Car: 2015 A3 2.0
UPDATE -
10-15-2021, 08:23 PM
Switched from map 5 to map 2 and now I’m probably going to need a motor
Ran great missfired and died took plugs out saw the tip to one was broke off changed plugs and now my whole top end is knocking badly 49k miles on the car
Trying to find a stock down pipe and send it to Audi to hopefully get warranty work done … PRAY FOR ME GUYS THIS SUCKS!!!!
Reason: Silly
Car: Audi s3
10-16-2021, 08:11 AM
Originally Posted by 1maudiz
Switched from map 5 to map 2 and now I’m probably going to need a motor ����
Car? S3? year?
10-16-2021, 08:29 AM
Some misfire codes require them to be cleared a few times. You can try disconnect the battery for a while.
If you taking it in dont clear the codes.'
Where the plugs stock? We have never seen tips come off on stock plugs. They can burn the tip away after long use but dont fail.
2021 VW Golf 8 R
Car: 2015 A3 2.0
Update -
10-17-2021, 01:02 PM
Car is a 2015 A3 With the 2.0 and yeah stock plugs I’ve personally never seen a tip come off a plug too! Cleared the codes no more codes for the missfire,
I can upload a YouTube vid if you want to see the sound it’s making
it it’s kinda crazy for only 49k
Question for you guys when I take this car to Audi for warranty work should I keep the new plugs I put in and keep quiet that a plug failed?
Say “car was missing so I tryed new plugs and noticed that it was making a sound too”? (Having the girlfriend take the car in)
My biggest struggle right now is finding a used stock DP
Right now the car had a ******* down pipe and I would think that Audi would flag the work and not cover the issue if they see the ***************
10-17-2021, 01:29 PM
Note sure about the plugs. DP would be a issue.
2021 VW Golf 8 R
Car: 2015 A3 2.0
Thanks -
10-18-2021, 10:40 AM
Car: 2021 Mk4 Skoda Octavia RS 245HP
11-24-2021, 02:34 PM
Hi George, do you support the new 2021 Mk4 Skoda Octavia RS Australian spec? It’s got the EA888.3 with IS20 not the garret turbo. I’m picking it up tomorrow.
11-24-2021, 03:37 PM
The Group 2 unit will work on it. Will be best to email some logs to me once its up and running.
We missing a few OBD parameters on it that will will add on a future firmware update that will be specific to those motors. We have done a few MK8 GTI's already that have the same new/old motors in them. It seems South Africa also got the same spec with the IS20 and I managed to get one in and test on it.
2021 VW Golf 8 R
Car: Audi s3
11-25-2021, 08:20 AM
Excellent George!
What would be the updated list of cars that support the JB4 gen3 "B"? Thanks in advance!
11-25-2021, 12:23 PM
Originally Posted by santiagoafull
Excellent George!
We might confuse things by calling it a 3B as that is already a different motor that is fitted in the 140kw models.
We going to sell the Group 2 for the Australian and South African market as is from the site and then down the line create a market specific firmware for them so all the OBD channels will work. They seem to be the same as the MK8 R Euro spec so once we have solved those it will be easy to test as I am in South Africa and have access to the cars.
2021 VW Golf 8 R
Car: VW Golf GTI PP MK7
12-01-2021, 09:32 AM
Hi, So I have a mk7 Golf GTI PP in the UK and have got an induction kit + Scorpion non res catback. Currently just been using map 2 with 99RON. Would a custom map 6 see better gains / drivability with these mods?
12-05-2021, 03:52 AM
Yes, on 99 we can run more boost than map 2.
2021 VW Golf 8 R
Car: 2019 VW Polo AW GTI
2018 8v2 S3 Fuel pump not priming (Intermittent issue) -
12-13-2021, 12:59 AM
Originally Posted by Raks9201
Hi George
I installed the jb4 in my Audi s3, I noticed after the install my car won't start sometimes with the first turn. Note I don't have the keyless option and have to physically turn the ignition. I noticed this happens intermittently and seems to only has happened on maps 3/4/6 & 8. It will just hang like there is no petrol, not the same noise you hear when the battery is flat. I switched into Map 0 this morning and I am waiting to see if it happens again.
Have you ever come across this fault before? If yes why and what is the solution?
Warm Regards,
Hi George
I think I prematurely agreed that this problem was rectified. After changing the fuel loop to 45 I still got the starter issues after a while. I then ran the car on Map 0 for around 2 months and the problem disappeared completely. After changing it to map 1 on the weekend everything thing ran fine initially until the same issue started again. It seems to start fine in the morning however after a short drive and stop, on the restart, it had a hanging starter like there is no fuel. Once I turned off and tried again it started again. Please assist me, I hate not having my jb4 on.
Warm Regards,
Car: Audi s3
12-13-2021, 01:43 PM
George,
I just sold my S3. I bought a 2018 Audi A3 40TFSI (2.0T 190CV). Is it compatible with the JB4 GEN3 B that I was using in my S3 8V? this car has DQ381. The stickr on the box says: JB4-MQB-2.0-AWD and check box "other" says "B".
Thanks in advance George
12-14-2021, 05:41 PM
George,
You can run it in map 1. Dont connect plug C on the side of the intake manifold or the AFR connection.
2021 VW Golf 8 R
Car: Audi s3
12-14-2021, 06:14 PM
Sorry: I did not understand what I should NOT connect:
1) Plug C (intake manifold)
2) AFR wire.
Correct?
Dq381 I can't use map 3?
Thanks George !!!!
12-15-2021, 04:54 AM
2) AFR wire.
Correct?
Thanks George !!!!
Map 1 on Gen3 firmware is the same as map 3 on Gen3B firmware so that is the recommended map.
Map 4 has too much boost for this motor.
2021 VW Golf 8 R
Car: Audi s3
12-15-2021, 07:01 AM
Ok George.
To install: plug C not install? Sorry dont understand this
12-15-2021, 07:22 AM
Ok George.
No, that is not used at all and leave stock one in place.
2021 VW Golf 8 R
Car: 2017 Golf TSi 1.8L
12-17-2021, 06:32 AM
Hey George, Map 3 is fine with good fuel without the AFR wire on the 1.8, right? After buying from a Golf R owner I'm getting perfect trims, stock AFR's and no timing corrections. I'm hooking up the AFR wire later as he had the full AFR passthrough plug for MK 7.5 and my T fit connectors arrive later today, but these 2 pulls (trimmed to one chart) look good right? Not sure how to post links here, had to cripple it to post.
datazap . me /u/danbfree/map3?log=0&data=1-3-4-6-11-14-15-18-25-26-27-28
Car: AUDI A3 8V 2016
02-02-2022, 08:53 PM
Hi, I'm new here on the Forum!! There are some logs of my car mounted stg2 + JB4 turbo IS38 in the phase of adjustment with George!!!
https://***********/u/djdouglaslopes...=0&data=1-4-18
Car: 2017 GSW
02-07-2022, 10:56 AM
Originally Posted by djdouglaslopes
Is it running a little rich up top? Maybe why it's not reaching target. Great boost numbers.
02-07-2022, 11:15 AM
Hi, you're really right, it's a little rich up there!!!
I'm working out some details about the fuel mixture with George, in this log I have FUEL BIAS 100 between 2500 to 4500rpm, and 20 between 5000 to 7000rpm, and FOL at 50!!
About the turbo not reaching the target, we saw that the flash that is in the car's ECU, for sure, has the wastage setpoint modified, so it can't pour more than 20psi at high (6000RPM).
I'm still testing, because I'm having error 3A9F, and let's lower the FOL a little to 40!!!
Car: Golf R
New Install Help/Advice Required Please -
03-09-2022, 10:34 AM
Hi, I've just installed a JB4 on my MK7 Golf R and have the app and can connect to the car. All is good so far.
I've emailed George to start the custom map setup and await a response.
In the meantime, what is the best map to run until I get the custom map?
Is there a list of the current maps and what they do for my car available to view?
What is the process for logging data? For example, should I drive the car in Map 6 then log a drive? I read somewhere you drive in third gear and log until it changes to 4th gear, but the posts I've been reading are quite dated and I really want the most up to date information.
THanks in advance!
Car: 2017 GSW
03-09-2022, 11:53 AM
