Hi all,
I recently found a discussion about the N54 ignition system in a German forum, where the consensus seemed to be as follows:
- Old coils discharge later than fresh ones. Hence combustion happens later.
- Switching to fresh coils can lead to pre-ignition, because the DME (or the tune) adapted to weak coils. The fresh ones ignite the air-fuel-mixture earlier and therefore the DME is more likely to pull timing.
- Spark Plugs with an adjusted gap have a lower chance of having the spark blown out at higher boost, however the spark itself is smaller and therefore the air-fuel-mixture takes longer to fully ignite. This has the same effect as lower ignition advance
So the derived relations were like this:
- New Coils: reduce misfires, but dont help with timing drops and possibly make them worse
- New Plugs (gapped): help with misfires and timing drops, but reduce idle smoothness and max. power (due to the same effect as lower ignition advance)
Would you agree with these statements?
I am wondering because I am having more timing corrections with new coils and plugs (Eldor + NGK 95770 @ 0.022") than I had before with the same boundary conditions. Logs can be seen here:
https://www.n54tech.com/forums/showthread.php?t=66571
I am unsure about the point with new coils and timing pulls due to pre-ignition. This would mean that the DME has adaptations for old coils, is this the case?
Best regards from Bavaria
