(#1751)
Bullitt1841's Avatar
Default 12-02-2015, 07:08 PM
Originally Posted by ThaCuda
I have searched through for readiness questions, and it seems you can flash to "stage 0" and have the readiness for inspections.
My question is; if I am flashing JB4 Backend, then is there a BEF so I don't have to perform the full flash back to stock? I am re-installing my DP fix just for the inspection, then removing of course. So other than Map0 on JB4, any known way to have readiness and such for inspection? I am currently using the JB4 PUMP BEF. Thanks for the help.
You have to modify the BMS BEF to get readiness for O2 sensors. You will achieve readiness once this is changed ON ANY MAP. But, it must be set to Map 0 for any OBD2 communications, externally. Don't ask me how I know, because a friend of a friend of a friend told me about this.
Default 12-02-2015, 07:34 PM
Originally Posted by cmg5461
I'm getting Torque control value codes flashing using the backend option. Looking for alternatives.
At this point, I might just be sticking with bbflash
You must be doing something wrong then as there are no known issues. Maybe an issue with the map you're flashing for your DME version.
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 12-03-2015, 07:28 PM
Stupid question but.. the XDF files are the ones at the Bimmerboost software thread? The same for both Bimmerboost and MHD?
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
Default 12-03-2015, 07:29 PM
The same XDF files work for both, generally, with some tables only being able to be modified if flashing with MHD.
ccdre ccdre is offline
Default 12-05-2015, 09:39 PM
Another noob question.
With MHD Stage 1 currently on the car, what is the easiest way to adjust the Torque Request values in order to fix the Alpina B3 TCU flash functionality in D mode, while retaining the Stage 1 MHD flash?
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 12-07-2015, 06:25 AM
I appreciate the knowledge.
I haven't tried what you have shown just yet. So far, I have installed the DP Fix, flashed to stage 0 per Marshal suggestion, ( however my normal flash is the BEF JB4 PUMP) and given it some drive time. I have now adjusted the DP fix from around 5'oclock position, up to around almost max. each time i made a slight change on the DP fix, i still get the 29f4, 29f5.
So going back to what Bullit mentioned.. is modifying the flash ( stage 0 or otherwise ) required to get it to read properly and give readiness?
Appreciate the help.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD update v1.20 - 12-07-2015, 09:39 AM
12/07/2025 - v1.20
- added increased boost ceiling support (MBoost option) for the 1M, z4 and 335is (ikm0s and ina0s firmwares)
- added support for the BMW X6 35i
- Load per gear can be set up in custom maps (recommended only for MT cars. For AT/DCT another method will be added).
- Increased slots for Flasher / Backend only Flasher per Google account from 3 to 6
- Fix - removed options when flashing back to stock
- Fix - Gauges min/max reset bug
Load per gear is working nicely on MT cars, on AT/DCT another method to limit power in the first gears will be needed. Once this is implemented, a flash option will be added to limit power in gears 1-3.
Default 12-07-2015, 10:20 AM
Yes.
dustz dustz is offline
Car: E90
Default 12-07-2015, 12:38 PM
I have not had the chance to upgrade the g4 to a g5 yet. Does anybody know if the MHD Flash is compatible with the jb4 g4 module? 2007 335i, manufactured 11/06.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 12-07-2015, 02:37 PM
You need the recent firmware that support the menu 4/2 and 4/3 to use the BMS flash, so you will need the G5
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 12-08-2015, 01:20 AM
You can upgrade to g5 and run a backend end flash. But the g4 is a little gem since it will allows you to switch to map4 and let a stand alone flash like our MHD maps to run without controlling the boost like the g5 is even on map 4.
mistawall mistawall is offline
Default 12-08-2015, 01:56 PM
cant get my phone to connect to MHD.. using BT dcan and the usb to mini usb adapter. connects to jb4 no problem when i use my jb data cable. but doesnt seem to pick up the dcan in the odb port
TFT inlets, charge pipe TIAL BOV
RISS **, Exhaust
Walbro 450
335is Clutch
BMS short shifter
VRSF 7"
Montego Blue 1M clone
@breakmywallet (instagram)
volcom8190's Avatar
volcom8190 volcom8190 is offline
Not New Member
Car: 2010 335i
Default 12-08-2015, 03:03 PM
are you on map 0, does your phone support OTG?
Default 12-09-2015, 07:42 AM
i figured it out i was using the Bavarian tech cable. i had to use one of those other dcan cables luckily i had one
RISS **, Exhaust
Walbro 450
335is Clutch
BMS short shifter
VRSF 7"
Car: 09 E92 335i
Default 12-09-2015, 04:55 PM
Noticed that the SES light stays on for a few ignition cycles with the newer software and flash, while the older version from the summer was able to get rid of that annoying light.
Has anything changed for the code delete function at the end of the flash?
Default 12-09-2015, 05:14 PM
Is it possible to raise the idle on the BEF? Never edited bin files before. 6MT and think it would help start off engagement and reduce idle FW rattle on my car.
N54 | Build Thread
Iflickr.als Iflickr.als is offline
Car: Bmw
Default 12-09-2015, 10:55 PM
2 cars after updating to last MHD with latest jb4 FW , motor damaged piston #6 and bent ROD cars running fbo meth mhd t map sensor pump gas , one of them 335i MT and the other is 1M , any one face this issue ?
BMW 135i 2011 N55 Pure Stage 1 ETS Fmic , BMS Downp1p3 , BMS Intake , BMS OCC , BMS meth kit cm7 , jb4 ISO + MHD .
dawhiz's Avatar
dawhiz dawhiz is offline
Car: 09 335xi
Default 12-10-2015, 01:14 AM
I have to look into my issue more but I go lean on wot. Might be o2 is what i'm thinking though. Bumps to map 4. Also happens in map 4 which is where it's currently at.
wardy335i's Avatar
wardy335i wardy335i is offline
Car: E93 335i
Default 12-11-2015, 04:46 AM
Originally Posted by MHD
12/07/2025 - v1.20
For what reason is there going to be a load limiter put on gear 1-3? what issues are known??
2008 E93 335i M-Sport 6AT
MHD Stage 1 // Dual Foam Cones // Avant Garde M359 //
Powerflex Black Edition Polys // Ferodo DS2500s // VRSF 3" *** // TBC
London
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 12-11-2015, 08:44 AM
It's to aid in traction for high powered setups.
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
drifter's Avatar
drifter drifter is offline
Car: N54 135i
Default 12-11-2015, 02:35 PM
Hi guys,
Can someone have a look at this log for me please.
Not hitting target boost? Checked for errors and there is none.
Thanks in advance and appreciate any feedback!
http://***********/u/drifterr/first-l...&data=3-4-6-21
N54 135i - GTX3582R - 7" VRSF IC - BMS Meth Kit - XtremeClutch ceramic twin disk - RTD shifter & a load of other bits
reelruckus reelruckus is offline
Car: e 92 335i
Default 12-12-2015, 11:49 AM
Can't find engine version of car in mobile app in settings that says ijeos or i8aos
Car: e 92 335i
Default 12-12-2015, 11:50 AM
10/07 build date please help
Car: e 92 335i
Default 12-12-2015, 12:23 PM
Hi guys, mhd app can't contact ecu. Could be bad cable? It's a ķ + dcan inpa compatible ? If not on and everything
Max Fotography Max Fotography is offline
Car: 2008 E92 335xi
Default MHD - 12-13-2015, 04:04 PM
Has anyone used MHD as a stand alone? No JB4 or Cobb just running MHD?
I wanted to know whether using it alone will show a significant difference in power?
