(#226)
Default 02-13-2019, 08:32 PM
The platform continues to amaze me... I'm limiting boost -4psi in 1st gear too as the "private track" conditions are just so-so. Imagine on a full boost launch getting that 60' in the high 1.5x range.
Hckymstr19 Hckymstr19 is offline
Car: Audi rs3
Default 02-15-2019, 01:07 PM
Any rs3 draggy data out there with the jb4? I know the ttrs will run faster times, so just want to see what the rs3 is capable of with just the jb4.
Default 02-15-2019, 01:17 PM
Still early days but I'm sure we'll see it sooner or later. George is high elevation so his RS3 times will be proportionally slower.
Ctjallen Ctjallen is offline
Car: 2018 RS3
Default 02-16-2019, 03:26 PM
I forgot to order the wireless adapter, can I hook up the unit without it. I did order the computer connection.
Default 02-16-2019, 03:28 PM
Sure... The data cable and JB4 mobile adapter do the same thing. Data cable via laptop, JB4 mobile via your phone.
Car: 2018 RS3
Default 02-16-2019, 03:41 PM
Is there a page that shows what the standard maps are?
Default 02-16-2019, 04:01 PM
Its in post 1.
2017 Audi 8V RS3 Sedan
2018 Polo GTI
RSthree RSthree is offline
Car: Audi RS3
Default 02-17-2019, 02:21 PM
Terry, how do you measure in the 30% e85. Do you have a process to get the ratio right or is it just an approximation?
I have e85 available near by so I thought it would be good to use it as an octane booster.
Bullitt1841's Avatar
Default 02-17-2019, 03:23 PM
I use this: https://play.google.com/store/apps/d...nethnissel.e85
E85 is 85% ethanol and 15% gasoline (ideally). E20 is 20% ethanol, etc.
Most gasoline in the US is E10, already. Most "E85" from a pump in the US is really E50 - E85, depending on region and time of the year.
It doesn't make sense to say "30% E85" (alone) because you still don't know the true ethanol percentage. But it does help if you say "30% E85 and 70% 91 octane", because now you have an idea of how much "octane" you have, or realistically how much timing/boost you can run.
Yes, it gets complicated and it really comes down to checking your logs and keeping track of what fuel combo is in the tank. Generally speaking, too much timing being pulled = not enough octane for the combo. Fuel pressure taking a dive = too much ethanol (or boost) for the combo.
It's always a balancing act.
2018 Audi RS3 | Stage 1 E85 and 91 Flashes | JB4 for Logging
Car: Audi RS3
Default 02-18-2019, 12:07 AM
Thanks, and understood about monitoring the timing/ boost etc.
I was more asking about how Terry manages filling up his tank with the right quantity ratio of e85 and normal fuel (98 in my case in Australia) to begin with. Usually the fuel gauge is not an accurate way of determining the volume of fuel in the tank to try and work out how many litres/gallons of e85 to add.
Jd_335i Jd_335i is offline
Car: 2011 BMW 335ix
Default 02-18-2019, 02:02 AM
Hi BMS team,
2018 RS3. FMIC, down pipe, Midpipes. Looking to run full e85 (local pumps are ~e60-e63 as measured).
Can you support this? Can you code out down pipe cel?
I used jb4 on my n55 335ix and loved it!
Thx,
JD
Boulder, CO
Ross_T_Boss Ross_T_Boss is offline
5-chamber Heart
Car: '18 Audi TTRS
Default 02-18-2019, 02:56 AM
If adding to neat 98 - work out the E85 content for a full tank, add it first, then then brim it on 98. Or run it down close to 0 miles as possible, assume 2-3l left in the tank in your calc, add the ratio desired in for another 50l (which you'll get in - its's a 55l tank) and go for it.
Once you have your desired ratio in the tank you'll have to use a bit of guess work for part-filling but don't need to worry about calculating what's in there already. I find 'range' much more accurate to work out what's remaining than the gauge, aim under to give a bit of headroom, but generally if range less than 30miles you'll get 50l total in.
The biggest variable is working out what the E85 content is - hopefully in Aus it's more consistent that the US which suffers from a lack of regulation around fuel quality - and also any Ethanol/Methanol content in the existing fuel which should be taken into account. For example here the 95RON commonly uses 2-3% Methanol which ~3-4.5% Ethanol, and another 4-5% Ethanol as a co-solvent, so it'll report at E7-8 off the bat.
Car: Audi RS3
Default 02-18-2019, 04:47 AM
Thanks Ross. The last time I used E85 was a few years ago and according to my ethanol sensor the E85 was fairly consistent, 80-85 range.
