Car: 2010 535
Default 03-06-2017, 02:47 PM
Originally Posted by jandraos
Terry,
Will the BMS prototype intake system fit on the Straight N63 or non TU, if so when do you expect release date?
Im waiting as well
Maza454's Avatar
Maza454 Maza454 is offline
Car: 2010 Bmw 335i sedan, sport
Default 03-17-2017, 08:17 AM
I hope it will work for a 2014 X5 50I too.... and i am in the hardcore group, so ready to test and help with the development.
Default 03-17-2017, 04:16 PM
Was able to strap it down with the BCM installed and I'm very impressed with the factory turbo performance. Made a drama free 570whp on E35 fuel. Still no meth, no exhaust mods, etc.
The only drawback with the BCM is you need to cut an OEM wire to install it. It will likely remain an optional part of the n63tu JB4 system, but if you're looking for big gains, it made a huge difference. So much so that we are maxing out the factory 2.5bar TMAP sensors. Fortunately the JB4 can run 3.5bar TMAP sensors. We'll be swapping over soon.
https://www.instagram.com/p/BRwTYHwA0-1/
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 03-17-2017, 04:38 PM
Ooh..... cutting a wire kinda knocks out the casuals and the leases. There's no other possible way to do it? Maybe a harness extension that plugs in and has the necessary wire connected where it needs to go instead of straight through?
Mike Levy
2021 M550i - On hold due to lack of allocation
2017 X3 xDrive35i
2018 Equinox LT 2.0T
Default 03-17-2017, 04:47 PM
Nope, cutting a DME wire is the only viable method. It will weed out the boys from the men. You can always reconnect it later to go back to stock as its not in a particularly visible spot.
mark5 mark5 is offline
Car: 2014 550xi
Default 03-18-2017, 07:44 AM
You could always pull the contacts out of the connector housing and insert tap connections at the DME like this:
I think this is still only for hard-core guys since extracting the old contacts and inserting new ones into the connector housing takes a some intricate work (I built a custom tool to help with it) and if you're not delicate when extracting the contacts the housing could easily be damaged, but it does eliminate the need to cut wires.
'14 550xi, BMS stage 1, meth
'17 m240xi
kokoN63TU kokoN63TU is offline
Car: 2013 bmw 750i
Default 03-18-2017, 09:01 AM
Very impressive numbers
I will happy to see the results on the road on real time
100-200 time for example
Default 03-18-2017, 10:01 AM
There is no easy way to remove the contacts from the DME connector. You could cut the wire and crimp on contacts to make a connection like about. It's just one wire we need to intercept.
turboalb's Avatar
turboalb turboalb is offline
Car: 08' 535i
Default 03-18-2017, 01:32 PM
Nice numbers guys, needs a lsd now. Then try the 1/2 mile again
08' 535i sport auto, jb4/mdh/xhp
10' x5m 11.72 1/4 record jb4 only
00' hayabusa turbo 440rwhp street bike
1/8 5.42 141mph
07 SS trailblazer tuned/flex fuel
87 fox ls1 h/c/I 4l60e
m123 m123 is offline
Car: 440i F32
Default 03-19-2017, 04:51 AM
Waiting so hard to order the jb4! Hope its available soon!
F32 440i JB4
F11 550i N63tu JB4
DrewBert DrewBert is offline
Car: Alpine White e92 335i Coupe
Default 03-19-2017, 09:51 AM
any pump gas numbers?
timberwolf timberwolf is offline
Default 03-20-2017, 11:10 AM
Wow great results! I would imagine Xdrive cars would grenade the transmission pretty fast.
Burgerized Cars:
17 X5 50i
16 Golf R
13 M5
08 135i
Check out my videos
http://www.youtube.com/gvahan#p/u
Mike_L's Avatar
Anti-Social
Default 03-21-2017, 01:10 PM
Doubt it. The 8HP70Z they use is very similar to the 8HP75Z in the X5M and the upcoming M5. It can take plenty of power and traction.
Mike Levy
2017 X3 xDrive35i
Default 03-21-2017, 02:44 PM
Time will tell!!
Burgerized Cars:
17 X5 50i
16 Golf R
13 M5
08 135i
Check out my videos
turboalb's Avatar
Car: 08' 535i
Default 03-22-2017, 04:21 PM
How'd the trims look at 19psi Terry
1/8 5.42 141mph
padrino's Avatar
padrino padrino is offline
Car: 07 335i JB3
Default 03-23-2017, 06:14 PM
Really looking forward to it.. My dealer was trying to sell me on the Dinan tune until they realized Dinan doesn't have anything yet for the 2016 750
2016 750xi
Car: 2010 535
Default 03-24-2017, 11:31 AM
When is the intake getting released?
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 03-24-2017, 12:49 PM
Intake is still few weeks away.
Car: 2010 535
Default 03-24-2017, 02:59 PM
the n63tu It makes more torque than a tuned M5 as well
Default 03-27-2017, 07:50 AM
I'd love to see this 550 run down an F10 M5!!
Burgerized Cars:
17 X5 50i
16 Golf R
13 M5
08 135i
Check out my videos
Ando @ BMS's Avatar
Car: bmw 335i
Default 03-27-2017, 11:09 AM
It's been done already.
Car: 2013 bmw 750i
Default 03-27-2017, 01:54 PM
Is the m5 stock?!
And what model year is the m5
Because from 2013 they quicker
WakeOfDeath WakeOfDeath is offline
Car: X6M & M2
Default 03-28-2017, 12:13 PM
Originally Posted by kokoN63TU
Is the m5 stock?!
Yes it was a stock m5
F90 M5 HCP STG1+ by @HCP.us
Ando @ BMS's Avatar
Car: bmw 335i
Default 03-29-2017, 01:07 AM
JB4 map 0 and BMS intake.
Default 03-29-2017, 10:53 AM
Well mission accomplished!
Great stuff guys!
Burgerized Cars:
17 X5 50i
16 Golf R
13 M5
08 135i
Check out my videos
