(#726)
martymil's Avatar
martymil martymil is offline
The Backyard Mechanic
Car: BMW 1 Series M
Default 02-18-2016, 07:53 PM
Not yet. Right now it's global for all maps. We're slowly improving the system to be more automatic. At some point in the near or distant future you'll never need to adjust AFR bias at all.
This will be great, any sort off time frame ?
I could beta test if you need someone.
seroga1986's Avatar
Default 02-29-2016, 09:59 AM
From the first post, does this "PI on stage 1 lpfp and up to 600whp" stands true for this? Assuming full e85.
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Default 02-29-2016, 10:05 AM
Each firmware revision has a chunk of logic we need to make it happen. It's a complex process and we need to ensure each change is fully tested and functional as we build up to the end goal.
martymil's Avatar
Car: BMW 1 Series M
Default 02-29-2016, 10:15 AM
Thanks for the reply and good to hear
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 03-02-2016, 05:59 AM
We're slowly but surely improving the JB4 PI integration. The next piece of the puzzle is adding in a fueling factor for air intake temps. You need a lot more fuel for 25psi at 30 degrees inlet temps than for 25psi at 150 degrees inlet temps, for example. So we need the JB4 to automatically compensate for that.
We have a first draft done and need some help logging it. Drop me an email if you're interested.
Hi Terry,
Has any progress been made on this front? I am running 25 psi and winter is coming soon lol.
Is the latest n20 tmap fuel map still as of 12/6/15?
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018 gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020, stock everything else, 374.9 rwkw Mainline Dyno Aus
BostonBeemah's Avatar
Car: AW 135i
Default 03-02-2016, 09:28 AM
Originally Posted by DSCOFF
Hi Terry,
Game of Thrones reference?
RIP 2008 AW/BL 135i
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 03-03-2016, 07:41 PM
You know nothing Bostonbeemah
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
Car: AW 135i
Default 03-04-2016, 06:39 AM
Can you at least call my by my name John even if I am a bastard
RIP 2008 AW/BL 135i
DOCRAMON DOCRAMON is offline
Car: 2008 535i
Default Want to install JB4 - 03-04-2016, 10:58 PM
I have been running MHD, will like to reinstall JB4.
My PI has a separate system with separate tank, pump and boos switch.
Do I have to follow install options for the PI if I want to install the JB4?
or just install the JB4 and leave the split second as it is?
sch4400 sch4400 is offline
Car: 08 535i
Default 03-05-2016, 03:21 AM
I just installed the pi kit.
Is there a way to test it like meth(7/5) ???
martymil's Avatar
Car: BMW 1 Series M
Default 03-06-2016, 05:55 PM
easy set the afr bias to 50 and do a pull, watch the trims fall
Aerotest Aerotest is offline
Default 03-06-2016, 07:40 PM
Hello,
Can someone tell me which values enable and control the PI in the JB4 interface. I have JB4 controlling the PI.
martymil's Avatar
Car: BMW 1 Series M
Default 03-06-2016, 07:44 PM
If it's connected to the jb4 the Pi is enabled
The afr bias settings control the fuel flow
Default 03-06-2016, 11:00 PM
Tks. Any idea of what the bias value range represents (0-100)?. Does PI still enable at a specific boost value, based on rpm (which is what the bias is ranged at and doesn't make sense), or a combination of both? Engagement boost threshold value? I am running the ST FW.
Default 03-07-2016, 06:44 PM
Hey Terry,
Could you share some insight on how the jb4 controls the aic and what the AFR bias numbers correlate to so I can tune the PI?
Tks in advance,
Default 03-07-2016, 06:56 PM
I could have sworn I wrote up something. I'll have to look around for it. Anyway higher values = more PI, lower values = less PI, the internal curve is JB4 firmware specific, and you can log the output under "Fuel Enrich" in JB4 logs.
So I'd set AFR bias all to 50 and look at the parameter in logs to get a feeling for the algorithm. Then raise it in areas where high fuel pressure is crashing if needed.
Default 03-07-2016, 09:03 PM
Easy enough thanks for the response.
artsoasis artsoasis is offline
Car: 335iS
Default 03-12-2016, 10:08 AM
I'm running this Port injection kit without a JB4. So once I load the N20 map on the AIC controller do I need to make any changes? Is it "Set-it and forget it"?
Car: 2008 535i
Default JB4 integration - 03-14-2016, 09:08 AM
Terry-I have a separate setup for the port injection with an independent tank with pump as a secondary for the port system. Will this setup be a problem to do the integration with the JB4?
Also does the SS goes higher than 16psi? or need a new unit for it to go up to 26psi?
Default 03-14-2016, 11:35 AM
The JB4 controls port injection flow. If you have a separate tank we'll have to disable the JB4s low fuel pressure variable for you otherwise it will be compensating IPW for the primary system while you're running it off the second.
Car: 2008 535i
Default 03-14-2016, 03:41 PM
How do we accomplish this?
Also is the install the same?
Default 03-14-2016, 04:20 PM
After it's all installed and running just drop me an email and I can send the firmware.
trebila's Avatar
trebila trebila is offline
Default 03-15-2016, 02:05 AM
didn't realized JB4 integrating PI was also controlling the IPW of the lpfp.
Default 03-15-2016, 08:19 AM
It's not, but it has to read the low fuel pressure and compare that with boost pressure, to calculate injection pressure. This then factors in to the PI injector pulse width.
trebila's Avatar
Default 03-15-2016, 09:09 AM
understood
