Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default Help trims maxed out, afr lean jb4 safety (map4 safe) - 04-17-2017, 05:55 PM
Good evening. Sorry for repost but for unknown reasons my previous one was deleted. As stated jb4 +bef for 1 week ago when i go wot gives me map4 safety with "afr lean" code and trims are maxing out. Been using this bef long ago with no problems until now. Codes registered are the 2c7c. Ideas? Logs attached. One of them its at idle. Rpm changes out of nowhere as afr's
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
Default 04-17-2017, 07:29 PM
Try resetting adaptations & relogging
Eristoff's Avatar
Default 04-17-2017, 10:34 PM
Thanks for reply Dave. Shall i use JB4 to reset adaptations or MHD?
Default 04-18-2017, 08:06 PM
Jb4
Eristoff's Avatar
Default 04-18-2017, 08:17 PM
Will do, thanks. Just curiosity, is there a difference between both adaptations reset methods? Mhd has other adaptation resets too
Default 04-18-2017, 08:50 PM
Tbh, I don't beleive so.
I'd really only reset adaptations on a "need" basis.
Hopefully this helps you a bit
Eristoff's Avatar
Default 04-20-2017, 06:12 AM
Done it and remains the same :/ and also" 2c7c lambda probe behind catalytic converter 2, signal" was stored in dme. Could all of these be caused by o2 sensors?
Logs attached
Default 04-20-2017, 08:56 PM
Trims are maxing out on both banks so it's not bank related but is more global. Sometimes the JB4 reset isn't effective or as effective. Try resetting them with MHD or INPA. Beyond that, I'd verify and re-seat the connections in the DME box. If that doesn't resolve it, I'd reload the flash or try a different flash. Beyond that, you're looking for a hardware issue but this doesn't seem like an O2 sensor issue. What is 2c7c? It appears to be something global so maybe a TMAP or ???
Eristoff's Avatar
Default 04-20-2017, 09:00 PM
Thanks for reply Steve. Done the reset with MHD. It happens again. Can try a Tmap change. Should I change the Map sensor too?
Default 04-20-2017, 09:56 PM
It appears to be something global, so that is what I'd focus on.
