(#376)
Car: 2007 BMW E90 335i
Default 06-01-2017, 08:30 PM
Can we get Stage 3 v1.2 map that doesn't have the crazy blips in M mode? I'd like to have the other upgrages of 1.2, juat no agressive throttle blips. Thank you!
2013 135is DCT Carbon Black
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 06-02-2017, 06:58 AM
V1.3 will be out in a few days.
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://bit.ly/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 06-02-2017, 08:40 AM
+1 for this. This would be a nice flash time option.
Exciting, any feature previews?
MEGALE MEGALE is offline
Car: 535ix
Default 06-08-2017, 08:51 AM
What are the main differences between the stages? If I am not actively racing my 2010 535xi which stage is recommended?
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-09-2017, 04:51 PM
Been running stage 2 for 3 days, noticed strange issue which happen 2 times, when I'm on 3rd gear and floor it and cut off on high rpm it shifts into 4th gear for 1 second then again downshift to 3rd gear by it's own which today made the rear tyres skid before i manual shift again into
4th immediately to lower rpm.
Attached log showing how it was on 3rd cut off throttle so it shifted into 4rd and directly it goes back to 3rd until I manual shift to 4th again.
Not sure if anyone else had this issue also.
Default 06-15-2017, 10:46 AM
Any word on this? Haven't seen any app updates in awhile. Or do I even have to update the app to get new maps?
N54QC N54QC is offline
Car: 07 BMW 335i
Default 06-15-2017, 02:47 PM
You just have to have the latest version (1.1.53) of the app. I don't even think I updated it and it had the V1.3 on it already. Surprisingly, I went from the V1.2 which seemed a little harsh to me to V1.3 which now feels kind of sluggish comparably. Maybe it will do better as it adapts.
Default 06-15-2017, 04:21 PM
Stage 3 v1.3? I only see 1.0, 1.1, and 1.2 with single turbo versions of each.
Car: 07 BMW 335i
Default 06-15-2017, 04:50 PM
Yep, just installed it yesterday and it had stage 3 v1.3. It was released on the 12th. Maybe check your app store to make sure you have the newest update.
Car: 2008 E93
Default 06-16-2017, 09:32 PM
So 2.0 and 2.1 are obsolete now ??? Everything says 1.x now. What happened to the 2.0 / 2.1 ?? Or am I not sober enough to see them anymore ?
Koolsilver Koolsilver is offline
Default 06-16-2017, 11:35 PM
I flashed my 335i with stage 3 about two days ago, previously I had the Alpina flash. With both this flash and the Alpina flash it seems I may be getting what people are referring to as transmission flare. When I upshift a gear my RPM will increase by maybe 100 or 200 and then begin to shoot down to the correct RPM for the next gear. This mostly happens in lower gear upshifts. What could I do to eliminate this issue as it seems that this taking away a lot of the speed from the gear change.
ajsalida ajsalida is offline
Car: e92 335xi
Default 06-17-2017, 10:00 AM
Has the req to completely disconnect JB4 prior to install been fixed, or if not has it been linked to a specific ECU or JB4 version? IJEOS running latest JB4 firmware, 32.8. Anyone with this combo have issues installing xHP leaving JB4 on map 0 only? Thx.
n5418102's Avatar
n5418102 n5418102 is offline
Car: 2008 BMW 535xi
Default 06-17-2017, 01:23 PM
i have sucessfully flashed xHP with jb4 on map 0 . everything went smooth 0 issues.
n5418102's Avatar
Car: 2008 BMW 535xi
Default 06-17-2017, 01:25 PM
my app version is 1.1.53 but im not getting that v1.3 for stage 3 on 535xi . is it only for other models only?
i have redownload the ots maps from the app store and still same versions v1.0 and v1.1 .
Car: e92 335xi
Default 06-17-2017, 01:35 PM
Good to know, thanks. Anyone with 335i/xi IJEOS ECU and JB4 firmware 32.8? I really don't want to have to disconnect JB4 every time I flash a new xhp version or whatever.
Default 06-17-2017, 02:08 PM
I have a 335i with newest jb4 firmware. Flashed using xhp with jb4 on map 0 no problem.
Rushan's Avatar
Car: 335i E92 2009
Default 06-17-2017, 02:45 PM
Same here, e92 2009 with jb4 latest firmware all went ok from my alpina flash to stage 2 xhp
Car: e92 335xi
Default 06-17-2017, 02:51 PM
Excellent, thanks guys.
Default 06-17-2017, 03:22 PM
I think he just renamed them? The version control could use some help.
Car: e92 335xi
Default 06-17-2017, 05:41 PM
OK just flashed OTS map 3, version 1.3, 2009 335xi. Zero issues flashing thru JB4, later firmware automatically sets to map 0 when cable is connected. I did have a small issue I think was battery charger related. I had my charger set on 2 amps, 40 amps is the next setting. Initial backup failed at about 85%. Set the charger back to 40 amps (15 indicated on meter) started over, and let it go, everything was fine there on out. I used my cheap eBay INPA cable, cheap eBay OTG adapter, and my old deactivated Samsung S4 phone. End to end about an hour, that is backup, install app, flash TCU. So make sure your phone is charged up.
I have been running one version or the other of the Alpina flash for over 4 years, since it first came out (or was made public knowledge) thanks to Tomaz and then Cn555ic's DIY. I have never been super happy with it, esp D mode. I was concerned I'd lose the paddles like every other time I flashed the TCU back and forth between various Alpina and stock files, no problems paddles work fine.
Short test drive on xHP, D mode is fantastic. Also M-mode downshift rev matching A+. Only had a chance to drive about 15 miles (domestic **** this evening) but wow what a difference. Will baby it for a while let it adapt and then we'll see. So far so good.
Nice work, xHP.
RayBan81's Avatar
Car: 335i E91
Default 06-18-2017, 12:14 AM
Sorry, for causing confusion.
Originally the V2.x were meant to be for the ST guys, but as people were always just flashing the "latest" version, we had a lot of complaints about "shift points too high in D". (people with stock cars were using the ST maps)
So I changed the versioning to be the same for both, but ST maps have a "Singe Turbo Conversion" suffix.
That should be way more clear for new customers.
megaman416 megaman416 is offline
Default 06-18-2017, 08:47 AM
So it's confirmed new version will flash with JB4 in bypass mode if you had to physically disconnect before? From scratch as a new install?
TM TS 6466 Powa!
Rushan's Avatar
Car: 335i E92 2009
Default 06-18-2017, 09:09 AM
Works with jb4 on map 0
Car: e92 335xi
Default 06-18-2017, 09:33 AM
From scratch: 2009 335xi, w/ IJEOS ECU, 32.8 JB4 firmware. Note with latest/recent firmware JB4 automatically goes into bypass mode when an OBD2 cable is detected, you don't even have to set it at Map 0. No issues doing initial backup, installing software, or first flash map. EXCEPT make sure you have a good charger, I'd think 10 amps min. 2 amp trickle charger won't cut it.
houtan houtan is offline
Default 06-21-2017, 03:25 PM
Any possibility this will one day make it to the DCT trans?
