AdamsDriver AdamsDriver is offline
Car: honda
Default N55 Engine Reliability and Performance - 04-10-2021, 01:36 AM
Looking to get a 2011 335i with the N55 engine. I've heard that the N54 is more tuner friendly, but it is prone to having issues with maintenance and reliability. I've heard that the N55 is less tuner friendly, but more reliable. Is the N55 engine still pretty bad in the reliability department in the grand scheme of things? What are some common problems with it? Anyone have any experiences with it? ThanksTweakbox Appvalley https://vlc.onl
drwillb drwillb is offline
Car: 2012 n55 135i
Default 04-10-2021, 04:28 AM
You realize you’re the 4th person asking about N55 reliability this week?
Do a search or just scroll down the threads list
2012 135i Mods: air scoops, CP, K&N filter, PS1, ADE FMIC, BMW PE, JB4, 1M front body, full M3 suspension front and rear, M3 brakes front and rear, M3 rear subframe and LSD
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i
jmendez78 jmendez78 is offline
Car: 2014 335i M Sport
Default 04-11-2021, 12:15 AM
I don't have any BMW experience before my current car. It's a 2014 N55 F30. I've owned it for 2 years. Car was immaculate, currently it's got 124k miles and putting down 430 HP.
I did my research and first thing was to replace any weak points for the EWG motors. Charge pipe, ********, turbo inlet pipe, diverter valve and hpfp.
Aside from that just stay within your budget. Always take care of the weak points and you'll be fine.
anshmalik anshmalik is offline
Car: Tiago
Default 12-27-2021, 10:56 AM
N55 Engine has mainly these problems
1.Valve Cover Oil Leak
2.Water Pump Failure
3.Leaking Oil Filter Housing Gasket
4.VANOS Solenoid Failure
5.High Pressure Fuel Pump Failure (HPFP) – Mostly older models.
So we have to sortout the problem before it getting worse. You can find other issue on the forum as well. So try to figure it out from there. https://digieducationhub.com/https://myvestigeproduct.com/https://animeoschool.com/
Car: 2012 n55 135i
Default 12-27-2021, 02:04 PM
....and oil pan gasket
