Go Back   N54Tech.com - International Turbo Racing Discussion > Model-Specific Engine Tuning & Modification Discussion > N54
Reload this Page So This Happened This Morning: Catastrophic Engine Failure In Dramatic Fashion
turboalb's Avatar
turboalb turboalb is offline
Car: 08' 535i
Default 03-19-2016, 06:15 AM
Beautiful car, sorry to hear about this, makes my Dme problem seem microcosmic.
justa335i's Avatar
justa335i justa335i is offline
Car: 07 E92 335i
Default 03-19-2016, 07:23 AM
All of our problems seem like nothing whenever we see things like this!
I am no longer upset of my waste gate rattle and shaft play.
2007 E92 335i 6MT
New Jersey
N54-Tuning 3'' Downp!pes, Vrsf 5'' Intercooler, Vrsf Charge Pipe, Tial-Q BOV, Vrsf Lower Charge Pipe, Act HDSD Clutch, JB4 G5 ISO, BMS Intakes, Custom Axle Back w/ 3" Tips
ken2521 ken2521 is offline
Car: 535xi
Default 03-19-2016, 07:50 AM
Looks like it hydraulic lock.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 03-19-2016, 09:18 AM
Glad it happened at low speed and you weren't hurt! Cars are easier to fix than people. Hope you get it back to 100%.
Mr. T Mr. T is offline
Default 03-19-2016, 11:49 AM
I was literally saying what the **** looking at each picture. Sorry to see this happen! That's some nasty carnage
Default 03-19-2016, 11:56 AM
Dang...that was seriously catastrophic! Sorry to hear about that Evan!
Jt0407 Jt0407 is offline
Car: Bmw
Default 03-19-2016, 12:04 PM
Did you have the motor delete tune in? Lol
Jk lol. GL with the rebuild man!
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 03-19-2016, 12:17 PM
Originally Posted by Traf
Maybe that rod broke and sent pieces everywhere ?
The rod is definitely snapped, hard to say into how many pieces but that 100% happened
Originally Posted by ThaCuda
Such a perfect car. I'm sure you'll get it back together and better than ever.
For some reason, I am already thinking that there was a cylinder cut and went hyper lean detonation. I guess there may be an assumption that the tbi was going, and the injector wasn't
Yea, hard to say, I have no experience with engine failures like this. All my injectors were low mileage (like 3,000 miles) and never showed the typical signs of struggle, rough idle etc.
Originally Posted by jb's335
Doesn't look like #5 blew. But yeah you did it about as catastrophically as possible lol...
Sorry man, I can relate. Wastegate line blew off on the dyno, let my 6262 go into freespin, next thing we know it probably hit 50psi and now I have low compression on #1 and #6. **** happens! Just have to build it better next time...
Cylinder 3 is the culprit for all the carnage, and am impressive amount of carnage it is.
Electronic problems can be equally as frustrating.
I am glad to hear I am improving your perspective!
Care to elaborate? I am all ears!
Agreed!
Yea, at least the motor blew in an entertaining fashion. For my first blown motor I think I did a pretty good job!
Yea, I can grab the forward 1/2 of the oil pan and wiggle it up and down, it almost blew completely off!
lol, I actually pressed the "blow motor now, in dramatic fashion" button by accident.
Evan
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes, M5 Rear Suspension
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Trans Swap, MFactory SMFW, Spec Stg 3+ Clutch, UUC SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Lines +Ethanol Sensor
- JB4, Hexon RR550s, Custom Inlets, AR ***, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB Ext. PCV, BMS OCC
keyap keyap is offline
Car: N55 135i
Default 03-19-2016, 12:20 PM
OMG - soooooo lucky this wasn't at high speed. Feel for you man.
Hope the rebuild etc goes to plan
Mauricio @ MMP's Avatar
Mauricio @ MMP Mauricio @ MMP is offline
Car: 335i Cp TiAg JB3 DCI
Default 03-19-2016, 12:37 PM
That is the craziest engine failure I've seen on an N54 in 8 years. Thanks for sharing but sorry for the crazy bad luck and I'm glad your ok. I wonder if your engine blew from a failure in the PI system and hyper lean condition causing detonation. I run PI and always am scared that if PI fails there is no failsafe currently in any tuning solution to switch the tune and protect then engine like if an injector clogged or failed electrically etc.
Stock Turbo 500whp 540wtq with MMP inlets
http://mmp-e.com
  • inlets (high flow and one piece silicone)
  • high flow outlets
  • turbo development
Car: 535xi
Default 03-19-2016, 12:43 PM
Not an expert but most failures have been ringlands failing/bent rods e.t.c but looking at your pics and comparing them to pics suggest cyl 3 had way much fuel in it.https://goo.gl/photos/Qfjb9FGxhVPE9As88. Regardless very sorry on this catastrophic accident.
Default 03-19-2016, 02:57 PM
Definitely takes the cake as far as morbidly fascinating engine failures lol. You were logging at the time correct? Post a handful of the logs and a screenshot of your JB4 settings. Might contain a clue as to what happened.
ross22 ross22 is offline
Car: 2007 BMW 335i
Default 03-19-2016, 09:24 PM
Sorry to see your motor go that way. Appreciate you sharing your knowledge with the community.
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 03-19-2016, 10:32 PM
Wow. Sorry to see this.
Subbed for updates.
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 03-20-2016, 06:53 AM
Best of luck :/
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
AbacusRacingN54 AbacusRacingN54 is offline
Car: 07 335i
Default 03-20-2016, 07:54 AM
Originally Posted by ucsbwsr
I am not familiar enough with engine failure to make conclusions off the information I have at this point. The engine may need to removed at dissected before we know exactly what happened. I will try to share most of the process so even if I don't have answers, we can evaluate the data together.
Evan
Why does everyone say hydrolock?
It's hard to tell but it looks like u ripped the wrist pin out of the bottom of the piston..a better picture up towards piston will tell...
I build engines all day long and figuring out why they broke in the first place is one of the perks of the job...as long as it isn't my engine or fault... gl with moving forward and get me some more pics..
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 03-20-2016, 10:17 AM
Exactly the same thing that happened to our flood recovery motor. Just salvage what you can, and get another used motor. The N54's are not as tough as people think, we are breaking them quite frequently these days.
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
omarmarji's Avatar
omarmarji omarmarji is offline
Car: n54 335
Default 03-20-2016, 10:43 AM
my favorite e61 . noooooo
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
CURRENT: E82 135i (under construction)
Visit my website VaderSolution.com !
Traf Traf is offline
Car: 2009 135i Coupe
Default 03-20-2016, 11:10 AM
That is quiet a statement, do we at least know what happened ? In both cases.
f*** v-bands clamp
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 03-20-2016, 01:34 PM
LOL quoted for the idiocy
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 03-20-2016, 02:08 PM
I know exactly what happened to our motor, we bought a flood recovery they said was good for a core only, we ran it, it made 700WHP, and developed a small tapping sound. Rod let go exactly the same way as this motor did. The pictures actually almost look indentical. They are posted on bimmer boost. The guy below quoting for idiocy. The only idiot is the person who has never done any testing, never broken anything. Thinking he knows anything about the limits of the N54. The Down syndrome displayed by the people joining this platform is so damn real. Thank god, we are slowly moving away from the N54, and working on platforms where it's not a bunch of kids.
www.Vargasturbo.com
Default 03-20-2016, 02:11 PM
LOL for the guy who has no idea what on earth he is talking about, every post he makes, is embarrassingly ill informed, and just plain not correct. Keep up the good work. Let me know when you have tested even one N54 to failure, let alone more than a half dozen. The butt hurt with how we push things forward, and laugh at the stragglers is so real. Enjoy your stock turbo, FBO race cars!
www.Vargasturbo.com
Venom77's Avatar
Car: 335I
Default 03-20-2016, 11:11 PM
Is Vargas the only performance shop going through N54s or does everyone?
Default 03-20-2016, 11:27 PM
Well, okay. What platform are you moving to ? S55 ?
Another question, and please don't take it the wrong way. But why do you always sound like you have something stuck up your ass ? Chill man seriously...
f*** v-bands clamp
moss's Avatar
moss moss is offline
Car: 2012 335iS
Default 03-20-2016, 11:50 PM
