I M inluv340 I M inluv340 is offline
Car: BMW 340i FBO WMI
Default What is the B58 1/4 mile record?? - 09-19-2017, 05:07 PM
May go tomorrow and since I'm allwheel 8 speed with full bolt on meth and pure stage 1 thinking I may have a shot at it but don't know what I need to beat? The best I've seen is 11.8
Roki187's Avatar
Roki187 Roki187 is offline
Car: 340xi
Default 09-19-2017, 06:03 PM
I went 12.0@115 on AA tune, Er down pipe and bms intake.
Going back to the track next Friday
Default 09-19-2017, 06:22 PM
Walter it's me Ryan from our B58 group lol.
Roki187's Avatar
Car: 340xi
Default 09-19-2017, 06:29 PM
Ahh
What's going on buddy?
Johnorl Johnorl is offline
Car: 340i
Default 09-20-2017, 03:25 PM
I think it might be me. 11.85 @117mph on the old map 3. I plan to go next week on map 5 and see if I can best it before slapping some drag radials and shooting for 11.6.
16' 340i RWD
JB4 Map 5, ER **, BMS Intake and E30
Dean240 Dean240 is offline
Car: M240i
Default 09-20-2017, 10:44 PM
Good luck bud!
Let us know how it goes
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 09-21-2017, 04:15 PM
Awesome trap speed. How has map 5 been working for you? Do you also have a EWG in place?
Car: 340i
Default 09-22-2017, 10:52 AM
I love map 5, butt dynes says its a lot more power and the boost hits a lot quicker! I daily map 5 for the past couple months without any issues, can't wait to try it at the track with E30 and I do have EWG cable.
16' 340i RWD
Wickedowesix's Avatar
Car: 540i G30
Default 09-21-2017, 05:13 AM
Good luck! Log your runs and post up results.
Car: 540i G30
Default 09-23-2017, 02:18 PM
Did you ever end up making it to thw track?
Car: 340i
Default 09-25-2017, 07:50 AM
Post an update... What did it run?
16' 340i RWD
Default 09-25-2017, 08:16 AM
It was canceled, this Wednesday its open again but looks like rain
Default 09-26-2017, 06:55 AM
Looks like weather is better for tomorrow. If the track is open I'll be running!
Default 09-27-2017, 08:59 PM
I think I took it home today! 11.763 @116.8 awd 1.721 60'.
Roki187's Avatar
Car: 340xi
Default 09-30-2017, 01:53 PM
Track day results.....
16 340 xdrive zf auto
Pure s1*meth (vp m1, dual cm7s)*Er ***Ap intake (modified)*no muffler*no back seat*7/8 in the tank ~E18 mix*
Best pass 11.448@118.84 DA1113 (at the time of best pass)
Fol 70, fua 5, add 30 (best pass)
I have slips but do not know how to resize pics
The car does have more in it as there were some nasty closures through out every single pass in 3rd and 4th gears but a/f was good
I will hit the track again with ms109, bigger meth jets and meth/x98 mixture and shoot for 11.1
Car: 540i G30
Default 10-01-2017, 01:30 PM
Moving bro! Nice run. Can you post your logs
Roki187's Avatar
Car: 340xi
Default 10-01-2017, 05:36 PM
I would but I don't know how to, sorry
Car: 540i G30
Default 10-02-2017, 04:49 AM
Its simple bro. When you hit reply, hit the manage attachments under additionl options (underneath whereyou type) clixk attach files and serch for your .csv file log and attach it
Roki187's Avatar
Car: 340xi
Default 10-02-2017, 06:01 AM
That I know but I am not given the option to attach from the JB4 app, pictures only.
And all the footage I have requires resizing (which I also don’t know how to do) I’m a dinosaur in a digital age
If you want, pm me your email and I’ll send you what I have....
babyboss's Avatar
babyboss babyboss is offline
Car: 135is DCT
Default 05-26-2018, 02:55 PM
Ran 12.79 @ 178kmh with 440i mppk only ..
239 kmh on the 1km trap ..
With better launch car should do 12.5 ..
Not the fastest but 100% reliability ..
Car: 2010 535
Default 06-20-2019, 09:15 AM
12.79 @ 110mph. What was the weather temp and track DA?
Dj_quik Dj_quik is offline
Car: 2017 m240xi
Default 05-26-2018, 05:36 PM
Are you at sea level with these numbers?
Car: 540i G30
Default 05-26-2018, 08:07 PM
My 540i with the draggy app
12.06@119.76 mph
7.91@94.86 mph
2.03 60'
Jb4 map 7 40 additive, down pipe, 100% meth dual CM7, E30 (1/2 tank)
OzBMR OzBMR is offline
Car: BMW M140i
Default New Tyres - 06-13-2019, 02:21 AM
These should help with the 60ft times, Hoosier 245 x 40 x 18 drag radials. Hopefully xHP will also have the adjustable launch control they've been working on for the ZF8HP50. Should be back at the track in the next 4 weeks
Australian 2016 M140i LCI Mineral Grey ZF8 Auto
11.51@121.94MPH with 1.77 sec 60ft
MHD 95/102 OTS DME Tune with E30 fuel blend
xHP Gearbox Tune
Car: BMW M140i
Default 11.8@118mph Stage 1 with Hoosier DR2 - 07-10-2019, 06:52 PM
I went to the drag strip last night to test the Hoosier DR2 and modified launch control with xHP Stage 3.
There were over 150 cars and I only managed to get 2 runs over 3 hours The track was also poorly prepped and no sticky surface.
Run 1 Sport+, shifter to the left, small burnout, Hoosiers were at 18 PSI cold, launch control activated at the line and my logs tell me that stationary boost built to 8.7 PSI and on launch 1st gear immediately went to 22 PSI, so there was maybe too much boost and wheel spin for the track, even with the drag radials. The 60 ft time was 1.90 seconds and quarter mile was 11.854@117.62mph
Run 2 I did a bigger burnout after re-adjusting tyre pressure down from 19.5 to 18.0 PSI. As I manually changed into 2nd gear during the burnout to try to get more heat into the tryes the car then shifted into fully manual mode. Launch control flag did not show, boost only built to 3.33 PSI at the line and 1st gear boost only got to 16 PSI. Less wheel spin provided a faster 60ft time of 1.867 seconds, but I lost time as I forgot to shift manually into 2nd and hit the limiter for a little while, so the E.T was 11.89@118.52mph.
With better track prep, 1.7 second 60ft and a clean run I think 11.4@119mph is possible. I have some video of the runs that I may post up soon.
xHP Gearbox Tune
