bandook bandook is offline
Car: 2013 335i
Default Fuel pressure issue, what pump do I need? - 09-16-2020, 06:39 PM
Fuel pressure is dropping. Trying to run e30 when I saw the drop, filled up with around e20 and it's still doing it. There is a fast, dull ticking noise coming from under rear seat. Think lpfp is on its way out, maybe. What is a go to lpfp for f30 335i? In my log you can see it dip out when it shifts to 4th, but the AFR goes rich. I figured it would lean out? Only had the car a month so I'm learning. Jb4+bef map 2.
