(#1026)
BMRDude BMRDude is offline
Car: 2012 550ix
Default 12-13-2016, 10:12 PM
ah, ok. been quite a while since i ran my Stage 1 but i could set a broad range of boost on it but i kept running into drivetrain errors on higher boost.
looks like you still need to get a cable for the laptop to set FUD=1.
Car: 2010 535
Default 12-13-2016, 11:09 PM
where can I purchase the cable and windows software?
what does FUD=1 do?
Default 12-14-2016, 11:13 AM
When we changed the system from the G3 to G3rev2 board we also dropped the FUD=1 setting. The new board detects the model now and adjusts itself. So you just install and enjoy. Next stop for more power and features, the JB4 upgrade kit.
Car: 2010 535
Default 12-15-2016, 01:14 PM
My box is marked "63-2", does that mean it uses the G3rev2 board?
Car: 2010 535
Default 12-16-2016, 09:00 PM
I just opened my box, I have the G3 rev2 board. im assuming it comes defaulted at 3.0.
i run 93 octane, could I use the jb4 interface to bump it to 4psi?
Default 12-17-2016, 03:19 PM
Yes should be the new board that is automatic and not adjustable. Next stop for more power will be the JB4.
evanswan evanswan is offline
Car: 2013 BMW 550i
Default 02-16-2017, 11:16 AM
Any firmware updates or new tune coming for the N63TU engines.
badblack550ix's Avatar
badblack550ix badblack550ix is offline
Car: F10 550i Xdrive
Default 04-07-2017, 12:59 PM
any instillation instruction for the JB4 beta ? can't find anything.
F10 550i xdrive Carbon Black Aluminum BMS Stage 2 WR 11.943 @117.940 Time Slip 421AWHP 467.9 AWTQ MUSTANG DYNO
Car: 2012 550ix
Default 04-07-2017, 04:50 PM
http://www.n54tech.com/forums/showthread.php?t=40626
two Stickies down from this one...
Kolbe's Avatar
Kolbe Kolbe is offline
Car: BMW F10 M5
Default JB Stage 1 Settings - 06-21-2017, 04:43 AM
Hi, I remember post nr. 1 having information on JB stage 1 Map settings as well as firmware levels and when to use the JB4 interface for decreasing the boost settings (JB Stage 1 production date specific). Where has this information gone?
Default 06-22-2017, 08:58 AM
Using JB4 interface you can select map3 and adjust boost safety between the 0-4psi range.
Car: 2010 535
Default 06-22-2017, 09:04 AM
Do you have the new version or older version? the newer version isnt adjustable
Default 06-22-2017, 02:25 PM
We've not sold the old version in many years and its no longer supported. If you need additional assistance or to purchase an upgrade feel free to email in to tech support.
Kolbe's Avatar
Car: BMW F10 M5
Default 06-23-2017, 04:53 AM
Sorry, that is not correct, the new version is definitely adjustable via the JB4 interface with the BMS cable. Map 0 = stock, map 1 = 4 psi fixed, map 3 = adjustable from 0 - 4 psi max.
Car: 2010 535
Default 06-26-2017, 10:54 PM
The N63 rev 2 board, Terry told me it wasnt adjustable... post #1031
Kolbe's Avatar
Car: BMW F10 M5
Default 06-26-2017, 11:10 PM
With the present (V2) board on my S63TU: Map 1 is not adjustable - that is correct. The adjustment is possible via Map 3 and is adjustable from 0 - 4psi. Map 0 is stock. I have done numerous logs on all three maps and confirmed this times. Confirmed by Terry and Ando. Try it.
m5james's Avatar
m5james m5james is offline
Default 06-26-2017, 11:24 PM
Terry will correct me if I'm wrong, but:
1) The S63TU JB4 isn't the same as the N63/S63 version
2) The N63/S63 JB4 has been discontinued
Kolbe's Avatar
Car: BMW F10 M5
Default 06-27-2017, 01:25 AM
Just to avoid any confusion - I am talking of the JB stage 1 (not JB4), Version 2 board, for used on an F10 M5 (S63TU). The JB4 interface is used to connect to the JB Stage 1 board to select map 0 (stock), map 1(+4psi additive) or map 3 (which is adjustable from 0 - 4psi). Jon from BMS and my local BMS agent confirmed/explained this by email before I purchased this 4 months ago and this is exactly how it works - which is great!
m5james's Avatar
Default 06-27-2017, 01:46 AM
This is an N63/S63 thread, so I don't see why S63TU is even being discussed. I'm guessing everything from firmware to steering wheel controls/menus are different. The S63 version of the JB4 has been discontinued, so if the S63TU was interchangeable between the two engines, then the TU would be in the title.
Kolbe's Avatar
Car: BMW F10 M5
Default 06-27-2017, 03:43 AM
Sorry, this is also an S63TU thread! Please refer to first post from Terry:
"Hey guys,
This is the central post for all n63/n63tu/s63/s63tu Stage1tuning information.
Download the install guide here".
If you read the various posts then you will see various references to the S63TU.
Car: 2010 535
Default 06-27-2017, 07:14 AM
"Hey guys,
Ahhhh ok, I thought you had an N63 board. Sorry for the confusion
Kolbe's Avatar
Car: BMW F10 M5
Default 06-27-2017, 07:52 AM
All good, thanks .
m5james's Avatar
Default 06-28-2017, 09:10 PM
"Hey guys,
I stand corrected, sorry. The engines are wildly different going from non-TU to TU, AFAIK the BMS hardware itself isn't cross compatible, so I'd assumed the thread title was specifically N63/S63 and that the N63TU/S63TU would be yet another subforum. I'm still waiting for the third / to be added to this ///M subforum though lol
Car: 2010 535
Default 06-29-2017, 09:52 AM
Terry, out of curiosity why did you move the default boost from +2.25 to +3.0 on the n63 stage 1 units?
Default 06-29-2017, 05:35 PM
Testing over time showed 3psi was a more appropriate default value. The initial 2.25psi value was overly conservative. The difference between them is relatively minor, though.
