(#51)
Default 12-27-2021, 09:57 AM
Originally Posted by Boosted_8
Despite 'not knowing how to analyze my own logs' I'm the only guy with a JB4 running 10's on the dragy leaders board...
Don't take it the wrong way. Happy to help you go even quicker and correct any issues in the JB4 firmware. Just post the CSV so we can see the relevant data and correct your analysis as needed.
Manley00 Manley00 is offline
Car: 2020 BMW M550
Default 04-05-2022, 04:14 AM
What’s with the huge timing drop? You can see it in the graph and the logs- along with the throttle dropping. What’s odd is it adds back the timing after the timing drop. At an even higher RPM. I’d imagine because that’s where the timing corrects for the boost being so hi? What is the typical timing we should be accomplishing on 93? As in, what’s the peak timing so we can adjust boost to maximize both. ��
Antec800 Antec800 is offline
Car: 340ix
Default 04-06-2022, 01:08 AM
Iím also running 10.9@127 2022 m550
Tomholland Tomholland is offline
Car: Bmw m550i
Default 04-14-2022, 10:34 PM
Is this on map 6
Car: 340ix
Default 04-15-2022, 01:55 AM
Yes on 5psi on all rpm’s with e15-20
Car: Bmw m550i
Default 04-24-2022, 10:39 AM
Yes on 5psi on all rpmís with e15-20
Did you just add 5 psi to all gears or did you adjust any other parameters? Trying to get a map 6 on mine.
Car: 340ix
Default 04-24-2022, 12:24 PM
Everything else is default, just 5 psi across all rpmís
zse8h zse8h is offline
Car: M5501
Default 06-24-2022, 02:46 AM
@Terry - What does map 1 run across all RPM ranges is is a flat 4 psi or is it a ramped up and down type situation?
2021 M550i
Bernina Grey Amber Effect
BMS Elite Intakes
GPower Axel Back High Flow Sport Silencer
Active Autowerke High Flow DwnPips
HardRace rear sway bar and Dinan lowering springs
Barracuda Racing Wheels (Inferno)
JB4 Map 1
Retired:
2009 335xi
Completely Moded out
Beat corvettes - they were pissed
phaser's Avatar
phaser phaser is offline
Car: X5 M50i
Default 06-27-2022, 06:31 AM
Good question.
Pushin' B Pushin' B is offline
Car: X5 M50i
Default 06-27-2022, 07:08 AM
Originally Posted by phaser
Good question.
My logs say flat 4 target all across
Car: M5501
Default 06-27-2022, 09:10 AM
So if you were to run map 6 with all RPM ranges set at 5 psi would map 6 be as smooth and responsive at map 1? and of course the expected 1 psi difference.
I want to test this. Has anyone else? if so what are your thoughts?
2021 M550i
BMS Elite Intakes
JB4 Map 1
Retired:
2009 335xi
Boosted_8 Boosted_8 is offline
Car: M550i
Default 06-27-2022, 10:03 AM
It's probably fine as we have the stock ECU and TCU countermeasures in place but having banana'd some rods on a Mazda many moons ago, I've tended to steer away from asking for lots of boost at lower RPM's since.
