nlrbmw nlrbmw is offline
Car: BMW M140i
Icon1 B58 M140 JB4 MAP 1 - First Logs - 03-27-2017, 01:55 PM
First logs in my B58 JB4 M140i, running 97 RON fuel - no other mods.
Any help / advice on these and for further logs is appreciated - many thanks.
Default 03-27-2017, 07:13 PM
A bit lean and trims are pretty high. Are you really running meth or just put those settings in?
Car: BMW M140i
Default 03-27-2017, 11:24 PM
No I'm not running meth. Car is stock apart from JB4 - not sure why it is populating figures for meth?
Is it worth a few more logs to see?
Thisisdudewhoru Thisisdudewhoru is offline
OEM+
Car: '16 340i
Default 03-28-2017, 02:07 AM
For whatever reason mine records meth too and I don't have meth either..
Also interesting that you're seeing 17-18lbs and I'm seeing like 15-16 at best. But then again my logs are in 1st-3rd gears
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake
Car: BMW M140i
Default 03-28-2017, 10:17 AM
Yeah very odd that it's throwing in figures for meth! Not sure why that is.
It looks like I'm running pretty lean though - I'm going to have a few more runs in 3rd and 4th to see what they show, in Map 0 and Map 1
Default 03-28-2017, 10:18 AM
If there is no meth kit installed the input voltage signal floats around. Ignore it.
Default 03-28-2017, 10:20 AM
This is pretty much par for the course for B58 tuning.
Car: BMW M140i
Default 03-28-2017, 10:22 AM
No problem Terry, will not worry about the Meth!
What do you mean by par for the course?
Car: BMW M140i
Default 03-28-2017, 01:02 PM
Few more runs this evening with logs attached - I think theses look a bit better?
Would appreciate a knowledgable eye cast over them if possible!
Default 03-28-2017, 09:46 PM
Timing looks pretty good and boost is on target so that looks good.
Basically he's saying the B58 tends to run lean and stays around lambda throughout the RPM range instead of getting richer as RPMs rise.
