(#1526)
CapitaineBeaver's Avatar
CapitaineBeaver CapitaineBeaver is offline
Car: BMW 230i xDrive
Default 11-10-2018, 11:55 AM
Originally Posted by AndreySPB
Can we expect backend flash for b48?
I'm sure we will start to see B48 flash tune and backend flash soon but i'm pretty sure they are prioritizing the B58 since it's probably a bigger market for tuning.
'18 230i xDrive // Black Met // Coral Red // M-Sport // 719M Black // BM3 // BMS Intake // BMS OCC // Dinan Axleback // Roof Rack // 365 days of fun
HIRRS-ZN's Avatar
HIRRS-ZN HIRRS-ZN is offline
Car: F30 320i
Default B48 320i Max boost - 11-10-2018, 11:35 PM
Howzit Guys,
Whatís the max boost the b48 320i with stock internals can run?
BMW F30 320i N20 - JB4 -EWG
BMW F30 320i B48 - JB4 - EWG - FF
HIRRS-ZN's Avatar
Car: F30 320i
Default 11-10-2018, 11:37 PM
There are a few guys that are flashing the b series.
Not sure on mhd or bm3 release eta.
AndreySPB AndreySPB is offline
Car: Bmw 320i lci
Default 11-11-2018, 12:47 AM
So the bef for b48 already exists?
Car: Bmw 320i lci
Default 11-11-2018, 12:57 AM
Howzit Guys,
Iím running 22 psi with 11:1 compression ratio. Also tried 23 psi for a short time. The power is great! Especially great for 2 liter bmw. Honestly I wasnít expecting that kind of performance. The car is basically 320ix with 330 power class so it became 330 with 320 pistons.
HIRRS-ZN's Avatar
Car: F30 320i
Default 11-11-2018, 01:12 AM
Yeah bro.
HIRRS-ZN's Avatar
Car: F30 320i
So your ecu is flashed?
Car: Bmw 320i lci
Default 11-11-2018, 01:55 AM
No, that was done not via flash. You can do that before 10 motor hours on a new car.
HIRRS-ZN's Avatar
Car: F30 320i
Default 11-11-2018, 02:12 AM
Huh what u mean bro?
2blu 2blu is offline
Car: F30 335i X-Drive M-Sport 8AT
Default 11-18-2018, 07:38 AM
Is it normal that error code deleting doesn’t work on g30 jb4 with Bluetooth connect kit?
Default 11-18-2018, 12:25 PM
Support requests go to our support team via email, or to the support forum.
Default 11-18-2018, 12:26 PM
Originally Posted by 2blu
Is it normal that error code deleting doesnít work on g30 jb4 with Bluetooth connect kit?
Make sure you have latest firmware, and sometimes need to press ignition 3 times foot off brake to get in to diagnostic mode first on the vehicle.
Default 11-18-2018, 12:43 PM
Have the latest firmware, Iíll try that trick to see if it works!
BMW After BMW
Car: BMW M240i
Default 11-19-2018, 10:58 AM
Originally Posted by ZTZ1010
is the practical effect of FUA adjustment boost reduction? I seem to see substantially lower boost the more I increase FUA values..
This was written in 2015, my observation is that it's still largely true today:
"FUA Single Turbo Firmware:
0-50 - Lock in a differential between DME target and ECU PSI to reduce the throttle safety. 0 = default operation. 26 units per PSI. e.g. a value of 26 would dampen throttle safety an addl psi. This value will also reduce effective load reported back to the DME by that amount. For diagnostic purposes only."
People run with values from 5-20 from what I have observed; for me, the EWG harness and FUA set to 10 corrected throttle closures due to overboost in WMI use. It did this at the expense of additional boost, which was ok in my case. It's not about boost only, it's timing (advance) and the boost curve. YMMV.
Wickedowesix's Avatar
Car: 540i G30
Default 11-19-2018, 11:41 AM
Little FYI/update
Im back to V9 firmware. The car runs a lot more responsive than with V11. With the V11 my targets were never met and V9 are basically spot on.
bhw3131@aol.com's Avatar
bhw3131@aol.com bhw3131@aol.com is offline
Car: M3 Competition
Default Interesting... - 11-19-2018, 11:54 AM
Thx for that update.
18bmwb58's Avatar
18bmwb58 18bmwb58 is offline
Car: 2018 bmw 340i m sport
Default 4th gear and 5th pull - 11-25-2018, 06:42 PM
B58 should i readjust anything on map6? 93 octane ******* ********* ewg and flex fuel wires
Default 11-25-2018, 09:50 PM
You have some timing drops here, I tend to prefer the additive maps on the B58. Like, map3.
18bmwb58's Avatar
Default 11-26-2018, 02:44 AM
This is on firmware 11 ... and i like map3 but the throttle closure is unreal especcialy in between gears if i shift too fast it leans out bad ... im gonna take another 4th gear log tomorrow ... on map 6 and map 3
18bmwb58's Avatar
Default B58 logs looking good to me? - 11-27-2018, 05:35 PM
Attached three logs
3rd pull
4th pull
And third to fourth on map6
Let me know how these look
It felt great and looks ok to me
Default 12-02-2018, 07:59 AM
Any ETA on the new update with revised Maps number and valet ?
JohnnyM40i JohnnyM40i is offline
Car: X3 M40i
Default 12-05-2018, 05:30 PM
Question: I recently installed the BMS intake and JB4 on my 2019 X3M40i and I am curious to know what is the highest map I can safely run?
I tried to search to see if I could find the answer and didn’t find anything pertaining to the X3.
Thank you in advance.
Default 12-05-2018, 06:40 PM
What fuel are you using?
Default 12-05-2018, 06:41 PM
I think the firmware in the first post has the VALET map4 option, not sure why it isn't documented. I'll update that now.
Car: X3 M40i
Default 12-05-2018, 07:32 PM
I fill up with 93 oct down here in Miami.
