Car: Mazda 3 Turbo Hatchback (M3TH)
10-19-2021, 09:53 PM
@Terry@BMS
Newbie question,,,,,,How do we send you the logs?
M3TH user
TransModel = A Mazda but identifies itself as a BMW
Car: 335xi sedan 6AT
10-19-2021, 11:24 PM
Terry,
Will the CX-5’s JB4 continue to utilize the connection at the intercooler, or will further development see that connection point migrate north to the MAF? I’m not a fan of the work involved getting to the passenger side of the intercooler.
Car: Mazda3 Turbo Premium Plus Hatch
10-20-2021, 08:51 AM
Originally Posted by Tric_101
Well I just blew up my rear diff today on my Mazda 3 turbo   On the Bright side looks to be a manufacturing issue with just mine not anything common.. Warranty is going to cover it..  not fun for me for the next 4 days well I wait for it to come in.
I figured the axles would’ve gone first. What were you doing when it blew out?
10-20-2021, 09:25 AM
Originally Posted by SixPackABS
@Terry@BMS
You just select them in the app and email them, or you can also email them to yourself and attach them to a post here.
Car: Mazda 3 2.5 Turbo
10-20-2021, 12:09 PM
Was not accelerating hard just cruising. Nothing to do with strength that caused it to go.. Even the strongest diff would let go if it had the same issue.. My lash was not setup right from factory or a clip was not installed causing my pinion gear to move. looks like a one off definitely not a common issue..... Covered under warranty no big deal. Got a cx-30 turbo loaner till I get my 3 back
10-20-2021, 01:12 PM
Was not accelerating hard just cruising. Nothing to do with strength that caused it to go.. Even the strongest diff would let go if it had the same issue.. My lash was not setup right from factory or a clip was not installed causing my pinion gear to move. looks like a one off... Covered under warranty no big deal. Covered under warranty no big deal. Got a cx-30 turbo loaner till I get mine back
Yeah I saw your Facebook post. I won’t say I’ve been taking it easy on mine, but I now save boosted launches for “special occasions” rather than the regular occurrence they used to be
Car: '21 Mazda 3 2.5T AWD
10-20-2021, 03:45 PM
Originally Posted by Djfourmonie
WRONG!
In modern torque tuned based turbocharged direct injected cars, it does a fuel quality test at high idle during start up.
If you started the car for the first time that say without 30% E it will not give you extra timing.
What you have to do is do 4-5 WOT blast in 3rd-4th gear.
Occasionally, I have to run 91 octane and its wack. The car drops 3-4 degrees ignition advance.
Don't get it twisted that because I have a Kia and you have a Mazda there is no correlation, there is plenty.
My car will run around 98 mph on 91 octane in the 1/4 mile.
It has run 102+ on E30 and 103+ with E and water methanol injection.
I run drag radials at the track so it should run high 13's on 91 now that I got my 60 ft times in the 1.9's.
I ran a FULL tank of E30. A week's worth of starting it up, giving the ECU ample time to "learn" fuel trims and apply additional spark, load, or boost. It did none of those things. I took regular logs. It might be best to know the product before chiming in
10-20-2021, 05:27 PM
WRONG!
Not true. The ECU works in a closed feed back loop. Keeping the engine making as much power as the manufacture map will allow, many times a second trying to advance the timing till micro knock. Then the ECU dials back the timing a bit and the loop starts over again, advancing to a maximum point that the manufacture sets or micro knock. This maximum level can be varied almost in real time for different engine temperatures, throttle positions, engine loads and others inputs. The only way to over come this is altering the inputs data to the ECU or a tune.
The ECU is monitoring many times a sec as close to real time as possible. lol not some start up check that changes timing.
10-20-2021, 07:30 PM
Not true. The ECU works in a closed feed back loop. Keeping the engine making as much power as the manufacture map will allow, many times a sec trying to advance the timing till micro knock. Then the ECU dials back the timing a bit and the loop starts over again, advancing to a maximum point that the manufacture sets. This can be varied almost in real time for different engine temperatures, throttle positions, engine loads and others inputs. The only way to over come this is altering the inputs data to the ECU or a tune.
Gotta love the big brains trying to tell you what isn't happening with our platform... because it might be with theirs. Data is king, always. Making assumptions and telling people they are WRONG... laughable at best.
10-24-2021, 10:26 AM
Not sure what you guys are arguing over but there is a high and low long term adaption range for timing, and this specific ECU also uses that adaption to modify it's boost target slightly, providing for a wide range of octane levels to be used from 87 on up to around 93 where it more or less maxes out from the factory. There is also a short term by cylinder "knock" timing correction factor blended in.
10-24-2021, 10:53 AM
Pretty much what you just said - the ECU isn't going to exceed OEM 93 map timing targets simply due to the presence of higher octane. We'd need to flash the ECU like a typical Cobb / Mazda Edit map... or whatever voodoo you can cook up with intercepting and tricking the car further.
10-24-2021, 12:30 PM
Originally Posted by jcrout7992
Terry,
We're always going to need the 2 MAP connectors... The MAF will be in addition.
10-27-2021, 11:18 AM
Just want to share these to newbies like me. This will be a great help in doing their own install. Thanks a lot @Ben_TPPH .
Mazda3 Turbo Detailed JB4 Install - YouTube
M3TH user
Car: Mazda 6
Jb4 tuning on or off -
10-27-2021, 09:37 PM
Hey guys. I’m new here so my questions may seem nooby. I got the jb4 for my 2020 Mazda 6 2.5t and I wonder, do I have to go in the app to turn it on every time I start the car? Or does it stay on constantly? The reason I’m asking this is that I noticed (and it may have just been my subjective observation) my car running normal if I don’t get in the app and tap on the MAP to get it to map2. After doing all that and only then the chip seems to start working. Please let me know if it’s me or this is how it works. Thanks!
10-28-2021, 08:59 AM
Should always be on
Car: 2021 Mazda Cx-30 Turbo
10-28-2021, 09:48 AM
Anyone here getting the CS sri for their 3 turbo or cx-30 turbo??? Dropping November first!!
10-28-2021, 09:51 AM
I already have it, but interested to see what Burger Tuning is cooking up!
10-28-2021, 10:46 AM
Our intake should be worth the wait.
10-28-2021, 02:52 PM
possible release date??
10-28-2021, 04:05 PM
I just tossed a K&N filter in mine as a stop gap until we've got intakes available that include a turbo inlet pipe. I might pick up ~5awhp lol.
10-30-2021, 10:50 AM
My God 93@Map2 is amazing. Getting pas a 100mph is just too quick .This is already enough for my need. Just need that 80mm corksport midpipe then I am good.
M3TH user
10-30-2021, 11:36 AM
Lol.. it's still a high 13s 1/4 mile car. I spose I'm extra jaded because I own a 525whp Speed3. I do really enjoy the 0-30 burst with a brake boost, and probably even more so when I get real tires on the car.
Roasting all 4 tires to ~5K RPM is entertaining, even if it's on bicycle tires.
10-30-2021, 11:45 AM
I don’t own a faster car but I’ve been in much faster cars so I agree completely. Last night I pulled a 1.9 60ft which felt good, but the rest of the run was nothing special. (8.7 in the 1/8th and 0-60 in 5.1, so good for this car but overall I wouldn’t call it “fast”)
Car: Mazda 6 2.5 T
11-01-2021, 07:58 AM
Hi, also a newbie here
By any chance do you have pics of the installation process?
Y own a Mazda 6 2.5T and recently bought the JB4, but can't figure out if it is just a plug&play install that I can do in my home or should I take it to a car shop.
It seems that the setup is different in the CX/3 models than the 6.
Acoording to BMS instructions, there should be 2 MAP sensors to plug, and only on CX-30 a third MAF sensor to plug in
So in my car I need to find the manifold sensor that I already did
And the other sensor should be on the chargepipe, I asked Terry and he sent me this pic (I can't find it in my car, at least not in plain sight under the hood)
And finally, the wire to the OBDII should be routed through the firewall
My main question is, do I have to remove the front bumper to reach the chargepipe sensor? (second pic) If so, then for sure I'll have to take the car to a shop.
Thanks in advance for any help
MAX
11-01-2021, 10:01 AM
