(#351)
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 09-12-2015, 02:38 PM
Originally Posted by AWSAWS
Thanks. Does this then mean that I can use the jb4 torque ceiling values if using MHD flasher? It's only necessary to retain stock values if using a BT cable.
Spot on
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 09-14-2015, 07:40 AM
Thanks that makes sense now.
In the beginning I'd always used the bin straight from the download and had no issues but using MHD explains it.
I now modify my bin to account for my DCT transmission, the MAP voltage and the O2 sensors.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 09-15-2015, 04:27 AM
Original post edited to link HairyWelshSteve's guide and remove Method 2 (which was creating more confusion than anything else)
AWSAWS's Avatar
Default 09-15-2015, 04:37 AM
I actually didn't realise that there were BB specific and MHD specific bin files.
D'oh!
johmei's Avatar
johmei johmei is offline
Default 09-15-2015, 05:03 AM
Great move deleting method 2 and linking in a guide for method 3. This will help a lot of folks!
Many probably miss that Torque Monitor Ceilings shall not be changed for MHD use. I for one missed that and just followed Method 1 and thought I killed my drivetrain when I hit the stock ceilings on the first pull (car went into "hellalimp"!).
Default 09-15-2015, 07:29 AM
Cheers!
jamhot's Avatar
jamhot jamhot is offline
Default 09-19-2015, 03:57 AM
anyone have a stock EU bin they could send me? I lost mine... or should I say, didn't back mine up. tia
Default 09-19-2015, 05:06 AM
What DME version?
jamhot's Avatar
Default 09-19-2015, 06:04 AM
I8A0S, sorry should have mentioned that...
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 09-19-2015, 06:21 AM
Email me. But we will have not identified zones different from each other :/ could cause some errors.. but i can send it to you anyways. My email is tiagobaloca@gmail.com
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
Default 09-19-2015, 06:49 AM
I have my UK bin pm me your e-mail address
jamhot's Avatar
Default 09-20-2015, 03:00 AM
Steve has sent me a UK bin. Many thanks for all the offers guys! It's much appreciated.
jamhot's Avatar
Default 09-21-2015, 04:23 AM
tried flashing my custom bin file and doing the mod to the stock bin but got the MHD error while trying to flash??? see screenshot
any idea's guys?
jamhot's Avatar
Default 09-21-2015, 04:24 AM
try again https://drive.google.com/file/d/0B22...ew?usp=sharing
jamhot's Avatar
Default 09-21-2015, 08:58 AM
Got to the bottom of this I think. I ended up modifying a stock I860S for my I8A0S DME and MHD flasher basically thought I was going mad and stopped me loading it. If anyone has a I8AOS uk stock bin I would be grateful for the donation. Didn't notice the issue to begin with because the DME numbers are very similar. Doh"!
mrx168 mrx168 is offline
Car: BMW E90 335i
Default 09-21-2015, 10:24 AM
Is there an very noticable difference in performance when doing a backend flash (vs just JB4 alone) on cars with just FBO mods?
Not planning on going higher than basic FBO (waiting for my FMIC to arrive) at this stage and I'm sitting on the fence on whether I can be bothered to mess with all this DME US to Euro conversion ****e.
And knowing me, no doubt I will **** something up and end up with a BSOD car...
Man I miss the simpler times of tunning with my Skyline, wack in bleed valve + SAFC 2 signal bender, take it to tuner and pay some $$$ and drive away happy.
2007 E90 BMW 335i |JB4|AR ***|ER chargepipe + Forge DVs|BMS dual cone intake|
1993 R33 Nissan Skyline GTS-T |SAFC-2|Apexi POD|Boost Tee|FMIC|3" TBE|
Default 09-21-2015, 11:09 AM
Yup my bad - rectified now though!
AWSAWS's Avatar
Default 09-21-2015, 01:22 PM
Maybe not, but it'll be healthier for your car. Better AFRs for various fuel types you may run, better timing, better fueling, better view of torque by your transmission.
montyp86 montyp86 is offline
Default 09-22-2015, 10:25 AM
Hi all, firstly this forum is awesome, so much good info, I have read through this whole thread and have a few questions if one of you would be so kind as to help . .
I have only had my 135i for a few weeks, its FBO (no meth) and I live in the UK. The previous owner said he just set the JB4 to map 5 and never changed it or did any logs/flashes, but that the car was remapped by the owner previous to him while it was stock.
I flashed the US pump gas back end flash using MHD a few days ago, car felt extremely fast up top, no codes, but stuttered and hesitated mid Rpm range.
I decided to go back to my original map until i changed my plugs/coils.
I have now changed my plugs and coils, but have since found this thread so i am unsure what to do.
Should i still try and use the US spec back end flash first, and see if i have issues?
Is there any euro guys running the US spec back ends and having no issues/are happy with it?
I am awaiting a USB extension arriving so I can do some logs, the one attached to my JB4 is very short.
Any help is much appreciated
Eristoff's Avatar
Default 09-22-2015, 10:39 AM
Hey there. First of all and as Terry always says "we need some logs" so we shall wait for the cable and for some logs.
Eristoff's Avatar
Default 09-22-2015, 10:41 AM
And I will need your OEM file to transfer over the US to your oem bin (EU spec)
Eristoff's Avatar
Default 09-22-2015, 10:50 AM
And by the way that kind of file is in your DME? :/ if its not a backend, it should not be used with jb4 :/.. and if it is you should set your JB4 to 4/2 (menu 4 on speedometer, menu 2 RPM meter)
Default 09-22-2015, 11:02 AM
Thanks Eristoff, as soon as my cable arrives i will post some logs.
Yes, after doing much reading over the past few days i appreciate i should not be running a map along with JB4 if it is not a specific back end.
I have tried setting 4/2 and 4/3 and feel no noticeable difference. I have a p3cars boost gauge (i don't think its very accurate, well i hope not!) and always hit 21psi max in either setting. Never get chucked into map 4 so the gauge must be reading high.
It may not even have a map . . who knows if the original owner was telling the truth.
If i posted the back up of my DME i took before trying the US spec map would you be able to tell if it was stock??
Default 10-04-2015, 10:29 AM
Hi Eristoff,
Finally got my cable and did some logs. I have been playing with various settings all day and posting in another thread if you fancy reading it.
http://www.n54tech.com/forums/showthread.php?t=34011
Basically i am back where i started still not hitting my boost targets.
I have attached the first logs i took earlier today showing this.
Any thoughts/advice would be appreciated
2008 135i M
JB4, Alpina trans fash, Trebila Custom flash, P3 gauge, BMS DCI, BMS ***, VRS 7" FMIC, VRS CP, Tail BOV, BMS Wheel Spacers, BMS oil catch can, KW V1 coilovers, E92 M3 front and rear lower control arms, BMW M3 Anti roll bars, Quaife Limited Slip diff, Custom Quad exhaust
Default 10-04-2015, 10:33 AM
Also . . . after doing proper WOT pulls the car definitely runs better in setting 4/3, even though i may have an ecu flash.
I tried setting all my duty bias to zero on the advice of Terry, presumably to work better with the ecu flash i may or may not have, but it made the car run terribly.
I am keen to give the MHD back end flash another try, euro modified this time, the fact i am not hitting boost targets isn't good, but i'm excited to see what the car feels like when its dialled in because i am already impressed!!!
2008 135i M
