Default 11-22-2021, 07:23 PM
Correction...map 4 first and then map 5 if everything looks good. The B58 Gen 2 typically does better with the absolute maps rather than the additive maps and map 3 can be pretty aggressive depending on DME_BT and ECU_PSI.
ToThePublic ToThePublic is offline
Car: 2015 F55 Mini - B38
Default 12-05-2021, 04:29 PM
Finally got the plugs in. NGK 94201 Laser Iridium's gapped down to 0.022". There's 2 Map 4 runs in the log. How's that look compared to the last log on OEM plugs? Thanks!
Car: Evo VIII
Default 12-05-2021, 04:38 PM
Is traction control all the way off during this log?
Default 12-05-2021, 07:29 PM
Traction control was active for them. I donít think Iíve turned it off for any of the logs. Iíve been using Sport Individual with everything but the trans in Sport. Should I be turning off traction? Any other settings for logging?
Default 12-07-2021, 11:31 AM
Here's a Map 4 log with Traction Control switched off.
Default 12-08-2021, 11:03 AM
That looks pretty clean. Timing is good, boost is on target, etc.
Default 12-09-2021, 10:09 AM
Awesome! Make sense to see what Map 5 looks like?
Default 12-09-2021, 11:47 AM
Absolutely!
Default 12-13-2021, 02:16 PM
Here's Map5 from this morning.
Car: Evo VIII
Default 12-13-2021, 02:58 PM
Looks healthy.
Default 12-14-2021, 11:03 AM
Originally Posted by Cannon @ BMS
Looks healthy.
Agreed....I'd stick with that setup and fuel, WGDC and trims are pretty much maxed so I'd say this is going to be about as good as it's going to get without pushing too hard.
Default 12-15-2021, 08:20 AM
That's awesome! Thanks guys for all your help!
I'd love to dyno the car now to see how much power it's making now. I'm toying with going to a big turbo, but that won't be for at least 6-12 months.
On a regular basis, what would you suggest as the best Map to leave active? I'll pull up Map 5 when I want to push it, or am I good to leave it active normally?
I may log once more without octane boost to see what just pump 93 looks like too.
Thanks again!
Default 01-06-2022, 11:38 AM
Hope everyone enjoyed the holidays!
Here's a Map 5 log on just pump 93 from the local Exxon and no octane boost.
Car: Evo VIII
Default 01-06-2022, 12:34 PM
Timing really didn't get much worse. You are ok to leave it in map 5.
Also, looking back through this chat, did you get those spark plugs installed? If so, did you gap them down?
Default 01-07-2022, 07:23 AM
Thanks for taking a look and for the input. I did install NGK 94201 Laser Iridium plugs and gapped them down to down to 0.022".
Car: Evo VIII
Default 01-07-2022, 12:11 PM
Perfect.
