05-22-2017, 04:48 PM
Don't see how either would be firmware related. But, run whatever version you prefer!
Car: 340i
05-22-2017, 05:27 PM
Terry, I'm no longer seeing values (zeroes throughtput) in my logs for Ign 2, 3, 4, and 6, since updating to the latest firmware via the app. Thoughts?
OEM+
Car: '16 340i
05-22-2017, 09:00 PM
Originally Posted by I M inluv340
As we increase power and torque numbers what are you guys thinking will be the solution for our transmission? The ZF8 speed we have is rated to 450 nm which is under 400lb/ft of torque which if you're running meth you're already over...when pure comes out with a stage 2 it's going to be a 500+ car. I think the tranny will be the weakest link.
Meh I think it'll be fine. TONS of transmissions. Like the auto in new 5.0 are rated at near the limit from factory and hold over twice.
The ZF8, albeit slightly different things for each company, has been quite a workhorse and holds alot of power in vipers, hellcats. I think we'll be fine...
Also we have the second gen. Our zf is different than the 335i ZF8. Ours is 500nm.
https://en.m.wikipedia.org/wiki/ZF_8...F_8HP_variants
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake
Car: M140i
05-22-2017, 10:06 PM
No doubt we reduce the life span of the gearbox by forcing much more power through them. But I only keep a car for 2 years or so, so the next guy can worry about that
Car: 120i
05-22-2017, 11:53 PM
This happen to me when I leave my driver door open, also it seems to happen when I unplugged the CAN bus connector accidentally while the car was on, but after connect back and restart it never happen again, so I just forgot about it until you post this, also that was on 5E FW on new FW never seen this happen.
05-23-2017, 10:38 AM
It's a FUD option now.
*B48/B58 JB4
FUD:
bit0 - Disable in dash BC button controls
bit2 - Disable oil temp warmup safety.
bit3 - User adjustable PWM meth control
bit4 - Enable alternative meth input algorithm where 0-100% flow = .5v - 4.5v input.
bit5 - Disable CANbus when boost is less than 1.5psi
bit6 - Enable cyl 2-6 timing logging (reduces CANbus sample rate on other parameters)
bit7 - Force actual boost value out MAP sensor
FutureUseA: Negative offset to dutycycle via EWG connector to correct for over boost conditions when PWM is low
Car: 08 corvette / 06 vue
05-23-2017, 12:33 PM
in what instance would you want to "Disable CANbus when boost is less than 1.5psi"?
-2016 340xi 8AT
-2008 Corvette MN6
Car: 2016 BMW 340i xDrive M- Sport
05-23-2017, 12:56 PM
Updated to the 7 and haven't had any problems like some of you were having.
2016 BMW 340i xDrive ///MSport
BMS Billet Intake ✓ | JB4 ✓ | M Performance BBK RED ✓ | ƎR ** ✓ | M Performance CF/Alcantara Interior Trim kit ✓ | Black Dual slat Kidney Grille |
Car: 440i F32
05-24-2017, 02:54 AM
Stupid question, how is FUD used? Just write Bit7 for example?
F32 440i JB4
F11 550i N63tu JB4
Car: 120i
05-24-2017, 06:53 AM
In the app write 2^(bit) into the FUD variable in:
Settings->User Adjustment->Future Use D
For example is you want to enable bits 1 and 6 to disable WG Adopt. and to enable multi cylinder log.
2^1 + 2^6 = 2 + 64 = 66
Car: 440i F32
05-24-2017, 07:25 AM
 Thank you
F32 440i JB4
F11 550i N63tu JB4
Car: BMW 440XI MPPSK
05-24-2017, 07:43 AM
What? LOL...
Your serious?
OEM+
Car: '16 340i
05-24-2017, 08:03 AM
Originally Posted by risktaker76
What? LOL...
Your serious?
No way
05-24-2017, 08:50 AM
The interface has prompts for each bit. But then those are converted to a single byte within the interface and written for backwards compatibility.
05-24-2017, 11:30 AM
I see the function now. However the descriptions of each FUD Option on the Web Page (first page of this thread) doesnt match the Application prompt.
Also noticed the heading of the prompt "Twin Turbo N54 FUD Options)"..
So, follow the prompts to designate the function OR whats in the First Page of this Forum thread?
Car: 120i
05-25-2017, 03:29 AM
Follow what is at start of this thread, they use different features for different JB4 FW, PC app refers to some other FW with different features.
The PC app tool will help you to calculate the bit to a single number as well but when I am in my car I use the phone app so I just calculate it using binary (bit) to integer (number) conversion. Yes sets the bit to 1 or on, and no sets to 0.
05-25-2017, 04:19 AM
Got it... have a degree in CS....you can imagine what I do for a living and why it's funny to me..
It's nice to know jb4 users are a tad smarter than the average grease monkey..
OEM+
Car: '16 340i
05-25-2017, 05:23 AM
Yea I'm in healthcare LOL. Don't have a clue what yall are talking about lol
I also see removal of the oil temp safety. What temp is the safety set to from factory?
What's some good settings to start map 6 at if I have intake lesscat pipedown and running torco mixed to 104 octane u.s.?
Car: Mini Cooper S 2.0 aut
05-25-2017, 08:39 AM
Sorry for the stupyd question. Can I update my JB4 with this last firmware. I have a B48 F56 MINI Cooper. Which is the safety boost to my car? Is the same 26 PSI from the BMWs?
Thanks.
Sato.
05-25-2017, 09:09 AM
No, this is a BMW thread. MINI software is posted here: http://www.n54tech.com/forums/showthread.php?t=33083
JB4 addict
Car: powered by JB4
05-25-2017, 01:27 PM
So after having new firmware in for a week or so now, with MPPSK it's very noticeable when flaps are open/closed.
2 things that I've notices so far:
- On startup, it's a variable length of time before flaps open & stay open. Sometimes 3secs, other times it's a lot longer like 10 - 20 secs. Kinda weird that it's not same time every time operation.
- Left arrow forces open but right arrow doesn't appear to be OEM operation. It's more like force flaps closed. This is more evident to me because with MPPSK in sport/sport+ it forces flaps to stay open. However, if I enable right arrow, in sport/sport+ it's very quite and doesn't keep flaps open like original OEM operation
05-25-2017, 01:54 PM
Well that sucks... If you disable the JB4 does it go back to stock operation?
JB4 addict
Car: powered by JB4
05-25-2017, 02:01 PM
good question... i'll give it a try and let you know. lol
Car: F30 340i
05-26-2017, 02:51 AM
Hey terry
How does map 6 works ?
If you can help me and other users as well
What number psi and other number we have adjust?
*B48/B58 JB4
FUD:
And how does this work ?
Thank you I am new
I just got my jb4 and the FBO
05-27-2017, 05:18 AM
Hi, I'm from Germany and drive a M240i B58. I would like to buy the jb4 soon but would like to know how much horsepower and torque I will have with map 1 .. Will only have the 400 hp and 600 nm torque that is enough for me ..
