ocr4m ocr4m is offline
Car: Bmw 320i n20
Default F30 N20 Log Review - Fw 13/5//5 & 13/6//5 - 09-10-2019, 02:54 PM
Hi guys, yesterday I updated the Jb4 firmware to version N20_OBDII_EWG_6.hex (13/6//5) and now the car is not doing so well and with the same performance as the penultimate fw on map 6. I would like someone to analyze the logs and if possible send me the firmware N20_OBDII_EWG_5.hex (13/5//5) I wore before the upgrade.
Below is a current mod list:
- 2014 BMW 320i Active Flex (EWG)
- JB4 - Map 6
- ** 2.5" without catalyst
- Inbox K&n
- Brazilian gasoline called "Podium" E25 95 octane
Attached is the data I use in map 6 and the logs from firmware 13/5//5 and 13/6//5.
I appreciate any help.
Default 09-12-2019, 07:52 PM
Both logs look fine, you're riding the boost safety at +12psi over stock on both maps. So any minor variance in factory target will effect your actual JB4 target.
