(#3651)
Default 09-11-2020, 05:12 PM
Originally Posted by bosaad
Any benefit from fuel wire for stinger 2L with out E85 or WMI?
Not a huge benefit on the 2L unless you're doing racing and need every last tenth.
Default 09-11-2020, 05:13 PM
Originally Posted by danalmsa
Can you check out these logs? I had a hard time upgrading this firmware, including having the app stating that there was no firmware on the device after two failed attempts. Unfortunately, I had to move the car 20 feet while it was like this. Finally got it to succeed by placing the phone right on the Jb4.
I only use map 2, so that's what I tested with. And, something feels off. Didn't feel as peppy as it usually does (I had just done some errands before trying this and the car was feeling quicker). The other thing is that when I pressed the pedal, on the first drive after, it felt lagging. And then, about half a second later, I would feel a hit, kind of like the transmission suddenly falling in gear. This happened a few times, so I parked the car, turned everything off and then restarted, and that stopped. Might have been because of the recent upgrade. But the acceleration still felt different. I'll go test again later, as I suspect I need to drive it a bit more with the new map.
Edit - is it possible for the ECU computer, because of the confusion caused by turning on the car without a firmware loaded, to over boost? If I look at all my lgos, and compare to the one at 2:06, the ecu_Boost went up to 17.7 , whereas in all other logs, that was maxed at 14.5. The target boost went up to 22.1, higher than any other log.. just odd.
Don't see much in the logs. Set app to combine logs next time and do more full throttle.
Impurpleo Impurpleo is offline
Car: Kia Stinger
Default 09-15-2020, 07:14 PM
Hi Terry, new to this platform but I've got two runs that I'd appreciate if you could take a look at.
Everything looked fine from my preliminary once over but obviously I'm not the expert you are.
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 09-16-2020, 10:20 AM
So noticed that the initial post mentions which wire to tap into for the 1.6T is now Blue? Wasn't it originally white? I know I'm using the adapter so I know which wire to properly tap into, but what would happen if tapped into the wrong wire?
Also, now seeing the new alpha. Are the mentioned DWP settings of 60-70 fine for the 1.6T or is there a more optimal setting? I setting it higher or lower going to possibly cause issues?
Default 09-16-2020, 11:37 AM
Fuel control won't work if it's in the wrong wire. A log can confirm that. The 1.6L fuel wires have been an area of confusion as different model cars seem to have different color wires. =/
Default 09-16-2020, 11:38 AM
Looks fine to me! I see gas pedal isn't 100%, make sure nothing is blocking the pedal.
khancerto's Avatar
Default 09-16-2020, 01:54 PM
if using the adapter on the 1.6L, the red wire is still the correct one, right?
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default 09-16-2020, 06:22 PM
Question for all but interested to hear Terry's opinion - got my JB4 kit for G70 3.3T and get the card new on Friday. How long do you think I wait before installation of Induction, JB4? I think I will add catch can and plugs straight away.
Can't wait, I'm like a kid at Xmas.
Twister
Twister
2021 Genesis 3.3T
Siberian Ice
Got it today
JB4 kit with EWGs waiting to go on, then onto next upgrade
Waiting to feel the JB4 difference
Stung Stung is offline
Car: 2018 Kia Stinger GT2 3.3TT
Default 09-16-2020, 06:43 PM
Twister
LOL I completely understand. This'll start the 'engine break-in' ever-argument so I'll say I like to break in a bit. Sure I'll get the first oil change in and sure, a bit early. And if I can actually find the time and place, I'll work the transmission somewhat hard (harder to do with an auto LOL) and a bit of brakes break-in. Nothing extreme. But let's make sure this newly-built chariot is working before I play with it. But, as patience goes, one vulture on the dead branch turned to the other and said, "Patience, hell. Let's go kill something."
2018 GT2 AWD
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 09-16-2020, 06:44 PM
Break the motor in first, wait for the first oil change, then start bolting stuff on.
Default 09-16-2020, 08:20 PM
I always suggest 200-300 miles before tuning just to make sure nothing is broken from the factory.
twister68's Avatar
Car: 2017 Q60 RS
Default 09-17-2020, 04:36 AM
thanks Terry - common sense reply, much appreciated
Twister
2021 Genesis 3.3T
Siberian Ice
Got it today
twister68's Avatar
Car: 2017 Q60 RS
yeah that's me, not very patient
Twister
2021 Genesis 3.3T
Siberian Ice
Got it today
khancerto's Avatar
Default 09-17-2020, 07:43 AM
Messed around a bit with the new DWP settings. Starting with 65, noticed that mid throttle it seemed to be either I guess what you call surging or just not pushing as hard as it usually does. Set it down to 45 and it stopped happening. Throttle seemed to be closer to normal.
Kinda curious if higher towards 100 is actually doing the opposite of what I think it's doing. Hmm.
Default 09-17-2020, 01:30 PM
Keep the feedback rolling and be sure to also indicate what motor you have. Also for DWP to work the JB4 has to be properly installed. Brown connection on manifold, red/yellow/black before throttle body. Some 1.6L customers especially invert the connections.
khancerto's Avatar
Default 09-17-2020, 02:10 PM
Yea sorry, I'm in a 1.6L Turbo. I should have the plugs in the right place. I guess I'll just keep messing around with the numbers and see what changes. Looking forward to hearing what it actually does once it's been fine tuned!
GT2Crew GT2Crew is offline
Car: 2019 Kia Stinger GT2 AWD
Default Yesterday, 05:03 PM
I see fuel pressure starting to drop a bit, update to v21 firmware and re-log map3 for comparison's sake.
Done. v21 e30(91 octane) Map3. Still feels like fuel pressure drops at high RPMs.
Default Yesterday, 05:59 PM
Seems OK to me but timing isn't perfect. Use a dragy to see if map2 or map3 is faster and run whatever is giving the best times.
twister68's Avatar
Car: 2017 Q60 RS
Default Yesterday, 07:30 PM
Interested to learn a bit more about the DWP wires and where they come from to in new firmware version?
Twister
2021 Genesis 3.3T
Siberian Ice
Got it today
twister68's Avatar
Car: 2017 Q60 RS
Default Yesterday, 07:35 PM
Next question may turn into a rat hole,but .....
Gas seems inconsistent here in Canada from what I’m reading. What are best ways to,boost octane for lowest risk to the engine and components?
I’ve been running petro Canada 94 since I moved to Canada but is that the best, maybe not it seems?
Which I was able to get my super unleaded 98RON in UK here...
Twister
Twister. Car came today and it’s soooo hard driving under 2500 rpms, not sure how long I will last.
Twister
2021 Genesis 3.3T
Siberian Ice
Got it today
Default Today, 08:39 AM
It's just a test software setting, documented in the app under alpha firmware updates.
Default Today, 10:09 AM
Thanks for the prompt response. Would running e40 make any difference in your opinion from what you see with others at 5000+ elevation?
Lil Ripper's Avatar
Lil Ripper Lil Ripper is online now
Car: 2019 Veloster turbo
Exclamation Today, 12:43 PM
OK... So I have my yellow/red/green /black to my manifold and the brown before my throttle body on my 2019 Veloster 1.6 Turbo. Sooo your saying I have it backwards?
Default Today, 04:29 PM
Yes, backwards
Lil Ripper's Avatar
Default Today, 05:43 PM
Yes, backwards
OK, well that made a difference. I have only had it hooked up backwards for 4 months lol.
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
Lil Ripper
