisdudewhoru Thisisdudewhoru is offline
OEM+
Car: '16 340i
Default 02-18-2017, 04:08 AM
Us lowly b58's don't have maps 5/6 yet. Just 7 for meth.
Default 02-18-2017, 06:50 AM
When you do
OEM+
Car: '16 340i
Default 08-06-2017, 09:13 PM
How did you get it to let you to deactivate the DSC with 22psi? At 22 psi mine throws a tpms low tire warning and basically locks me into comfort
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake
OEM+
Car: '16 340i
Default 08-06-2017, 09:15 PM
Wait... So you put it in sport plus then push the DSC button or hold it? Holding it on mine takes it out of sport plus. I've never tried to just push the button once
