Car: Kia Stinger GT2
Log check map 1 -
09-29-2021, 12:18 AM
Using 93 fuel i think its combined logs but one was 0-70 and the other was 40-90 WOT… am i ready for e30 and map2??
Thanks log.csv
Car: Evo VIII
09-29-2021, 10:39 AM
I would recommend going to E30, then take another log on map 1 and see how it looks. If all is good, take it to map 2
09-30-2021, 12:23 AM
@Cannon @ Bms
Threw in almost 4 gallons of e85 to top off my tank and did some runs one was 30-90 mph wot and the other was 0-70 wot putting in e85 made it feel alot better the logs look decent to me but im no expert, what do you think ready for map 2 now?
Car: 2019 AWDGT2
09-30-2021, 06:16 AM
The log looks healthy. There's some timing being pulled but it's not worth saying stay where you are at. If Map2 timing looks the same, I say your good. As long as it doesn't get worst.
09-30-2021, 11:05 AM
Originally Posted by SneakerB
@Cannon @ Bms
Looks good to me, go for it on map2. On E30 usually isn't an issue and most customers have no issue with map3 on E30.
09-30-2021, 12:56 PM
Awesome thanks for the help guys really appreciate it!!!!
10-01-2021, 12:20 AM
This one was map3 first run was 0-70 wot and the second was 30-90 wot
The logs look a little funky to me and my 0-60 went from 4.325 on map 1 to 4.5 on map3
Car: Evo VIII
10-01-2021, 08:10 AM
Please take a 3rd or 4th gear log from 2k to redline at wide open throttle with traction control off to get a better log to look at. Thanks!
10-01-2021, 08:35 AM
I think this is good enough to evaluate. A few timing corrections but nothing major, looks OK overall to me. You're not 100% gas pedal the entire run which is slowing you down a bit.
0-60 is all traction and launch, little to do with power, so not a useful measurement here.
10-04-2021, 01:47 AM
So I did a few map 4 pulls for the heck of it ( ill most likely stick with map 3 as its plenty good for me)
E30 first tun was 0-70 2nd run was 30-100
Car: Evo VIII
10-04-2021, 11:37 AM
A few minor timing corrections, but everything looks good.
10-04-2021, 05:06 PM
Awesome thank you! Is there anything i can do to fix the timing corrections?
Car: Evo VIII
10-04-2021, 09:11 PM
The corrections are pretty minor, having exactly E30 in your car will aid in balancing out the corrections.
10-05-2021, 02:07 AM
Ok thanks so im guessing the e85 meter on the app isnt accurate? I usually keep it around 27-30 !
Car: Evo VIII
10-05-2021, 10:24 AM
Hard to say, to get a true ethanol reading you will need a flex fuel kit. Your trims are pretty low, so you could run a bit more ethanol. It would be nice to have accurate ethanol readings though. I have provided a link to the flex fuel kit below.
https://burgertuning.com/products/fu...a73578cd&_ss=r
