(#3276)
JayMixitSigns JayMixitSigns is offline
Car: 2007 E92 335i
Default 06-08-2017, 01:50 PM
Im wanting to try MHD stage2+ 98ron map while leaving the white sub connector attached for jb4 features, with menu 4/4 set. Will I need to 0 out the duty bias? Also what settings would menu 10,11,12 be set at to allow the jb4 to follow the flash tune most accurately?
Default 06-08-2017, 06:04 PM
No with white subconnector removed and mode 4/4 set no reason to touch any JB4 settings as they won't be active.
Car: 2007 E92 335i
Default 06-09-2017, 12:44 AM
Yes Terry but im wanting to leave the sub connector attached for logging and safety as I said, currently running the race back end but now my plugs have a few thousand miles on timing pulls are apparent. Was looking to try there OTS map for a little while. I have used them previously on the version 6 maps but found the throttle to have some hesitation so thats the reason for the question about the settings really.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 06-10-2017, 09:23 AM
I sent the info over to Sticky's programmer since he is doing a new app, but I guess that was delayed a few weeks. Anyway forward me the BIN and I can run the program on it to add the checksums. I have it setup for i8a0s and ije0s only currently.
Thanks for doing the Checksum for me. I flashed the file today with no issue along with doing a JB FW update and car is running great.
Default 06-10-2017, 09:25 AM
No problem I'll just clean up and post the app shortly probably. Was hoping to avoid wasting more of my time with it since BB is including it. Oh well.
Default 06-10-2017, 09:26 AM
I don't know what you're trying to do. You should be running one of our BEF maps appropriate to your fuel, along with the JB4 map appropriate to your power requirements. Then, if you need tuning help on fixing or improving something, post a JB4 log to the support forum with a list of mods, fuel, and details.
Pessimistic Poster
Car: 135i N54
Default 06-12-2017, 09:26 AM
This may be a loaded question, but after switching from the old 2/23/16 BB file to the 3/17/17 Merged file, it feels like the throttle is a lot more sensitive to loading up the engine at light throttle and low RPM, which is noticeable in daily driving. Tried adjusting Menus 10,11,12 but didn't seem to affect this. Is this tied to any specific tables in the BIN where I could maybe copy from the older one to the newer one, or is it just due to a combination of torque and WGDC changes in the tuning?
Cynical Cynical is offline
Default 06-12-2017, 05:14 PM
Menu 11. Adjust down. Could also be 10. But more likely 11
Default 06-12-2017, 05:51 PM
We may have tweaked the torque request high and low % tables in the BEF also, so I'd start by evaluating those.
sanya0971 sanya0971 is offline
Car: BMW 335 e92
Default 06-13-2017, 03:59 AM
Hello, help me please)
I have jb4 isog5, and I also want to flash mhd backend..
But have some problem during flashing "Failed to write section paket 761"...
N54 e92 335, 81 engine version, 2008.04
Pessimistic Poster
Car: 135i N54
Default 06-13-2017, 06:33 AM
Thanks Terry. Looking at the old vs the new, the newer tables are more aggressive and more square across the range, while the older ones have more progressive values especially at low pedal percent.
Is it safe to copy the tables from the older flash to the newer one if I prefer that throttle mapping? Is this tied to any other torque related tables since it is percent based? This would not require a new checksum be calculated correct?
Default 06-13-2017, 03:28 PM
Yes those two tables and their axis can be copied, they do not interfere with the torque checksum.
Pessimistic Poster
Car: 135i N54
Default 06-13-2017, 05:16 PM
Tried this tonight and it works great. Back to the response I am used to. Will test over a few days of daily driving. I'll be sure to keep these tables as my 'favorite'. Thanks as always for taking the time to answer these questions!!!
n5418102's Avatar
n5418102 n5418102 is offline
Car: 2008 BMW 535xi
Default 06-17-2017, 01:21 PM
do we have a BEF for the I8A0S for ********* D P ?
im running jb4g5 and im getting cel code for ***** D P.
JLIT's Avatar
JLIT JLIT is offline
Car: BMW 335i
Default 06-18-2017, 08:30 PM
Originally Posted by MHD
O2 cannot get ready if the maps has some codes disabled. And the flash option ensure that codes are enabled, so readiness can be achieved IF cats are working properly.
Update the app, reflash the map, there was a bug for a short period of time.
My app is currently up to date but I'll reflash for sure. Thanks for the help!
E90 - 2008 -335i - FBO: WedgePerformance Tune, xHP Stage 2, Inlets, BMS DCI, 7" FMIC, ER CP w/BOV, VRSF meow-less DP w/lower cp upgrade, Vanguard full catback exhaust, KW V2 Coilovers, rear diff strut brace. Wheels stock af.
JaxMustang50 JaxMustang50 is offline
Car: 2011 335i Coupe M Sport
Default 06-18-2017, 09:38 PM
Will it be possible to use the BB flash to change the commanded engine coolant temperature on my 2011 E92 N55?
I read that this is possible with MHD but I don't have android.
Can commanded temp be changed with JB4?
Any other method for tuning this one function?
I'm really only interested in that one function at this point though the future holds some other tuning enhancements for sure.
Any help is greatly appreciated.
Thanks,
J
Default 06-19-2017, 06:34 PM
Someone mentioned they were having an issue with the XHP automatic trans flash and the BEF maps? If they've adjusted the line pressure directly you may need to put the "Torque Eff Divisor" back to the factory profile for things to run normally...
totti totti is offline
Car: E82 135i N54
Default 06-20-2017, 02:48 AM
Hi Terry, whats the general concensus when running stock turbos (upto 20-21psi) on E45 fuel. Is E85 BEF or Race BEF preferred? Thanks
Default 06-20-2017, 08:24 AM
E85 BEF for E40 and above...
Car: E82 135i N54
Default 06-20-2017, 08:46 PM
Thanks Terry. What would be required to justify the Race BEF?
N54QC N54QC is offline
Car: 07 BMW 335i
Default 06-20-2017, 08:49 PM
Meth or race gas
Default 06-20-2017, 08:52 PM
It's just a higher advance version of the PUMP file. WMI, good 93 octane, race gas mix, E85 mix, etc.
yellowfin's Avatar
yellowfin yellowfin is offline
Car: 335xi - jb4 - DCI
Default E85 or HYBRID E85 bef? - 06-22-2017, 05:50 PM
I am getting GC lites. I have catted aftermarket DP (CP-E), fuel-it stage 2 lpfp, but no PI. As DD will target max 20 psi with E50.
What's a better fit, E85 or hybrid E85 bef? With my fueling setup and moderate power goals, I'm leaning towards the standard E85 bef. Had good experience on stock turbos until they wore out What are the considerations?
2007 335xi (I8A0S kline) -- VTT GC lites + inlets + outlets -- Fuel-it stg 2 lpfp -- CPE catted **, FMIC, CP -- Tial BOV -- BMS DCI + OCC
JB4 + BMS/custom bef (E50)
Default 06-22-2017, 05:52 PM
I'd run the hybrid E85, to start.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-23-2017, 01:31 AM
The most common issues for random failing flashes are lack of current or unreliable KDcan cables.
For the current supply:
- let the battery charge fully first and leave the charger on
- if the charger is less than 10 amperes, remove the fuel pump fuse it's easy: http://www.n54tech.com/forums/showpo...9&postcount=10
- alternatively, bridge the car to another running engine
Make sure ignition is fully on (insert key, press the start button without touching the brakes until the dashboard displays the actual fuel level) .
If that stills fails, it's often due to a bad KDcan cable. See page 5 of the user manual for recommended cables per country
http://www.twisted-visionz.com/mhdguide
